N4 Changes
Discussion in 'Yu Jing' started by Triumph, Aug 10, 2020.
  1. Triumph
    I would say that's fairly typical of what we play with, it's usually pretty difficult to get a hard ARO piece in a showstopper position that can safely defend all or most of your DZ without being dealt with. Most of our players tend to pack enough disposable and soft ARO pieces with repeater coverage that trying to punch into a DZ in one turn is usually pretty unlikely outside of drop troops or rolling for infiltration.
    EDIT: Actually found the game in question that picture was attached to. It was from the thread testing the hulang.
    #501 Triumph, Sep 24, 2020
  2. Amusedbymuse
    n3 ikol works when you use cc or dodge. But if NBW requires to use cc then para ccw -6 is real good against nwb. Not only you cheat during first ftf but after they get immobile you can start using your full power with skills.
    Edit: NWB requires only b2b but cancelling mode works only if enemy declare attack. Technically if i dodge and use ikohl then nbw cant cancell it :0
    #502 Amusedbymuse, Sep 24, 2020
  3. Space Ranger
    It feels like playing any amount of HI vs. Nomads is going to be an uphill battle. Pitchers were mentioned but my concern is their deployable repeaters. They can Oblivion a whole force just in ARO.
    Zeroes, Spektr, Bandits, Moran are Infiltrating Deployable or ARE repeaters.
    Meteor Zond, Hellcat, Tomcat are AD with Deployable repeaters.
    Jazz, Tsyklon have Pitchers.
  4. Mahtamori
    Yes. This is it. And frankly, this is what's happened to me a few times in N3.
    Still, if all HI gets the discount that Evaders and Domaru seem to get (remember that N3 Domaru had Frenzy which hides just how much cheaper they truly got), then I don't think that's going to be enough.
  5. Mahtamori
    Got a few pictures with info from my local Warcor that may or may not be relevant to the current discussion;
    Seems Assisted Fire is limited to Marksmanship only (i.e. Shock component seems to be gone)
    Total Control seems (at least on the Hcking Chart) to flip a possessed TAG back to Normal state
    Zero Pain is B2 in ARO and nullifies Comms Attacks (so expanded to Jammers and a few others as well)
    You can also affect Strategos 2 if you are the first turn player; i.e. hold back one extra trooper in reserve
    It seems you can't use a Command Token to activate Fairy Dust (or similar) on an EVO
    Tourniquet and RolandTHTG like this.
  6. Triumph
    That's a good change IMO, too much damn shock around as it was.
    Eh, so how do we possess the TAG in the first place then?
    What's Zero Pain again and what's it on?
  7. colbrook
    Same program, it's essentially N3 Total Control and Exorcism rolled into one program, like how Assisted Jump and HTA are now the same program.
    Mahtamori and Willen like this.
  8. Willen
    Willen Well-Known Member
    Interested as well. It was not mentioned in the Program´s chart.
  9. colbrook
    Sounds like an upgrade program, won't know who gets it until the profiles come out tomorrow.
    Willen likes this.
  10. Triumph
    Question being can it nullify as a normal roll to defend someone else, or does it need to be face to face?
  11. Mahtamori
    This. It's not on any of the devices natively. I'm personally assuming we'll see it in stuff that had White HDs in N3
  12. ldgif
    ldgif Well-Known Member
    So Oblivion doesn’t seem to Target HI now?
  13. the huanglong
    I guess it will only be a problem if Oblivion works on HI.
  14. Amusedbymuse
    Wait what? Why wouldnt it targer HI?
  15. ldgif
    In the chart for it, it doesn’t list HI as a target.
  16. Triumph
    Dunno, haven't seen a picture.
    If that's true though and some of the more ballbusting hacks work on HI then there's less functional drawbacks to being HI, in fact having the higher BTS scores actually makes it a benefit.
  17. Triumph
    Ok I found the picture. Seems like we were worried for nothing, unless you happen to use the Avatar. Oblivion targets HI, REM, and TAG now.
  18. ldgif
    The chart has been posted elsewhere.
  19. Triumph
    Yeah Sun Tze appears to be safe as houses
  20. Zewrath
    Zewrath Elitist Jerk
    RobertShepherd likes this.
