Suppressive Fire via Command Token-Best Units
Tema en 'Access Guide to the Human Sphere' iniciado por Pflaumenmus, 23 Oct 2020.
  1. Iver
    Iver Human Plus
    3 Feb 2018
    I cede my argument. The puppetmaster and his bots are absolutely the best unit for this.
  2. Teslarod
    Depends on if you ever want to spend an Order on them for Specialist duty. Nomads don't really need Puppets to cover their button pushing, moving 3 Puppets up into the midfield for a bit of killing followed by putting them back into SF in annoying positions for a single Regular Order? Yes please, let the Zero push the button.
    DTW, Flashpulse and Specialist isn't a bad use for them, but other things can do that and nothing else gets the same value as defensive turrets. In the right situation the BSG/Flash Pulse can be better, is a Specialist and 2 points cheaper. So as with most things it just depends what situation you expect to run into as the most common.
    Personally I don't expect to use them again after getting in position, or potentially never spend an Order on them when going second.
