Reporting bugs in N4 rulebook?
Tema en '[Archived]: N4 Rules' iniciado por wes-o-matic, 25 Sep 2020.
Estado del tema:
  1. darthchapswag
    darthchapswag Shandian Strike Team
    20 Oct 2018
    Dodging deployed weapons and out of LoF clarification.
    Page 83 says dodge malus don't stack:
    Whereas page 86 demonstrates they do: Screenshot_20200926-101029_Drive.jpg
    Which is correct?
    A Random y toadchild les gusta esto.
  2. ijw
    25 Abr 2017
    The red box is correct.
    A darthchapswag le gusta esto.
  3. wuji
    wuji Well-Known Member
    29 Dic 2017
    Hidden deployment has a duplicate statement for success instead of having both a success and failure statement.
  4. Del S
    Del S Tunguskaball
    11 Dic 2017
    It happens on first prints. Everyone does it - Privateer Press had a few typos in most runs of Warmachine, and companies with larger teams have these errors too, sometimes even worse. Look at GW, they published an entire 6th Edition of 40k that was completely wrong! :stuck_out_tongue:
    A chromedog le gusta esto.
  5. Aldo
    Aldo Spare 15
    In Code One the Multi Sniper Rifle Anti Materiel Mode had B1, in N4 it has B2, is it a change or a typo?
  6. toaster
    toaster Modelling Madman
    26 Nov 2017
    Fire damage on the rocket launcher has been replaced by continuing damage in the weapon charts, but the rule book has no description of continuing damage.
    Similarly Shotguns still have range bands and a small template but no description of how it works, not a problem for us old hands but new players will be totally in the dark.
    Robert
  7. ijw
    25 Abr 2017
    All weapon Traits are in the Traits section in the Glossary, p152. This is mentioned in several places in the book, but you're also the second person I've seen mention this. Wait, unless you're the same person that was discussing this on FB?
    Note that Fire ammunition has been replaced by the Continuous Damage Trait on all weapons that had Fire ammo.
    I've not heard about anyone struggling with it in CodeOne. Don't forget that, unlike N3, CodeOne and N4 specifically describe how multi-mode weapon profiles work, see the ranged Weapon Profile section on p53-4.
    A WarHound le gusta esto.
  8. Lawson
    Lawson Well-Known Member
    23 Jul 2020
    I'm trying to figure out what they meant to say here. I assume maybe it was going to be something along the lines of "you can't ARO attack against a Repeater if the Repeater was used bounce a hacking attack at you?"
  9. toaster
    26 Nov 2017
    Thanks IJW, I hadn't given the glossary a good look as I'd assumed it would merely summarize the rules already covered in the text. And I haven't even looked at Code One so I've no idea how that compares.
    Robert
    A ijw y chromedog les gusta esto.
  10. Alfy
    Alfy Well-Known Member
    11 Jul 2019
    Yeah, I know, but it still irks.
    I also have a lot less patience with these sort of things due to personnel experience. I recently co-wrote and edited 30 pages of technical documents. That's a lot less than Infinity's rules, but I only had a bit less than a month to do it before it was released and hundreds of people got to pore over it, looking for any mistakes. They sure did, and there were still some very minor issues of grammar and spelling, but that was it.
    So I think there's an issue with process, when a document gets that much time before release, that many people getting to work on it, and somehow, nobody notices that sentences are missing... One key difference with my experience: I wasn't making people pay to read my stuff!
    A Mob of Blondes le gusta esto.
  11. ijw
    25 Abr 2017
    Out of curiosity, how much time do you think 'that much time' was? Because it's almost guaranteed to be less than you think, potentially a lot less. :-(
    EDIT
    Yes, it's a lot less. More than an order of magnitude less, and that's excluding the annex file, weapons chart, and diagrams.
    #31 ijw, 28 Sep 2020
    Última edición: 28 Sep 2020
  12. Aldo
    Aldo Spare 15
    I'm going to assume changes were being made up to an hour before release, because that's what I've come to expect since the launch of N3
    Where they literally copypasted JPGs of the correct profiles over the text-based profiles on the pdf
  13. Mahtamori
    Page 77, The game element attributes for Perimeter weapons are missing; ARM, BTS, STR, and Silhouette for these miniatures. (See comparison to DropBears on the same page)
    A Icchan le gusta esto.
  14. Alfy
    11 Jul 2019
    Well, if we are going to include annexes, I'd be at more than 200 pages myself, but I will exclude that as I was not in charge of editing them. On the other hand, I did not have a prior document to copy/paste from. So maybe it's apples to oranges, but I think it still provides a frame of reference.
    I would expect work on the actual document to have started at least a year ago. I would also think the entire team of editors and feedback teams to include more than three people, as was my case. And maybe I'm wrong, and maybe this is the product of two guys cramming every night for 2 months. Which really would not change anything: if that's actually how it was done, it would explain the result, but that wouldn't change the general conclusion of "don't do it this way".
    I have always strongly disagreed with the logic that CB should get a pass because it's a small company. You should aim to what you can do with reasonable quality; not aim higher, do it poorly, and argue it was the best you could do with your limited resources. I don't want to overstate my case, and I don't pretend these issues will decide whether N4 is a success or not, but it is disappointing, again.
    In my experience, the ruleset is the weak point of Infinity: how it is written, how it is presented, for such a complex game, constitute an essential barrier to new players (on the other hand, the minis constitute the strong point). Code One was a step forward in principle, but is hampered by a rulebook that is still poorly organised and presented. So I really expected N4 to be better on these points.
    A Mob of Blondes, Lawson y Aldo les gusta esto.
  15. ijw
    25 Abr 2017
    Oh, I agree, 100%!
    Maybe we could take this to PM later in the week? Overall structure of the rules and presentation isn't something I'm involved with, but I'd love to hear where you think it can be improved.
    A Alfy le gusta esto.
  16. Lawson
    23 Jul 2020
    Yeah, I think while I can give them the benefit of the doubt in some areas, there's clearly something that doesn't work about their process when a casual reading can immediately reveal so many errors. It's common in board game design to send copies of the rules/game for double-blind play tests, where the players only have the rules as written and nothing else (no designer sitting by the side chiming in) to learn from. This usually exposes a ton of problems. You get the sense here, particularly with the nature of many of the errors (including those in the Army Builder), that it could be that people who are TOO familiar with the design and rules of the game are checking their own work rather than having someone else do it for them.
    I also think rules errors caused by working too quickly would be more acceptable if the redactions/fixes came faster or there was communication from the designers with clarification. For example, there was Jump/Super Jump forum about an inaccurate image in the C1 book showing a Fusilier jumping over a barrier (which wouldn't be possible with a 4" jump due to the fact that falling is no longer a thing). It was clearly a mistake that needed fixing/clarifying, but I don't think we got any solution. Then the new N4 rulebook contains the same image and same error. It's things like this in particular that make it seem like the rules are being changed conceptually without enough play testing... and that is much more confidence-undermining and frustrating than things like misspellings and misprints.
    A Mob of Blondes, Icchan y Alfy les gusta esto.
  17. Iisbaerchen
    Iisbaerchen Member
    26 Jun 2018
    don't know if it is a bug, but the question came up in my gameing group and i couldn't find anything in the rulebook. does pistol(+1b) have b2 in cc or is burst always 1 in cc
  18. Gurtana
    Gurtana Member
    16 Abr 2020
    While I appreciate the effort made to get us an Annex .pdf file, I have to wonder, why weren't those rules included in the main rulebook? The Annex is about 14 pages or so. I would have thought it should have been included in the main book. Not having fire team rules when there are sectorial armies from the start of the release of N4 was a bit of a head scratcher. Only until I visited the downloads section on the CB site did I notice there were additional .pdf rules, so I'm disappointed they were not included in main book which would have made things easier as a one stop source.
  19. Aldo
    Aldo Spare 15
    As written there is no doubt that it does give you +1b in cc in the active turn.
    Wether or not it was intended is a different but irrelevant question.
  20. Mahtamori
    It's easier to press DELETE on a small PDF file than it is to edit a huge PDF file when they remake Fireteam rules and sectorial lists.
Estado del tema:
