Updated Total Immunity
Tema en '[Archived]: N3 Rules' iniciado por Cannon Fodder, 27 Mar 2019.
  1. tox
    21 Feb 2017
    Kitsune has the advantage of picking out his target. Maybe just avoid Total Immunity ones?
  2. Zewrath
    Zewrath Elitist Jerk
    28 Nov 2017
    1 save. E/M is treated as normal ammo.
    A emperorsaistone le gusta esto.
  3. Mahtamori
    Total Immunity ignores the effects of a Special Ammo. Damage value of 12 is an effect of Monofilament. Which is ignored.
    Shinobu attacking Sun Tze with Martial Arts 2 will be hitting at CC25 and DAM of 16 if using the Monofilament blade. This is better than Knife, although a Knife would still have Silent.
    A The Red Duke, Tom McTrouble y toadchild les gusta esto.
  4. Teslarod
    Normal Ammunition always causes one ARM roll.
    Which a Total Immunity Trooper could roll BTS against.
    Note that you can decide not to use Total Immunity in case you don't want to risk taking damage from E/M or something like that.
    Normal Ammunition's crit effect always does one damage. A Zayedan Breaker doesn't hit a Dog with Breaker+Shock, but with Normal and nothing else.
    Just out of curiosity - What for? +1 DAM over Barehanded in case you don't want to kill something that is also Shock immune?
  5. Zewrath
    28 Nov 2017
    Killing people CC with Silent Trait.
  6. daszul
    daszul Well-Known Member
    11 Oct 2018
    Oh, I see, you not only treat the damage as N, but the whole weapon as being an ordinary CCW.
    I see your point, but that is not what Total Immunity says.
    The rules are only about the ammunition type, not the damage value.
    What happens with K1 ammunition?
    If it is the same damage, then I prefer silent to non-silent.
  7. Barrogh
    Barrogh Well-Known Member
    26 Nov 2017
    I've probably missed something again, what about crits?
    Do we still consider it a hit with ammo type that calls for ARM / BTS roll, and therefore trigger TI and count it as Normal ammo crit?
    If not, what happens when you crit with something that causes several saves (one of which will not roll for ARM / BTS)?
    Nevermind, found it.
  8. ijw
    25 Abr 2017
    The weapon itself has a Damage value, unlike other CCWs that have DAM = PH.
    A The Red Duke, toadchild y chromedog les gusta esto.
  9. Mahtamori
    That's redundant and kind of dumb, but okay.
  10. daszul
    11 Oct 2018
    So.... Monofilament becomes Damage 12 Ammo N.
    What happens if you crit with Monofilament?
    Does the phrase '...bypassing the usual ARM Roll.' negate the application of TI?
    What happens to K1?
    There the damage is an ammunitions-effect and gets negated,
    so you use the damage that kind of weapon usually does,
    right?
  11. ijw
    25 Abr 2017
    http://infinitythewiki.com/en/Immunity#Total_Immunity_and_Critical_hits
    It's a crit with Normal ammo.
    For it to work the way you said, Total Immunity would need to specifically mention CCWs and say that they all become standard CCWs, instead of simply changing the ammo type.
    A chromedog le gusta esto.
  12. Mahtamori
    That's not at all correct and very nitpicky. Monofilament specifically states the damage value for the weapon, all that would be required would be for the Monofilament CCW to have it's damage value derived from the ammunition type.
    The damage value of Monofolament weapons (regardless of whether they are CCW or not) could until now have been listed as * and it wouldn't have made a difference.
    A The Red Duke le gusta esto.
  13. Gunmage
    Gunmage General Contact Unit
    4 Dic 2017
    I'd say "any ARM or BTS Rolls" does include unusual ARM rolls.
  14. ijw
    25 Abr 2017
    That would result in a Monofilament CCW not having a Damage value when used against Total Immunity.
  15. Barrogh
    26 Nov 2017
    I'd say it would be better if DAM was just directly written down in a weapon profile, just like it is with any other ammo type.
  16. spears
    spears Well-Known Member
    30 Nov 2017
    So can skills such as martial arts buff the damage of a mono weapon turned normal?
  17. daszul
    11 Oct 2018
    Guess not, as MA only affects damage values derived from PH attribute.
  18. Mahtamori
    1. Not a month ago.
    2. Not if Monofilament CCWs had PH as DAM value on their weapon entry.
    3. This is still a pointless line of argument.
    It is written down. And that's what IJW reminded me of. Prior to these changes I took that as simply a reminder of what the Monofilament rule stated.
  19. RobertShepherd
    2 Ene 2018
    If a model with Total Immunity takes a hit from an AP+DA, or AP+Shock, or Shock+Breaker weapon, does total immunity turn those hits into one ARM roll, or two?
  20. A Mão Esquerda
    It ignores all special effects, it’s a single ARM/BTS roll, which ever is more advantageous to the user.
    A RobertShepherd le gusta esto.
