Bunch of new stuff
Discussion in 'Japanese Secessionist Army' started by Mahtamori, Sep 25, 2020.
  1. hortanium
    hortanium Major Thomas Williams, USAriadna Marine Corps
    In the iOS app it looks like karakuri get the gizmokit and from the rules it doesn’t appear to need the engineer skill to use. If this is intentional, a Haris karakuri team can heal each other while murdering everything. Combined with the extra str, these guys have quite the buff.
  2. colbrook
    "Gizmokit (PH=12)" indicates that they roll against BS12 when hit by another trooper's Gizmokit, they do not possess one themselves.
  3. meikyoushisui
    Oyama, Daiyokai, FO looks pretty good to me. Haris with 5 useable orders (Tac Aware from Oyama and NCO on Daiyokai).
  4. Fed4ykin
    Fed4ykin Well-Known Member
    Even up to 6 orders when the spitfire lt2 domaru is somewhere on the board. Talking about orderefficince. An 5 orders in a duo.
    Daiyokai might find its way in a lot of my lists.
  5. Kumatake81
    Kumatake81 Well-Known Member
    Doesn't TacAware break the Link since its an Irregular Order?
  6. Mahtamori
    It's got a special extra rule that says "In addition, if the owner of this Special Skill belongs to a Fireteam and is designated as the Team Leader, this Order can be used to activate the Fireteam"
    meikyoushisui, RasPuto and Kumatake81 like this.
  7. hortanium
    The gizmokit is listed under karakuri as equipment, while the o-yoroi lists it as a skill, that’s what I’m basing it on
  8. colbrook
    That would technically be a bug because there's no Gizmokit skill. I based my answer on the last bullet point of the Gizmokit rules:
    ijw likes this.
  9. hortanium
    Time to report it in bugs so CB can tell us what they mean.
    Having looked at a few TAG profiles now, the one’s I’ve checked list gizmokit under skill, like the o-yoroi. The karakuri are the only one I’ve seen to have it as equipment, besides engineers. That final bullet point doesn’t negate having it as equipment and having it used on them, it only states that the bracketed PH value is used. Doesn’t mean it’s not a bug, especially with how strong it could be, but it could very well be intentional. Hopefully we find out soon.
    #49 hortanium, Sep 26, 2020
  10. Kumatake81
    Why would the gizmokit on karakuris be a bug because it is listed under equippment?
    I think it is like:
    Listed under equipment: you have the gizmokit, and everything in brackets applys
    Listed under skill: you do not have the gizmokit itself, but if one is used on you the brackets apply.
  11. ijw
    It’s a bug. Karakuris do NOT have GizmoKits.
    meikyoushisui, RasPuto and colbrook like this.
  12. wuji
    wuji Well-Known Member
    Use the Multi Marksman Rifle for Heavy Targets that are usually not getting B2 in ARO except the handful like the Daiyokai himself.
  13. ambisinister
    ambisinister Broken Zoetrope
    Since dual wield doesn’t appear to be a thing anymore, Neko having 2 distinct CC weapons, means he just selects which one he wants to use any time he makes a CC attack, correct? Contrast this with Musashi who has a single AP+EXP weapon whereas before they both had dual wield and AP and EXP weapons.
  14. ijw
    That’s correct, but his EM CCW is arguably nastier than AP+EXP!
  15. solkan
    solkan Well-Known Member
    Presumably they figured that the AP+EXP combo was better represented in N4 with DA, and the option of E/M. :flushed:
  16. ijw
    EM CCWs are nastier than AP+EXP.
  17. Kumatake81
    Are Karakuris immune to Para Amunition? So they can't get Immobilized by them?
    Are they immune to FO as well? Because in the trait it says: State:Targeted and Immunity makes you ignore that?
  18. ijw
    Yes and yes.
    wuji, RasPuto and Fed4ykin like this.
  19. Quickit
    Quickit Well-Known Member
    Sad face. Figured it was too good! I was just imagining a Haris of 3 Karakuris moving up the table and stopping every few minutes to fix each other up.
