Strategies for Prone models on Buildings
Discussion in 'Access Guide to the Human Sphere' started by RogueJello, Apr 8, 2018.
  1. Hecaton
  2. daboarder
    Didnt realise when you played a TAG it was the only thing on the table.
    Also you cant Cautious move in ZOC, so thats a fairly large chunk of the board the TAG player decided to stick its back too under your interpretation, doubt a sensible player does that
  3. Solar
    Solar Well-Known Member
    I engage TAGs in suppression within 24" all the time. MSV2 and smoke, killed a Tikbalang with an Intruder LT over 3 orders once. It was hitting on... 3s? And I was on 13s because I flanked it. Worth it.
  4. Barrogh
    Barrogh Well-Known Member
    You actually can if you have Stealth, which everyone with CC mainstay skills (MA, NBW, Protheion) has.
    oldGregg likes this.
  5. Hecaton
    That's more or less what this thread is about.
    What is stealth
    I mentioned a Samaritan specifically...
  6. daboarder
    Without going into the actual details it sounds like there were a large number of factors that presumably let you strip cover, roll well, and obtain multiple surprise shots on a single TAG. A light TAG it should be noted.
    Honestly sounds more like your opponent misplayed more than anything. because doing a presumed 5 wounds to a TAG that fights Back at B3 and is ARM6 in each order isnt a small taskj even if you have
    Flanked its cover, Smoked It, Managed to bring the MSV2 and the HMG....
    RogueJello likes this.
  7. daboarder
    yeah i missed that samaritans have stealth.
    Why though does everyone always assume that the TAG is on its own, any isolated troop will die in this game.
  8. Hecaton
    Because the OP and others are presuming a scenario where you have TAGs operating on their own with a bunch of cheerleaders in a building. I agree, suboptimal.
  9. Nenyx
    Nenyx Well-Known Member
    Suppressive fire may be a trap too. Range modifier is one of the most important modifier in fights, and from the moment you count on suppressive you relinquish it. Between 40 and 60 cm you are at -3 instead of the +3 you would have with single shoot HMG. It's as if you were granting your opponent a free, cumulative ODD. With that -3, you can easily obtain a -12 (cover + TO/ODD, or cover + surprise shot + CH, or cover + msv2/smoke). Thus the TAG may have burst 3, but at 3 to hit, instead of 9 if he would go single hit. Suppressive fire is not only weak past 60 cm, it is also weak between 40 and 60.
    This is true for all suppressive fire, the best way to fight them is not always to try and find an oppening past 60 cm, but simply to stack modifiers as usual.
  10. Solar
    Because like I said, TAGs are easy to kill, you have to get through the defensive perimeter. Which I did!
  11. daboarder
    So everything is easy to kill is your argument
  12. Hecaton
    I'd agree with that. Everything without Symbiomates.
  13. Nenyx
    It's easier to kill a single TAG than the same price of a bunch of cheap warbands or camos. Of course it will cost several orders, but not more than having to search and kill many cheap troops. The problem is not "is it hard to kill ?" but "can i afford spending ressources to kill that thing, is it worth it ?"
  14. Solar
    My argument is that TAGs are good because of their active turn killing capabilities, and reactively they're vulnerable. They're not unique in this regard, but due to their cost and significance in the list, their loss is a nasty blow, so you need to protect and support them with a screen of other troops.
    Suppression Fire is a nice boost, but won't keep them alive. Proper assistance from the rest of the force will.
    #134 Solar, Apr 16, 2018
  15. sarf
    sarf Well-Known Member
    Well I`ll shoot a Pitcher to some point near TAG and force to choose between drop SF or receive normal hack attack.
    But I`ve found really hard to kill TAG in cover with HMG or something weaker. Kriza HMG can pretty reliably overshoot TAG but it require a lot of orders to deliver enough wounds. So in my case unless it`s Feuerbach, HRMC or linked ML/PF, no good on direct attack. Should be some E/M, ADHL or Possession/Ejection tricks. I`m looking forward to AP HMG on O-Yoroi in my future JSA army as a brute force solution.
  16. RogueJello
    RogueJello Well-Known Member
    And with all that the TAG could have presumably failed the first two guts checks, and perhaps gotten into full cover. Finding a good parking spot for a TAG also includes good places to fall back if your opponent brings something suitably nasty.
    daboarder likes this.
  17. loricus
    loricus Satellite Druid
    WB and spam are easier to kill than TAGs if you do it on their turn.
  18. Section9
    Because this entire thread is about how to kill a pair of TAGs that have pretty much the entire rest of their order pool hiding. Well, OK, more like 6/8 of their order pool hiding, and the other 2 models are competent in ARO.
    Pic of the table is back on page 5:
    Here's the list.
    Opponent was running JSA, 4 bikers, Yojimbo, 5 man link team, doctor, Oniwaban, 3 Ryuken.
    Space Ghost likes this.
  19. loricus
    Ouch, bikers would have a tough time around 2 TAGs.
  20. Section9
    Yeah, does seem to be an odd choice of list for a Direct Action tournament. I mean, I'd be expecting to face either Dual TAGs or TAG+HI Link lists, and neither one is easy to face with bikes.
    Without seeing the list, I'm expecting 2 Spitfires and 2 hackers in the bikes, HMG and ML in the link team. Not sure why the Oniwaban didn't make a play for one of the TAGs, either. I mean, that's basically what an Oniwaban is for!
    My guess on the list is this:
    [​IMG] Japanese Secessionist Army
    GROUP 1[​IMG] [​IMG] [​IMG]9 [​IMG]1 [​IMG]5
    [​IMG] ARAGOTO Spitfire / Pistol, Knife. (1 | 26)
    [​IMG] ARAGOTO Combi Rifle + Light Shotgun / Pistol, Knife. (0 | 22)
    [​IMG] ARAGOTO (Killer Hacking Device) Combi Rifle + Light Shotgun / Pistol, Knife. (0 | 25)
    [​IMG] YOJIMBO Contender, Nanopulser, Smoke Grenades, CrazyKoalas (2) / Pistol, DA CCW. (0 | 21)
    [​IMG] KEISOTSU HMG / Pistol, Knife. (1 | 17)
    [​IMG] KEISOTSU Missile Launcher / Pistol, Knife. (1.5 | 14)
    [​IMG] KEISOTSU Combi Rifle / Pistol, Knife. (0 | 9)
    [​IMG] KEISOTSU Lieutenant Combi Rifle / Pistol, Knife. (1 | 9)
    GROUP 2[​IMG] [​IMG] [​IMG]5
    [​IMG] TOKUSETSU EISEI Doctor (MediKit) Combi Rifle / Pistol, Knife. (0 | 14)
    [​IMG] ONIWABAN Submachine Gun, Nanopulser / Pistol, Monofilament CCW. (0 | 37)
    [​IMG] RYŪKEN (Forward Deployment L2, ODD) Submachine Gun, Antipersonnel Mines, D-Charges / 2 Breaker Pistol, Knife. (0.5 | 24)
    6 SWC | 300 Points
    Space Ghost and Abrilete like this.
