Some questions
Discussion in '[Archived]: N3 Rules' started by shaka_umruk, May 30, 2018.
  1. shaka_umruk
    shaka_umruk New Member
    question :
    if the pilot contested an obiettive to the end of the game, what happen?
    thanks
  2. inane.imp
    I'd award the points to the Pilot (rule of cool). But it's ambiguous.
    The Trooper is in a Null state, but the Specialist model is not. The ITS rules specify that the Model must not be in a Null state for some missions (Show of Force) but that the Trooper must not be in a Null state for others (Safe Area).
  3. tox
    chromedog and daboarder like this.
  4. inane.imp
    Controlling ZO I'll give you. Controlling objectives. That's an entirely different kettle of fish and not one covered by the rule you cite.
    If they're a Specialist trooper in a non-Null state they can control objectives.
    I'll also give you the Pilot rules are a massive mountainous mess. You could stop the Persian hordes on that hill. [emoji6]
  5. tox
    If the Pilot specialist is not a survivor for any other purpose, how could he control an Antenna? He can activate them, but he can't control them....
    emperorsaistone likes this.
  6. xagroth
    He controls the antenna as a specialist... with a value of 0 points, in case of contest.
    Also: TAG "locked" with dismounted Pilot (alive or not): TAG counts as "live", controls zone, controls Antenna (!), etc..., since the TAG is the troop.
    Interesting consequence: you can kill everything in a LI scenario Vs 9 troops + TAG if you dismount the pilot, kill him, then kill all other troops... As long as the TAG costs more than 75 points or so, the enemy won't go into Retreat! That's why the Szalamander is BTS 9 XD
    TAG destroyed, but pilot dismounted: TAG is dead, pilot won't generates order (the TAG does), and if Lt (Guijia, O-Yoroi...) theh LoL ensues.
  7. shaka_umruk
    question:
    situation:
    i have 3-4 model in a point of table in reactive turn, now an active miniature declare moves, as first short skill,
    now only 1 piece have LoF with model:
    the model declare bs attack with its aro,
    the others model declare idle
    then with the second short skill declare a bs atk with an impact template weapon on a piece ,
    place template andall pieces covered from the template.
    question is:
    the pieces that declare aro, now can change their declaration with dodge for example?
    thanks
  8. Mahtamori
    You can't declare Idle as an ARO.
    The other models do not get an ARO unless the active model is inside their ZoC, in which case they could have declared Change Facing.
    If they weren't in ZoC, then they have not declared anything yet and can declare Dodge - but the model that declared BS Attack will not be able to change their declaration.
  9. shaka_umruk
    Question:
    Situation :
    Dual wield weapon on domaru butau ( for example, have E/M ccw and shock ccw), make a critical hit on an roll
    Question :
    What is the effect on critical hit i must apply ( shock or e/M) and why?
    Regards
  10. nazroth
    E/M Special Ammunition and CC Weapons
    Close Combat Weapons that use E/M Special Ammunition cause Normal damage in addition to the E/M effect. Critical hits in CC are always applied to the E/M effect.
    Consequently, the target must make an ARM Roll in addition to the BTS Roll (with half its usual BTS value). For both Rolls, the CC Weapon's Damage is the trooper's PH Attribute.
  11. Mahtamori
    @nazroth you're missing the part about the Shock CCW. I know this has come up before but I can't find it or remember the conclusion.
  12. macfergusson
    I think he's still correct, though. EM CCW causes ARM+BTS rolls. Adding shock to the hit makes that ARM hit have a Shock effect if it is failed. However we still have the base EM rule stating how to handle crits when EM CCW is used.
  13. shaka_umruk
    Question:
    Shock
    • Special Ammunition causes the target to lose one point from his Wounds/STRAttribute.
    • If the target has a Wounds Attribute of 1 on his profile and fails an ARM Rollagainst Shock Special Ammunition, then he enters the Dead state directly, bypassing the Unconscious state.
    • This specific special effect does not apply to:
      • Units whose Wounds Attribute is higher than 1 on their profile (such as Heavy Infantry).
      • Troopers who, during the course of the game, increased their Wounds Attribute above 1.
      • Units with a Structure (STR) Attribute instead of a Wounds Attribute, such as Remotes, TAGs, Vehicles, etc. Against these, Shock Special Ammunition has the same effects as Normal Ammunition.
    IMPORTANT!
    Shock Special Ammunition cancels the effects of the target's Special Skills Valor L2: Dogged and Valor L3: No Wound Incapacitation. Shock Special Ammunition also cancels the effects of the SpawnEmbryo part of the Shasvastii Special Skill.
    Then on a piece with 2+ wound and NWI shock deny the NWI?
    THANKS
  14. inane.imp
    Yes. They go Unconcious. Read the FAQ it's explained in detail there. On my phone or I'd quote it
  15. macfergusson
    It actually isn't on the wiki yet it seems. @ijw are you still holding off on some of the FAQs still or am I just blind?
  16. shaka_umruk
    Question:
    Mine has concelead when reveal it, it has mimetism given from camouflage or not?
  17. macfergusson
  18. xagroth
    http://infinitythewiki.com/en/Mines
    All mines listed there have "Concealed" among their traits.
    • Concealed. This weapon or piece of Equipment benefits from some or all the effects of the Special Skill CH: Camouflage (Camouflage Marker, -3 BS, etc.). Refer to the description of the weapon or Equipment for more details.
      • Camouflage Markers concealing a weapon or a piece of Equipment have a Silhouette (S) value of 2.
    So yeah, they do.
    And MacFergusson has just nijaed me... XD
  19. shaka_umruk
    question:
    have a opponent miniature behind a cover, and have lof on it, but i dont see the the center of piecese, now i shoot with a circulate template munition;
    1:then place the circulare template on center the piece or on point i can see?
    2: SS1 to activate it, the piece must be within 8 of the shooter or the template?
    thanks
  20. inane.imp
    1. Centre of the base
    2. Attacking Trooper must be within ZOC of the Trooper with SSL1
