Spec Ops private info
Discussion in '[Archived]: N3 Rules' started by Dr. Nik, Jun 25, 2019.
  1. Dr. Nik
    Dr. Nik Well-Known Member
    Hello.
    So for example we have a spec ops in Holoprojector - do we still need to have him in the open list? Do we need to let opponent know what loadout he has? Do we need to show which figure it is?
  2. meikyoushisui
    No. The Holo1 unit will appear on your list as any model it can Holo1 as. The actual statline and abilities of the unit in the Holo1 state are Private Information. See the example in the Holo1 rules: http://infinitythewiki.com/en/Holoprojector#Holoprojector_L1_and_Private_Information_Example:
    And the big yellow remember box:
    REMEMBER
    The presence of troopers in Holoprojector L1 state is considered Private Information. This also includes the Special Skills they have and their weapons and pieces of Equipment, too.
    However, in Holoprojector L1 state the Hackable Characteristic is considered Open Information when the trooper is inside the Hacking Area of an enemy.
  3. Dr. Nik
    The problem is army builder put him on the open list.
  4. colbrook
    Delete him from your list and add whatever you want to Holoproject as, then reprint the courtesy list.
    Remember, a courtesy list is just a handy list of the open information of the models you have on the table at the end of your deployment.
    Xeurian, WarHound and meikyoushisui like this.
  5. Diphoration
    Diphoration Well-Known Member
    Be careful doing that, the courtesy list will only be accurate if the model it represents is of the same training.
    Manually updating the list for courtesy will never work to mimic holoprojector 2.
    Holoprojector does not hide the orders generated.
  6. colbrook
    Order count doesn't happen until the start of your Active turn so the orders printed on the courtesy list shouldn't be taken as gospel anyway, especially when you can do things like deploy a TO unit as a marker or choose not to use AD which can give a different order count to the printed one even when you go first.
    meikyoushisui likes this.
  7. Diphoration
    It would still be knowingly giving wrong information to your opponent.
    If you had a holo2 who was represented by 3 regular troopers (because you manually made the list). If you had 2 TO units in that group, your opponent would still see 10 orders in the courtesy list when they should normally see 8 (as it is normally shown when using the menu and adding in holoechoes)
  8. colbrook
    My point is that they shouldn't really see any orders on the courtesy list, because those orders aren't generated until the start of the player's Active turn.
    BLOODGOD and meikyoushisui like this.
  9. Diphoration
    But they do. That’s how the courtesy is programmed and printed. That’s how your opponent is expecting the information.
    Purposefully altering that information and gaining an advantage because of it is cheating.
  10. Diphoration
    I am of the opinion that no information regarding the orders should be on the courtesy list, but that’s what we have right now.
    Ogid and meikyoushisui like this.
  11. Diphoration
    Also, the holoprojector is working on my browser. I am getting the selection menu when I click on courtesy list. Make sure you do not have a add-on blocking the pop-up!
    inane.imp and Ogid like this.
  12. meikyoushisui
    I am seconding this. My opponent doesn't know the size of my order pool until I count my orders (see - Holo2).
  13. Sabin76
    Thirded.
  14. Ogid
    Ogid Well-Known Member
    I also add my voice to the no order in the courtesy list movement.
    Just tried and yep, for me is also working as intended
  15. Mahtamori
    There is a long standing issue with the courtesy lists providing information it shouldn't since it doesn't handle Hidden Deployment and Holoprojector 1 and 2 correctly.
    You are required to hand over a courtesy list to your opponent that accurately represents the open information your opponent is entitled to. If your courtesy list shows too few orders because Army doesn't handle Holoecho 2 correctly, it doesn't matter that you printed it using Army, you're still providing your opponent with an inaccurate courtesy list.
  16. Bobman
    Bobman MERC
    Holo works on normal units but not if you add to spec Ops. Or at least that was the case.
  17. Mahtamori
    Nah, it's broken on normal units as well. I'll attach the printout for a list with a Single Lu Duan that's disguised as two Yojimbo.
    a) It's showing 1 Regular Order instead of the expected 2 Irregular + 2 Extreme Impetuous
    b) It allows me to make a Holo2 into two units when the only valid options are either 1 unit (Holo1) or 3 units (Holo1 + Holo2)
    c) It allows me to add Yojimbo without Mercs being enabled
    Ergo, you still have to handle Holo manually.
  18. colbrook
    Though it could be argued that because your number and type of orders isn't open info until the order count you should blank out the orders printed on your courtesy lists.
    Heck, I can make my own courtesy list invalid by failing a superior Infiltration roll during deployment and revealing my Oniwaban!
    Courtesy lists are a game aid, a way of speeding up the process of divulging open information to your opponent at the start of the game. Things start to fall apart if we think of them as a solid, binding part of the rules.
    inane.imp, BLOODGOD and Mahtamori like this.
  19. Bobman
    Bobman MERC
    Wow OK. I've had it work fine on normal units every time I've tried.
    Although the orders thing is correct Holo wouldn't generate more orders. But that's a fault with the courtesy list, as mentioned.
  20. Mahtamori
    Seems to work just fine? Below is a screen capture of a courtesy list containing only a Zhanshi Spec Ops
