zapp painting
Discussion in 'Miniatures' started by zapp, Mar 24, 2018.
Tags:
  1. Section9
    Oooooh, nice!!!
  2. zapp
    zapp Well-Known Member
    I finished the Zuyong HMG in May 2019 and it was a pleasure to paint. I'm realy happy how my interpretation of the studio color turned out with the Zuyong armor.
    I did many pictures this time, so don't forget to click the button.
    Terminé el HMG de Zuyong en mayo de 2019 y fue un placer pintar. Estoy muy contento de cómo mi interpretación del color del estudio resultó con la armadura de Zuyong.
    Esta vez hice muchas fotos, así que no olvides hacer clic en el botón.
    #42 zapp, May 11, 2019
    Rot_Sechs, Willen, Abydog and 19 others like this.
  3. Janzerker
    Janzerker Well-Known Member
    GORGEOUS!!!
    zapp likes this.
  4. Section9
    Finally had the forum cooperate with showing pics, so there are some fresh likes on old posts.
    Looking good!
    zapp likes this.
  5. McNamara
    McNamara Merc Rep
    Wow, amazing stuff! I think I like them better then the official CB ones!
    zapp likes this.
  6. maru
    maru Well-Known Member
    Look nice .. hava i point you already to article about speeding with cars ansd then slowing and how this compare to minature painting and how contrast operates ??
  7. jherazob
    I lost that link! Do you have it at hand?
    maru likes this.
  8. zapp
    I remember reading that article. Was very interesting.
    maru likes this.
  9. maru
  10. Section9
  11. zapp
    I did some batchwork while painting the Zuyong HMG, so I was able to finish the Tinbot Zuyong quickly, also in May 2019.
    Both tactical awareness troopers are now available for the battle.
    Hice un poco de pintura por lotes mientras pintaba el Zuyong HMG, así que pude terminar el Tinbot Zuyong rápidamente, también en mayo de 2019.
    Ambas tropas de conciencia táctica están ahora disponibles para la batalla.
    Some size comparison between male and female troopers.
    Alguna comparación de tamaño entre hombres y mujeres.
    redeemer, Rot_Sechs, Abydog and 11 others like this.
  12. Section9
    Beautiful paintwork! I'd love to see those across the table from me.
    It's too bad the Zuyong Multirifle is as big as it is, it really makes the female Zuyong from the IA starter look tiny.
  13. zapp
    I'm not quite happy with the result. I cannot exactly tell you why, so I decided to call it finished and move on.
    I would have liked to get the SMG profile first, but the sculpt is fantastic and in itself its a very good model. This was finished at the end of June 19.
    No estoy muy contento con el resultado. No puedo decirte exactamente por qué, así que decidí llamarlo terminado y seguir adelante.
    Me hubiera gustado tener el perfil SMG primero, pero la escultura es fantástica y en sí misma es un modelo muy bueno. Esto se terminó a finales del 19 de junio.
    redeemer, Rot_Sechs, Willen and 15 others like this.
  14. Section9
    There are some spots where it looks like you are suffering from fuzzy primer, but overall it looks pretty good!
  15. archangeleong
    I think it looks good as per your usual standards. However to be critical I think the cloth looks a bit plain. I think with your skills you should do a camo pattern to spruce it up a bit ;-)
    zapp likes this.
  16. Koin-Koin
    Just a thought from my unskilled painter mind: maybe the cloth and the armor are too close in term of color/hue (whatever the correct term is).
    I think that @Section9 's camo suggestion would do wonder.
    zapp likes this.
  17. zapp
    I think you're right. I did used the same colors for the cloak like I did for the Guilang. I was quite happy with it there, but it had less armor plates and think I'll do it differently when CB released the SMG version. *hint hint*
    To this day, I avoided camo patterns like a cat does avoid water. Maybe its time for a shower on the next camo model.
    Koin-Koin likes this.
  18. Section9
    I painted my Guilang with "Pine Bough" snow camo. White background with brown arcs on it, then scrub some green over the top in near-vertical strokes (I used a GW drybrush but didn't get the paint completely dry).
    The white background is a bit annoying to shade&highlight, but overall it's a very quick camo to paint.
  19. zapp
    As you already know, I am a rather slow painter. So it should be no surprise that I still have a huge pile of JSA models unpainted since Uprising. My plan for them was to use try different color scheme and it had to be be green! So I came up with his in July 2019. I hope you like it. Critique is welcome. Next step would be some tests on an armored model. But later. IA will be back with the next model.
    Como ya sabes, soy un pintor bastante lento. Así que no debería sorprenderme que todavía tenga un montón de modelos de JSA sin pintar desde el Levantamiento. Mi plan para ellos era usar un esquema de color diferente y tenía que ser verde! Así que se me ocurrió la suya en julio de 2019. Espero que te guste. La crítica es bienvenida. El siguiente paso serían algunas pruebas en un modelo blindado. Pero más tarde. Asuntos Internos volverá con el próximo modelo.
    redeemer, Rot_Sechs, Abydog and 7 others like this.
  20. archangeleong
    Lol Evangelion comes to mind!
    Oni likes this.
