Speculative fire + smoke = attack?
Discussion in '[Archived]: N3 Rules' started by gorin, Oct 24, 2018.
  1. gorin
    gorin Well-Known Member
    Unit 1 in smokes. He make speculative fire with another smoke and affects Unit 2.
    Does Unit 2 ARO BS attack is legal?
    Clues
    1. Zero Visibility Zone
    • Any trooper who is the target of a BS Attack into or out of a Zero Visibility Zone, or whose LoF traverses a Zero Visibility Zone, may respond to the attacker even without LoF, provided the trooper is facing the attacker.
    2. SPECULATIVE FIRE - ENTIRE ORDER
    Attack.
    REQUIREMENTS
    The user must employ a BS Weapon with the Speculative Fire Trait.
    3. Smoke and Speculative Fire
    Certain weapons that use Smoke Special Ammunition allow the user to use the Speculative Fire Common Skill. In that case, the Common Skill Speculative Fire works normally, even though it is a Special Dodge and not an Attack.
    works normally - like normal speculative fire? So, its an Attack? But if it is, can you speculattive fire with smoke on another your trooper? Because
    • Attack. The use of this Skill is a form of Attack. Remember that you cannot declare attacks against allies or Neutral units, whether represented by figures or Markers.
  2. DukeofEarl
    DukeofEarl Well-Known Member
    Yes at -6 unless they have SSL2.
  3. solkan
    solkan Well-Known Member
    A BS attack firing Smoke is still an attack. What gives you permission to include friendly models in the area of effect is (at least in part) the FAQ saying that not causing damage makes it okay:
    Q: Can weapons with the Impact Template Trait and no value in the damage attribute be fired with allied troopes in their area of effect? For example, a Smoke Grenade, an Eclipse Grenade or a Nimbus Grenade.
    A: Yes.
  4. CabalTrainee
    @ijw Said differently in this thread: https://forum.corvusbelli.com/threads/hvt-and-smoke.24760/
    Or over here: https://forum.corvusbelli.com/threads/smoke-and-sixth-sense.23551/page-2#post-109541
    I'm confused.
  5. Hecaton
    No shit. Just ignore what he said and treat it as an Attack that just doesn't deal damage and you'll be good.
    CabalTrainee likes this.
  6. ijw
    Straight quote from the rules:
    marful likes this.
  7. Hecaton
    @ijw And that's exactly what you'd expect to see if there was a statement where they had clearly stated "this is not an attack," backtracked on it, and then left that "even though it is..." phrase in there due to poor proofreading.
  8. ijw
    Do you have something productive to contribute to the conversation?
    paraelix and A Mão Esquerda like this.
  9. Mask
    Mask Well-Known Member
    Do you have an answer rather than the usual "quote"?
  10. ijw
    Smoke doesn't work consistently if it has the Attack label. It does work consistently if it doesn't have the label. So why not take the usual "quote" at face value? Especially when discussing the exact situation (Speculative Fire and Smoke ammo) that the quote applies to.
    inane.imp and A Mão Esquerda like this.
  11. Hecaton
    Yes it does. That's the whole point. It works just as well as a Pitcher or what have you.
  12. Mask
    Because I'm dumb and I often need a deeper explanation. Copy paste a part of the wiki could not be a solution sometimes... Maybe we've already read it before but the doubt remain. (language barrier is a thing for someone). A well written answer promote a clear and well argumented communication.
  13. ijw
    Ah, sorry, I thought you'd read the linked threads!
    Commoner1 and A Mão Esquerda like this.
