Targeting with Maximus Switch
Tema en 'Rules' iniciado por Eightballz, 5 Mar 2018.
  1. Eightballz
    Eightballz Well-Known Member
    3 Mar 2018
    How should I understand the targeting in the switch?
    Maximus has two switches. Once the general "Impose the Taunted State to the Target."
    and also the switch in "Jotum's Shield": Displace the Target.
    With Jotum's Shield, I'm pretty sure that Target is just the target of the attack. But which target is meant in the general switch? If I defend or disengage, can I then defeat each opponent with the Taunt, or only the one with whom I make a comparative throw? In an attack, the target would make sense. But in a comparative throw? Does Maximus then only have the chance to taunt the targets he holds, attacks or defends? This then reduces the benefit of the switch enormously.
  2. -V-
    -V- A! Team member
    31 Ene 2017
    The target of the general Switch is the character against you are making a face to face Roll.
    • When you make a :W:Defense Roll, your Attacker.
    • When you perform an Attack, your current Target. Not only Jotum Shield, you could perform a Contender to :H:Taunt :L:1-8.
    • When making a Disengage Roll. You may even leave scape your target to use a :1::3:to :H:Taunt them.
    • When making a Disengage Roll you could add any dice to your :8: so you can :H:Taunt the enemy who is trying helplessly to engage you.
    Which other way of using were you thinking about?
    :thinking_face:
    A Roadrunner7431 y Eightballz les gusta esto.
  3. Eightballz
    3 Mar 2018
    Thx for your answer!
    I totally forgot the last one. Thats not bad.
    I hoped there would be a possibility to taunt someone, i am not fighting with. Something like an active taunt. The attack is strong enough in itself. If Maximus could taunt another target it would be great - and maybe too strong :D
  4. -V-
    -V- A! Team member
    31 Ene 2017
    You'll find that in Massacre.
    :wink:
    A Eightballz y Roadrunner7431 les gusta esto.
