Antipode pack spearhead model
Discussion in '[Archived]: N3 Rules' started by Tanan, Oct 19, 2019.
  1. Tanan
    Tanan Well-Known Member
    When antipode assault pack receives an order, a spearhead model must be chosen. However, I fail to see any functionality for the spearhead model.
    Did I miss something?
  2. Arkhos94
    The spearhead is the one who will perform the cc attack (if the pack had bs weapon, he would be the one performing bs attack). For every other skill, spearhead is meaningless
  3. RobertShepherd
    Are we sure? I was under the impression that this was a matter of some contention.
    Tanan likes this.
  4. Tanan
    Can antipode pack model be part of a Coordinated order?
  5. Mahtamori
    Tanan likes this.
  6. solkan
    solkan Well-Known Member
    It'd matter more if the Antipodes had more skills that they could perform that involve rolling dice. :)
    Honestly, I'm just hoping that in N4 they delete half the text of the Antipode rule, and replace it with "Antipodes always activate using the Coordinated Order rules, with all pack members involved in the order if any of them are, and one of the antipodes must be the coordinate order's spearhead. If only the antipode pack members are involved, no command token is used for the order."
    Save half a page, and give them more reason to consolidate the rest of the multiple-trooper activation rules..
    Section9 and theradrussian like this.
  7. Arkhos94
    The matter of contention is not on "the spealeader will perform CC attack" but on "what happen if 3 antipode are in CC with an enemy and the ennemy target an antipode other than the spearleader for ARO => Is it F2F with the leader or both the leader and ennemy have normal roll" (it's the second unsolved question)
  8. Tanan
    If antipode pack is activated by Coordinated order, can non-spearhead models make an attack?
  9. ijw
    This is false. The Antipode rule contains no restrictions on which trooper performs the CC Attack.
    If it is a CC Attack, no, because the rules for Coordinated Orders and CC only allow the Coordinated Order Spearhead to perform a CC Attack:
    • In Close Combat, only the Spearhead trooper will perform the CC Roll, getting a MOD of +1 to his B and +1 to the PH Attribute for Damage for each friendly trooper participating in the Coordinated Order engaged with the adversary.
    Tanan and RobertShepherd like this.
  10. Arkhos94
    I checked and you are right. So what's the point of the spearhead if it's not used for anything ?
  11. ijw
    It has no point. :-(
    Arkhos94 and theradrussian like this.
  12. Marduck
    Marduck Well-Known Member
    Yet another unique rule to erase ? Is the gameplay difference between the pupets in nomad and this tri antipode thing meaningful enough to have two different rules ?
    Or they could just be G synch to the antipode controler (would requiere the controler to gain camo to be consistant I guess). Would make them work more like the chimera.
    theradrussian likes this.
  13. ijw
    Given how drastically differently they work on the table, yes?
  14. Marduck
    I'm of the humble amateur opinion that this game could sacrifice some complexity for less special rules.
    Providing you remove the interdiction of being in camo state in a link, they could work as G Marionette. They would be less deadly (having to declare the leader before the action the reactive player can ARO accordingly) and they would be less order efficient (not generating an irregular order and not being frenzy) but they would fight to the last dog. Maybe they would cost one point less per dog then ...
    My 2 cents for N4.
    Mahtamori likes this.
