StarCo Lieutenant?
Tema en 'StarCo' iniciado por DaRedOne, 22 Mar 2018.
Etiquetas:
  1. Armihaul
    Armihaul Well-Known Member
    Core of 2 riot with Emily and haris of 2 riots with avicena... And a brawler lieutenant duo with any specialist can be worth a try
    A DaRedOne le gusta esto.
  2. Death
    Death Well-Known Member
    28 Nov 2017
    I think I prefer a haris with Brawler MSV 2. You got plenty of smoke to take advantage of with Jaguars, might as well make use of it.
  3. Raghart
    Raghart Well-Known Member
    Face It. BEST thing about Emily chain of Command is her grenade Launcher.
    At high points games i would use her with linked mobile brigada lt. Any other time, Brawler is my Guy. Or gal. Or something.
    A Kahlain, Wyrmnax y inane.imp les gusta esto.
  4. Leviathan
    Leviathan Hungry Caliban
    6 Feb 2018
    Brawler MSR + Brawler Haris + Brawler LT shouldn't be too expensive and be fairly safe. :)
  5. DaRedOne
    Yup. This seems to be the consensus and I agree. Gonna try some lists out sometime next week and talk about the results later!
  6. inane.imp
    28 Ene 2018
    CoC is an irrelevant tax on an already stupidly broken profile that may occasionally come up in game. I wouldn’t bother List building around it.
    A DukeofEarl le gusta esto.
  7. sarf
    sarf Well-Known Member
    Broken good or broken useless?
  8. xagroth
    Spec Fire E/M grenades at 13-16 up to half a table, at the cost of not linking Avicenna with 4 Riot Grrrrls! and hiding the other four until you ended raining Isolation and possibly IMM2 (that last one to HI/TAGs). It's like the coming back of the Guided Missile storm from N2 XD
  9. Armihaul
    Yesterday tryed for the first time Emily and her light grenade launcher at 10s (13+3 from link-3 from range-6 from speculative fire). Not worth it, too much orders to do something that can be evaded on a -3 fis. But her is good. Her mimetism and BS13 makes her a hard hitter, even if her cost is high.
    The problem is getting a good lieutenant with her. Maybe a brawler in a haris with also a MSR, but that leave outside the riot haris (wich is so good with avicena)
  10. sarf
    13+3+3-6=13, fix your math)))
    or 13+3-3-6=7
  11. Armihaul
    I forgot to add that the -3 to range become 0 due x-visor. My bad.
  12. Death
    28 Nov 2017
    You can do the same thing with a much cheaper Alguaciles link. Then you can take a Riot Grrls Haris for some aggression.
    A xagroth y DukeofEarl les gusta esto.
  13. Leviathan
    6 Feb 2018
    Emily+Alguaciles Core, Riot Grrl Haris? As far as points go there should be room for both.
  14. xagroth
    Yes but different purposes. Emily + Riots = advance, lob some grenades, fry with Spitifre. ARO risk can be done aswell, thanks to the ML and the blitzens. Plus they have "close combat" capabilities thanks to the stun grenades XD
    Alguaciles + Emily = either hide the alguaciles to make Emily a rambo, or risk them on ARO.
    Frankly, I would go with Brigadas + Daktari + Massacre and Avicenna + Haris riot + Spitfire Riot for full Blitzkrieg. Emily with Alguaciles is so... "I can do it on Bakunin, to an extent", while the BRASS (BRutal Armor aSSault) is not :p
  15. Leviathan
    6 Feb 2018
    At the moment I'm also looking at the Emily+Uhahu duo, as well. Uhahu is so fragile/non-combat that I feel like she needs an escort, and this is in lists where I'm pushing lots of stuff like Hellcats and Bandits so I don't have room for HI fireteams and instead have a bunch of Duos and a Haris.
    A McNamara le gusta esto.
  16. Hecaton
    How is Uhahu fragile? She's tougher than Handleman.
  17. loricus
    loricus Satellite Druid
    I like CoC so I can take the Brigada Lt. in the Anaconda Duo.
    Corregidor doesn't get anything fancy. Just the only Dog Warrior outside Ariadna, literally the best unlinked cheerleader and Infiltrating repeaters. Drop Doctors. Almost everyone with either ADH, E/M or DTW sidearms. Token State MSV2. Just the basics really.
    A Golem2God y inane.imp les gusta esto.
  18. Armihaul
    She is easier to wound, she has BS11 but Emily has 13, mimetism and weapons with longer range
  19. DukeofEarl
    DukeofEarl Well-Known Member
    27 Nov 2017
    Interesting. I'm finding it hard to even think about taking anything other than the Tinbot MB in the Duo.Just too much value for the Anaconda and it is hard to remove
  20. loricus
    I'm playing a lot of Gecko Duos and being able to cover flanks or target people at close range with the MULTI weapon and extra order prevents more problems than the Tinbot would. But that could be meta dependant. I know some people are saying Assault Hacking Devices are becoming uncommon for them.
