Vaulting 'Over'
Discussion in '[Archived]: N4 Rules' started by spears, Mar 15, 2021.
  1. inane.imp
    To me they are intuitively the same concept. In every other case you can move infinitely divisible amounts along the direction of travel, the restriction is whether you can remain there.
    Clipping into terrain is something that's allowed in the rules. And clipping into the ground is basically irrelevant because it doesn't increase the positions covered by the SIL: it's only on external transitions (ie outside the right angle) that you increase the SIL and this matters.
    @Teslarod
    You vault the bit at the top, you don't measure it. ;)
    #61 inane.imp, Mar 25, 2021
  2. Teslarod
    You can't vault it, there's no obstacle involved.
    Obstacles would be something protruding from the surface you move on relative to your direction of Movement.
    At no point of your path do you ever move on anything that's not perfectly flat and unobstructed surface.
  3. ijw
    Why, though? People have been playing with 'warping' from one surface to another for multiple editions now.
    Dragonstriker and Teslarod like this.
  4. inane.imp
    Only for Climb where it gets the free movement.
    I've been poking my nose over the edge of the wall for all (most?) of last edition.
  5. inane.imp
    Then surely your SIL should be placed on that surface as much as possible?
  6. ijw
    No, not only for Climb. I've seen this for ladders and Climbing Plus across multiple metas and forums.
    With the Trooper staying on the wall?
  7. inane.imp
    Yes.
    I can't swear I've played it consistently like that. But I know that's how I intuitively wanted to measure it.
    I have a distinct memory of moving a C+ REM from one wall around a corner to another wall and poking the nose out and then snapping around once I'd cleared the first wall.
    Edit: The way I intuitively think of "treating the vertical terrain as horizontal" is like this:
    [​IMG][​IMG]
    It means that you can Move whatever distance forwards or backwards rather than having thresholds you need to reach before you start moving again.
    #67 inane.imp, Mar 25, 2021
  8. ijw
    Is that referring to the Trooper staying on the wall and peeking over the top? Because that was definitely not legal in N3.
    Dragonstriker likes this.
  9. inane.imp
    * ladder, not wall.
    Well damn. Apparently I flubbed the rules at least once or twice in N3.
    To me doing that made sense as the way to manage the transition between horizontal and vertical while Moving.
  10. inane.imp
    It does, however, appear to be legal as part of a Climb in N4?
    "For visualization purposes, Troopers using the Climb Skill move with at least half of their base’s underside in contact with the vertical surface."
    Or is this just a variant of the Squeezing rule but misses the errata text that's in Move?
    Edit: I really have no idea what purpose it's supposed to serve unless it allows hanging over the edge of things. Because that's the only time you'd need it "for visualisation purposes".
  11. ijw
    It's the equivalent of the 'squeezing' rule, added to the N3 text about the base going flat against the wall instead of the Trooper staying upright, hence 'for visualisation purposes'.
    From an editing point of view, I wanted all the 'squeezing' text to be moved into the General Movement Rules. :-(
    Nuada Airgetlam and inane.imp like this.
  12. Alpharious
    Alpharious Member
    By the way, what happens if the structure on the right is the edge of a game table, and not a drop, can you still squeeze through?
    Sent from my M2007J3SG using Tapatalk
  13. ijw
    Wouldn't that just be the standard diagram?
    Dragonstriker, inane.imp and Teslarod like this.
  14. Alpharious
    Alpharious Member
    Yeah, I thought so as well, but I remembered how someone told me that the edge of the game table is somehow not a "wall", and that i can't do that.
  15. inane.imp
    There's no restrictions on what blocks the path, just that the only way to proceed along the path is with only half the base supported.
    ijw likes this.
  16. ijw
    This. The actual rue doesn't specify what's making the surface too narrow.
