Reinforcement Group - Open/Private info
Discussion in '[Archived]: N4 Rules' started by tox, Aug 4, 2023.
  1. tox
    If we play with this game mode, it is mandatory to have a Reinforcement group, that should be clear.
    When you start your game and you pass the Courtesy List, it includes the Reinforcement as Open Information
    (models added casually)
    Is this intended? Shouldn't they be Private Info?
  2. psychoticstorm
    That is correct, Reinforcements are open information.
  3. tox
    So that is the first case in the game where you disclose info about something that is not on the table.
    Can I ask you why the developing team came up with this decision?
    Mahtamori and xagroth like this.
  4. Gio
    Gio Well-Known Member
    I had the same question and the pandas (Fast Panda Gaming) kindly answered.
    You share that information when you deploy the reinforcements
    #4 Gio, Aug 4, 2023
    theclaw likes this.
  5. psychoticstorm
    I do not have the answer to that, but I have done the question in the bug elimination phase a long time ago and the answer is it is intentional to be public information and in the curtesy list.
  6. xagroth
    https://infinitythewiki.com/Open_and_Private_Information
    So... they merely applied RAW. I think this will slow even more the games, mind you...
  7. Robock
    Robock Well-Known Member
    Shouldn't the Reinf Section print off on a new page ? So that you can share it once the model are deployed ? While they are obviously Open Info, the rule says to share open info while you deploy them and the new reinforcement rule pdf clearly tells us to not deploy the reinf section during the main deployment phase, but only deploy your main section.
    chromedog, QueensGambit and theclaw like this.
  8. theclaw
    theclaw Well-Known Member
    as per the rules above you don't share you private information until you deploy your models and it says everywhere in the Reinforcements rules you 'deploy' Reinforcements later in the game hence that is when you share that open information
  9. xagroth
    This is not what I undersand from @psychoticstorm answer, frankly. As far as I can understand this, the reinforcements are with the courtesy list you give to your opponent while you deploy, between the Lt roll and the order recount of the first turn... and since the reinforcements are there, they are public info from the start of the game regardless of when they deploy.
    Granted, I may have misunderstood what you mean... nevertheless it is not the first time the rules end in a contradiction loop, I know people have used the rulebook as a Turing test sometimes XD
  10. tox
    You missed the last part. DURING THE DEPLOYMENT PHASE.
    It means that during THAT phase you disclose all your Open Info. And if Reinforcement are Open Info, you are required to disclose them at that very same moment,
  11. xagroth
    I do not agree with this interpretation, because it's cutting a huge chunk of the phrase. It says the time when you must share your list's public info: when you deploy yout models, markers and tokens during the deployment phase.
    It is not saying "you share your open information of each individual model, marker, and token when you place each on the table". This reading seems quite dissonant, since markers's contents are private info, the only public part about them is the mimetism level and silhouette
    tox likes this.
  12. theclaw
    as well as it saying in the rules page 15 you don't share the open information until deployed (you don't deploy Reinforcements at the start of the gane) the president is combat jump for example, once that unit is 'deployed' the unit information is then open so why is it different for Reinforcements?
  13. tox
    No idea, really...
    Maybe because of this?
  14. theclaw
    before we go off at a tangent, I said once deployed it becomes public information
    as in the deployment is the catalyst for information to become public
  15. Koni
    Koni BanHammer
    Just talked with the Dev Team and I can confirm that Reinforcements is OPEN INFORMATION from the beginning and the courtesy list is totally ok as it prints now.
  16. stormshroud
    stormshroud Member
    For me it fails the internal logic check, how can you know the full content of the un-deployed reinforcement section but not a troop with Combat Jump? That seems to be the most appropriate comparison. In both cases it relates to troops that will deploy to the table after the initial deployment phase. In the case of Combat Jump it is private information until it arrives on the table but you know everything about the Reinforcements before they are on the table. That is an inconsistency to me.
    Robock, Jam800, xagroth and 3 others like this.
  17. tox
    Ok, i don't like it but it is the way to go and is wierdly consistent with the rules.
  18. theclaw
    I agree, I don't like it but the ones who must be obeyed say so
    zapp, xagroth and Gio like this.
  19. QueensGambit
    @Koni thank you for your reply.
    At what point in the game are courtesy lists exchanged?
    We always thought it was at the end of deployment, because that's when all the models are on the table and their open info has become available to the opponent. But, your answer on reinforcements is leading us to wonder if we were wrong. Are courtesy lists exchanged at the start of the game, before deployment is finished? That is, is models' information Open from the outset, not merely becoming Open once they're deployed? To put it another way, do I know my opponent's list, including their reserve troop(s), before they've deployed them?
    zapp likes this.
  20. Jam800
    Jam800 Well-Known Member
    I have to say I disagree that the Reinforcement Group should be Open Information prior to it deploying.
    It feels contradictory to the standard game rules, in as much as, what can't be seen on the table remains Private Information, until such a time as the model is revealed or is placed on the table-top.
    I'd like to see a reversal on the decision to keep the Reinforcement Group as Open Information...
    zapp, Tristan228 and StephanDahl like this.
