Infinity Army Bugs
  1. Barrogh
    Barrogh Well-Known Member
    Yuan Yuans are definitely in the Army. The reason you don't see them is probably because Yuan Yuans are either only available (IIRC) in Quapu Khalki and Druze Bayram Security sectorials, or, if you want to make a list using Soldiers of Fortune rule allowing mercs in any army, you need to enable "Mercs" in Army's options. Keep in mind that last time I checked, Army did not account for SWC cost of enabling Soldiers of Fortune in your list. Maybe that has changed.
    Fat Yuan Yuan is not a separate unit, it's just a limited release model for Yuan Yuans.
    Outrage characters other than Knauf are not available in default ITS missions, so that's probably the reason they never bothered to include them in Army.
  2. Rannith
    Rannith Well-Known Member
    The only way I seem to have of getting the desktop version to work is using a .exe file called Electron. When I try to use the Launcher.exe it tries to connect to the update server, fails and then closes. The icon created on the desktop doesn't even do that much. I am using the 32 bit version which used to work but now does not seem to want to outside of Electron.
  3. Rannith
    Bayram Security does not seem to allow them by default only if the MERCS checkbox is selected. The QK does allow them by default. The Pan-O Vanilla list includes a bunch of Mercenaries by default and when you check the MERCS box it not only adds a bunch more but doubles up on the ones that were already there.
  4. Rannith
    Just multi-talented?
  5. mittenninja
    mittenninja Invincibles NCO
    The Druze profiles in Vanilla Haq on the Army Builder app are still showing the old profiles (ie no fatality, viral pistols, etc).
  6. Stiopa
    Stiopa Trust The Fuckhead
    New profiles for Rosie and Kerr-Nau are in, but have no unit logos for now.
  7. Deltervees
    Deltervees Crash Test Dumbass
    If they don't have logos, would they just show up as blank spots with a name? If so, I can't find them.
  8. KedzioR_vo
    KedzioR_vo Well-Known Member
    Bayram Sectorial - Still the same issue that I wrote about some time ago - there's a difference between AVA of Peacemakers in Druze PDF (1) and in ARMY (2).
    PozdRawiam / Greetings
  9. xagroth
    Shasvastii play badly in the Web Army, resetting the filters makes some profiles vanish until you make a ctrl+f5 refresh.
  10. takamura
    takamura New Member
    Hello
    For the French translation, we have a problem with the Gorgos profile.
    For both profiles it is indicated to have a Spitfire. While he normally has a spitfire AP.
    I did not see any other problem for this faction.
  11. Macbain
    Macbain Professional Shitposter
    USAriadna when you look for Smoke Light Grenade Launcher in the filter options I would look for it in the weapons filter.
    However it is in the Skills & Equipment section.
  12. gregmurdock
    By my count the mobile app is now two updates behind the web browser version. When will the app be caught up?
  13. TheDiceAbide
    Is there a change-log anywhere? I see that the new characters have been added, with their unit logos, also Druze Peacemakers were reduced to AVA1. Any other noticeable changes?
    Rannith and Hecaton like this.
  14. Hecaton
    Kerr-Nau shows up as "Nexus Hacker" on the courtesy list and printed army list - correct equipment but not his name. English version.
  15. xagroth
    That also happens on the Spanish version, I'm afraid.
  16. locksmith
    locksmith comlog active
    #56 locksmith, Mar 5, 2018
  17. -V-
    -V- A! Team member
    Do you mean Hacking Chart on menu or the Hacking Chart when printing your list?
    Thank you.
  18. -V-
    -V- A! Team member
    eciu likes this.
  19. -V-
    -V- A! Team member
    Have you tried to download current desktop version? :thinking_face:
  20. konuhageruke
    I can't seem to reopen weapon chart in web version. I closed it and afterwards the button is idle. Other buttons work ok. Restart doesn't work.
