Yu jing and Dahshat by Swissmade
Discussion in 'Miniatures' started by swissmade, Nov 23, 2017.
  1. swissmade
    swissmade Well-Known Member
    Jep, combination of small Yu JIng Orange parts and Haq. green, combined with a warm Camo. The Camo was the first thing which was fixed (or the reason for the Project ;-)).
    Somebody an idea, how i can make those Handy pictures smaller for the forum (I post them over Imgur).
  2. swissmade
    The next Dahshat miniature just finished. On the Pictures i saw that i did a mess with the varnish. Probably i shaked not enough, first time this happens to me. That just realy annoys me!
    #22 swissmade, May 27, 2020
  3. maru
    maru Well-Known Member
    so the green man army
    so what happend with Varnish ??
    did you get a "snow" effect or instade of mar you get glossy or Satyn ?
  4. swissmade
    If you zoom in the photos, you see that the varnisch did dry strange on the surface. Now the model has a little rough surface. Worked a little bit with the light, that you don't see it so much. Probably it's the snow effect you mentioned?
  5. Mob of Blondes
    Also known as frosting or clouding. If it disappears when putting water over it, it probably can be fixed with a coat of gloss medium or varnish, then apply matt again. If it remains, it means it is below the surface.
    swissmade and jherazob like this.
  6. swissmade
    How does it come to the frosting. Used a satin varnish spraycan, i had good results till now.
  7. jherazob
    Here's a video about this including the fix described by @Mob of Blondes :
  8. Mob of Blondes
    Matte is commonly achieved by adding matting agents, things that cause the product to dry with a "rough" surface. If they add less quantity, it stops at satin level. Frosting happens when the agents do not spread correctly, or worse, bubbles form due to contamination (so even gloss can go wrong). Sprays can catch dust in the air, or not form the right drops (wrong size, dry) due to temperature or humidity in the air, and when the prodcut lands it forms the bad coat that looks "frosted".
  9. swissmade
    A little Teaser from my next project. It's my first attempt to nmm-gold. I'm playing with the idea to switch from the yellow green highlight to a fluo yellow. Or to switch completely to fluo green-fluo yellow. Anyone tried this already?
  10. Law Dawg
    I like how you have the extremes - scifi cyber punk neon green to realistic military camo olive green.
    swissmade likes this.
  11. swissmade
    It's time to post the finished Crane. Took a while to finish it. A switched to a fluo yellow for the highlights.
    Oni, Croepoek, Modock and 10 others like this.
