White Company Jujak
Discussion in 'White Company' started by Space Ranger, Sep 14, 2021.
  1. Space Ranger
    Right now there's a lot of chatter about Jujak in White Banner. For the most part, not good. I feel, like Zuyong in Dahshat, Jujak are better in White Company than in their own force. Unfortunately they would need changes to WB to make them a little better and that's not likely to happen any time soon.
    The main thing that makes them better is that they can join two different core and haris teams instead of one in WB. One that makes Kaplans a little more expensive and one that makes Orcs a little cheaper. To me they are fantastic in a Kaplan team. Especially the Breaker HFT +Tinbot -6. Because then I can add Gromoz with the tinbot.
    Interestingly I think they are one of the best Lt. for WC. He's cheap enough that I don't feel bad if he doesn't do much in the DZ. 2 Wounds are always good, and then putting him in a room with a HFT is fantastic. Even if all he does is cover the DZ against jump troops, he's done a good job.
    What are you thoughts and uses for JJ?
    AssaultUnicorn likes this.
  2. AssaultUnicorn
    AssaultUnicorn KTS is the best unit
    JJs rock in WhiteCo. Kaplans get the benefit of a CQB two-wound infantry (usually, you don't want to bring Kaplans up close because any direct template weapon ignores their Mimetism and then your one-wound boy is a goner while Jujaks can actually take a hit and keep going) while Orcs can get TinBot bonuses or have a slightly cheaper ARO alternative to an Orc Feuerbach.
    I am tempted to include a Spitfire Jujak into a Kaplan Haris along with Kaplan Doc and Haidao KHD or CSU, purely because B5 BS 13 Spitfire, while not having a Mimetism (-3) of the Kaplan counterpart, also includes an underslung HFT which makes the link positioning just a little bit easier on your brain. That's because you don't have to think about how to shuffle Kaplan Spitfire with a Combi+HFT Jujak when you get into tight spaces: you just have both the mid-ranges and close ranges covered by one model. That said if you want a high-burst BS 13 two-wound model and a Mimetism, and a DT weapon – why not just include Hawkwood Red Fury?
    Edit:
    Then, there's also the fact that WhiteCo has very few AP guns, and then suddenly, you look at BSG/Breaker Combi profiles that manage to do that job quite well. So yeah, if I were to have an all-rounder Haris with a Jujak in it, it would look something like this:
    [​IMG]3
    JUJAK Breaker Combi Rifle, Heavy Flamethrower ( | TinBot: Firewall [-6]) / Pistol, CC Weapon. (0 | 30)
    KAPLAN Spitfire / Pistol, CC Weapon. (1 | 28)
    KAPLAN (Doctor) Combi Rifle, Blitzen ( | MediKit) / Pistol, CC Weapon. (0 | 27)
    1 SWC | 85 Points
    Not the cheapest team by any means, but it gets the job done, and the Doc can revive both the Spitfire and Breaker Combi.
    #2 AssaultUnicorn, Sep 14, 2021
  3. Space Ranger
    The Breaker tinbot is definitely good. You can make some good Orc Haris too.
    ORC Heavy Machine Gun / Pistol, CC Weapon. (1.5 | 37)
    HǍIDÀO (Hacker, Killer Hacking Device) Boarding Shotgun ( ) / Breaker Pistol, CC Weapon. (0 | 24)
    1.5 SWC | 91 Points
    ORC Feuerbach / Pistol, CC Weapon. (1.5 | 38)
    JUJAK (Engineer, Deactivator) Boarding Shotgun, Panzerfaust, D-Charges ( | GizmoKit) / Pistol, CC Weapon. (0 | 30)
    1.5 SWC | 98 Points
  4. Surmelk
    Surmelk Well-Known Member
    I use Jujak a lot in my WC lists, but seldom in Yu jing.
    Several of the combinations have been mentioned;
    - The firewall Jujak in a harris with Valeryia and a good gun ala Orc HMG
    - The spitfire Jujak in a kaplan harris, with a specialist kaplan and a CC model ala Lian kai
    I havent tried the Lt yet, since he is a little to obvious being at wip13. For lt I usually just go for the fusilier. In firefight, annihilation, decapitation I have tried out the guilang lt, with some medium success.
  5. Space Ranger
    Those are the missions I was thinking. Particularly Decap since the Lt. is known. Guilang is good but he can go down pretty easily.
    He can even be part of a good defensive haris like this. All he does it watch the back of the other two.
    KAPLAN MULTI Sniper Rifle / Pistol, CC Weapon. (1.5 | 29)
    HǍIDÀO (Multispectral Visor L2) MULTI Sniper Rifle ( ) / Breaker Pistol, CC Weapon. (1.5 | 33)
    JUJAK (Lieutenant) Combi Rifle, Heavy Flamethrower / Pistol, CC Weapon. (0 | 26)
    3 SWC | 88 Points
