What if Jammer's Isolation was persistant only in Jammer's ZoC
Tema en 'Access Guide to the Human Sphere' iniciado por eciu, 5 Jul 2019.
Etiquetas:
  1. Hecaton
    I suppose. Does it have Sixth Sense?
    A Wyrmnax le gusta esto.
  2. Wyrmnax
    Wyrmnax Well-Known Member
    4 Dic 2017
    SSlv2, smoke and camo. With MSV 1-2. And a SMG to keep it under 20 pts.
    A Ogid le gusta esto.
  3. Section9
    Which is funny, because I don't remember Jammers in N2. E/Marats and E/Maulers, sure. Mutts, yes. But I don't remember Jammers.
  4. Ogid
    Ogid Well-Known Member
    10 Sep 2018
    After looking at the other profiles, I'd expect more an irregular naked guy in a Wheelchair (terrible MOV, CC, BS, PH and ARM/BTS) with Frenzy, but with decent WIP, FD2, limited and ambush camo, a jammer and a knife and AVA 5. So you they cost like 3 points and you can deploy them in the good spots, plus an extra camo marker just for the lols.
    #184 Ogid, 1 Ago 2019
    Última edición: 1 Ago 2019
    A theradrussian y Abrilete les gusta esto.
  5. Hecaton
    Well, E/M weapons used to go through walls. So they gave Mutts this ridiculous suite of equipment for basically free, including smoke grenades, in the change-over, and never really took a serious look at the balance or play experience of it.
  6. Section9
    OK, now I follow you!
    A Hecaton le gusta esto.
  7. A Mão Esquerda
    Jammers dropped with C:P, with very similar characteristics.
    A Dragonstriker y theradrussian les gusta esto.
  8. Section9
    Huh.
    Says something about how often I saw them, then!
  9. A Mão Esquerda
    Could be. In fact, Mutts overall statline and performance remained static across editions.
  10. Alphz
    Alphz Kuang Shi Vet. Retired.
    25 Dic 2017
    Yeah ok, you baited me. Well done. It’s clear you really don’t want to add anything here. See ya.
    I fully expect they will get a jammer.
    A Mahtamori y AdmiralJCJF les gusta esto.
  11. Hecaton
    Statline, fine, performance, no. Giving them smoke grenades was a massive buff.
  12. ChoTimberwolf
    28 Nov 2017
    So reading through this thread I would say that my summary is that jammers are to cheap for an effective and pretty risk free weapon against any other unit in the game. I rarely play against jammers so got no personal opinion but as Tohaa I used Eraser a few times on the kriigel and that feels kind of strong while being on a 24/31 point unit and only effective against units with wounds
    A theradrussian, AdmiralJCJF y Abrilete les gusta esto.
  13. Armihaul
    Armihaul Well-Known Member
    I will add my experience with jammer, but from a tunguskan player. It works, is strong, is not so cheap, and are a lot of ways to deal with them
    Veterans laugh at them. Irregulars usually kill them easy. Stealthed troopers can pass through them or get to see then and do ftf rolls. Speculative is a viable option more times than some expect (once revealed can not go back to marker state).
    More than the weapon (which has been nerfed over the time), the problem is the platform is in, and what is needed in the faction.
  14. Hecaton
    How?
  15. Armihaul
    Sorry, double post
  16. Armihaul
    At the beggining was direct template that could ignore total cover
  17. Hecaton
    It affected the bearer, and didn't have an 8" range.
  18. Armihaul
    My bad . Wrote it wrong. Direct template. Afected more tha 1 tropper at once. Also, was E/M, but then their effecta were different
  19. theradrussian
    4 Ene 2018
    GOOD GRIEF THE LACK OF SELF-AWARENESS IS 40K ZEALOT LEVELS OF CRAZY
  20. Section9
    It's not troops classed as Veterans, it's units with the Veteran skill that laugh at Jammers. Very important difference!
    Now do me a favor and count how many units with the Veteran skill there are in YJ. Or JSA. Or even in PanO.
    There are ZERO units with the Veteran skill in YJ or JSA, and only Bolts in PanO. Frontoviks and VetKazaks in Ariadna. Zahyedan, Govads, Druze, and Al-Fasid in Haqq. Securitate in Nomads. No Shas, Umbra, Sygmaa, etc have the Veteran skill in Combined, it's just Morats. Shaki and Yadu in Aleph. Sukeul in Tohaa/Spiral
