Smoke and sixth sense
Discussion in '[Archived]: N3 Rules' started by kghamilton, Jun 18, 2018.
  1. Mahtamori
    You are, but if we're looking at the problem's integral parts instead of the specific situation, we have an FAQ which states that "without LOF" removes the LOF requirements from Dodge, so the question becomes "does this also apply to other skills and if not, why not?"
    Or, if you'd like "why doesn't this apply to the situation at hand?"
    Cry of the Wind, Hecaton and Ginrei like this.
  2. siri
    siri Well-Known Member
    we still don“t have answer to this question?
    the way i see:
    Zone of Control and ARO
    Enemies entering or acting inside the Zone of Control of a trooper while remaining outside that figure's LoF can be reacted to, but only by using the Common Skill Change Facing or Reset, unless the trooper has a Special Skill or piece of Equipment that can be used without LoF.
    So being sixth sense a Special Skill or piece of Equipment that can be used without LoF it should be used.
    in this case we had everything covered without problems. You could shoot if you could trace a line as you were not in a NVZ.
    FatherKnowsBest likes this.
