    Dismiss Notice
TAK buying advice
Discussion in 'Ariadna' started by MattyG2787, Oct 26, 2019.
  1. MattyG2787
    MattyG2787 Member
    Hey everyone. I’ve ordered the cold front Black Friday box but now I’m working out where to go next.
    I know I need tank hunters, streloks (both bsg and k9 versions)
    What else should I be buying first?
  2. Hecaton
    For your early games, I'd suggest the line kazaks box, and also every vet kazak sculpt you can buy.
  3. cazboab
    cazboab Member (phrasing)
    The 112 and Dozer are pretty good bets, you might not use them as often as say the veteran kazak, but they're good utility profiles and you'll have them on standby for vanilla and other sectorials.
    Frontoviks and line kazaks will let you put support behind a Veteran Kazak for your link team.
    TAK is one of the sectorials where there are few if any junk models that won't see use. Voronin is the closest thing, and even then his sensor profile is occasionally useful for dealing with ODD, and since he screams 'Lieutenant' he's pretty good for some chain of comand shenanigans, or even just baiting an alpha strike into multiple AROs.
  4. nakar
    nakar New Member
    I started some time ago with TAK and the most useful things I bought after the both Coldfront Boxes are:
    Line Kazak Box
    Veteran Kazak with HMG
    Irmandhios
    Kazak Spetsnaz Box (actually I just use the HMG one so far)
  5. McKaptain
    McKaptain Well-Known Member
    The boarding shotgun Spetsnaz can be used as a strelok BS/minelayer proxy.
    mipevo6 likes this.
  6. barakiel
    Good input so far.
    I don't know how much about your list preferences, but I immediately went out and got a 4 Line Kazak. You can can always proxy a 4th one, but I find that having ~4 rifles works well with my listbuilding.
    Eventually you'll want Antipodes. They're a big chunk of cash for a mere 25 point unit, but I think they'll find a home in all your lists.
  7. holycannoli
    I didn't start with just coldfront, having the rushkies before we were a sectoral. So I peiced together an army. But breaking down what I use and what I come in. The frontivik or beyond coldfront is a great box to buy. If you can find an APHMG septznaz blister get that, or the Vet Kazak blister. These are the units that have become my TAK bread and butter. I'll explain what they do, and why, and hopefully make sure you get some enjoyment out of your hard earned cash.
    Frontiviks can fill out points that your dirt cheap line kazaks just can't. On top of that is for those extra points you get a considerable upgrade. Memetism, T2, humble vs the vet or the spetznaz but they can really do work and can seem humble until someone gets red pasted. These guys feel like badasses compared to your dull as dishwater line kazak. That and their loadouts of the MSV sniper or the HRL are fantastic. That or run the engie profile for a specialist. Their link options are fantastic and the vet/frontivik link is a wonderful core for a list to run around if you like offensive core links.
    I'd also put beyond coldfront here if you have someone to split it with. I've found myself using all 3 of the minis frequently. Strelok: cheap in pts and super useful (especially to bulk out the camo tokens we put on the table) Vasili, wonderful for hitting power, camo presence, and utlilty, and hey look a frontovik a midtier, mid point problem solver. If you absolutely most WYSIWYG then you have a 2nd rifle frontivik to bulk out your links and lists.
    Vets... oh the vets. I've ranted in plenty of threads how I love vets. Cold Front has the rifle, but the APHMG vet is the Chad of the army. The APHMG vet feels like an absolute monster. You can't surprise him, you can't smoke+MSV him, you must fight him and fighting him head on is not for the feint of heart. In suppressible or active he is an absolute menace and makes it into most of my lists. If you feel comfortable going big and bold with a LT. the APHMG LT has made a mess of people during the 3rd turn all or nothing brawl. As a benefit, learn what vet level 2 means and you pretty much know his gimmick. He's a direct gunfighter and a great one at that, his strengths aren't only his rock solid statline but the fact that he removes tricks from your opponet rather then having too many himself. Easy to learn, yet great mileage. This guy is TAK in beast mode and makes the other sectoral's HI choices red with envy. This absolute unit is what Minutemen, Moblots, and other sectoral's HI wish they could be. So to say he's worth a blister is an understatement. It also lets you paint your coldfront vet as a Medic with a white helmet or shoulderpad. Two incredible loadouts, I bought multiple copies to convert I love them that much.
    APHMG Spetznaz. I say the blister because if you're really stretching your TAK roubles, and you had to pick 1 spetznaz, go with the APHMG. This was the Kamaru before the Kamaru, the camo token that spells death and despair to the enemies of TAK. In more tight knight communities this miniature will teach your opponents to fear the camo token. As you can probably tell him and the vet are two heavy hitters that come in a blister. These guys can rack up a lot of meat and are some of the people that really do work. If you're not absolutely stretching your dollar then go for the box, while the sniper may collect dust the shotgun spetznaz is the reason I started TAK specifically even before the sectoral. He's an absolute riot to run as for not too many points you'll annihilate line infantry link teams and cause havoc. Yet again in tighter knit communities you'll find your opponents counting your orders, and watching the sides of the map... Ivan is lurking.
    Shout out to the doggos too. Antipode assault pack, Dog warrior. Both are expensive but they're very interesting units. The assault pack is difficult to decode the rules for. But once you do you'll have a wonderful fur covered missile to launch at your poppet. 25 points for a regular order, irregular order, smoke launcher and a single use melee mauling. They show up in many lists besides Limited Insertions because 25 pts eats up 2 of my 10 orders. Dog warriors are also a very fun unit. Expensive box, but you'll find him the bully of the field, a real thorn in your opponent's side.
    Have fun Comrade.
    Tanan likes this.
  8. Tanan
    Tanan Member
    Another vote for the antipode pack. I own two and I rarely make a list both aren’t included. Even in limited insertion lists.
    They are a tricky unit to master, but will win games if used properly.
  9. MattyG2787
    MattyG2787 Member
    Thanks for all of the advice guys.
    Ended up grabbing the coldfront Black Friday box along with
    Vet with hmg
    Dog pack
    Strelok with dog
    Spetnaz box
    Tank hunter pack
    Carmen and batard
  10. Bellyflop
    Bellyflop Well-Known Member
    You should pick up the Line Kazak box, and 2 to 4 Irmandinhos. Personally when I use 4 Irmandinhos (which is most lists) I put two in each combat group. So I use 2 actual Irmandinhos and 2 Chasseurs to proxy as Irmandinhos to easily see who is in which group.
    But seriously, use 4 Irmandinhos.
    barakiel likes this.
  11. barakiel
    I agree with @Bellyflop
    That cheap stuff is what will make it into every list. I'm only a few months into TAK, but 3+ Irmandinhos, 4+ Line Kazaks, and Dozer + two Minesweeper Mules have seen more combat than any other unit. They're the kind of selections that make me wish the Army Builder could auto-load units when I build la new list.
    Bellyflop likes this.
  12. MattyG2787
    MattyG2787 Member
    I fully intend to get those pieces in my next order. 24 points for 3 regular orders is good value (war driver and 2 mine sweepers)
    irmandihos aren’t far behind
  13. Tanan
    Tanan Member
    Never understood why people think that Irmandihos are good. 8 point models that don’t generate regular Orders and require a lot of babysitting.
  14. Bellyflop
    Have you put them on the table? It is 8 points for a specialist with smoke who doesn't need regular orders from your pool to push buttons. They babysit themselves, as the back one goes first and throws smoke on the front one, who then runs up and pushes buttons.
    They are insanely efficient models. When they aren't pushing buttons, they can also smoke the lanes for your antipodes to run across the board. They also have CC20 and D-charges, and Booty for more random fun. They are also PHY14!!!! So they throw smoke on 17s!
    Spam them in TAK and you wont go back.
    #14 Bellyflop, Nov 17, 2019
  15. Tanan
    Tanan Member
    Haven’t run them myself, but I have killed a lot of similar models. Single wound models doing single die f2f rolls is too swingy for me. I definitely see value in smoke, but you already have (skill 14) smoke from antipode pack controller.
    I’m curious, what missions do you use them to push buttons? If anything, most missions reward conservative approach where you preserve your forces and make a mad dash to the mission area during your last turn.
  16. Bellyflop
    You dont face to face the smoke, you throw it near a corner then walk through it. An antipode pack costs 25 points, or 1 more point than 3 Irmandinhos.
    I use them to push buttons in every mission with a button. They have 2 orders to get stuff done before regular orders. You can always reflip buttons using camo specialists if needed on turn 3. The Irmandinhos are so good at doing the mission you can spend all your other orders on killing. They run to the middle, push buttons, and if they die after it was 8 points.
  17. MattyG2787
    MattyG2787 Member
    It’s 8 points for 2 orders to throw smoke. The regular order from the handler could be used for many other things (like feeding the dogs)
  18. Tanan
    Tanan Member
    Irregular orders don’t exactly help your other models in the killing business. 9 point model that generates a regular order does.
    My experience is that extremely impetuous models are really easy to lure into killzone, where they get put down. Perhaps with 4 you could create a somewhat controllable group of models if the enemy doesn’t have a MSV2+.
    I also somewhat puzzled why antipode pack gets compared to Irmandihos. Yes, they both have access to smoke grenades, but they are completely different units in every other way.
  19. Reservup
    Reservup Active Member
    Ahhh, I see your line of reasoning, and I will concede that irregular models don't assist in feeding orders to your attack pieces, but it's often the case that you can win games without killing very many of the opponent's models at all. You win by focusing on the mission.
    Irmandhinos are extremely good at doing that because their utility and ability to complete a vast array of classifieds. They are specialists, they are cheap, they are dogged, they are good DZ guards, they have D-charges, they have smoke, they have booty.
    Yes they can be picked apart by a dedicated ARO turret, like the Kamau for example, but that comes down to your deployment more than anything else. There's nothing in TAK that can go head on with something like a Kamau and reliably win. So we go about things tactically. And Irmandhinos give you a lot of scope for tactics.
    Take what I say with a grain of salt of course, but I think you'll find that the vast majority of extremely experienced and skilled players (all far better than myself) highly rate Irmandhinos.
    I've been playing with Kuang Shi, monks, Irmandhinos, and dog warriors for years now. I can promise you that extremely impetuous is absolutely manageable. It just takes practice.
    I know @barakiel has been playing TAK lately, and I typically find his analysis of units very informative and accurate. I'd love for him to chime in.
  20. Tongfa
    Tongfa proudly selling out since 1991
    the vet kazak be like 'marker state is for bitches'
    McKaptain likes this.
