Snowball paints slow and has army ADD
Tema en 'Miniatures' iniciado por Snowball, 25 Dic 2019.
  1. Snowball
    Snowball Well-Known Member
    14 Abr 2018
    Got everything airbrushed and ready to block out everything else! Using some 3D printed harpies from destiny as imetrons. They turned out fantastic.
    DAC70DFF-9B87-4E10-96C3-48A13FADF24D.jpeg 4BCA4D5F-36E2-4656-B527-71F22596A3A0.jpeg FC4E9122-5B2B-4478-B3A9-D3D8622FE6D2.jpeg
    Harlekin, ZlaKhon, nehemiah y 7 otros les gusta esto.
  2. ZlaKhon
    ZlaKhon New scale enthusiast
    27 Nov 2017
    Wow, that CA scheme is amazing! Is there some method to how you chose which color goes where when air brushing?
  3. Snowball
    14 Abr 2018
    I took a lot of inspiration from holographic and prismatic crystals like bismuth and other artistic depictions of similar effect. Basically I went from dark green - medium green - off white (in this case VMC deck tan) - salmon - medium purple -dark purple. Tried to separate the greens from the pinks and purples with the white. When I couldn’t do that I would try to transition the dark colors together. That’s about as far as my thought process went. Kinda nerve racking randomly airbrushing in areas in no cohesive pattern lol. Things only started tying together when I did the purples.
    A jherazob y ZlaKhon les gusta esto.
  4. ZlaKhon
    27 Nov 2017
    Thanks for the explanation! I already thought that this must have been quite nerve wrecking xD
    The Avatar clearly shows that it works though so looking forward to seeing more!
