Objective room, combat jump, and ai beacons
Discussion in '[Archived]: N3 Rules' started by kinginyellow, Jun 9, 2019.
  1. A Mão Esquerda
    Everyone has to have a dream, ¿no?
    chromedog and ChoTimberwolf like this.
  2. daszul
    daszul Well-Known Member
    I do not think that that follows from the text.
    Having a roof does not folow from "inside scenary buildings",
    as a walled garden can be a "scenary building" as well.
    And "infinite height" to me simple means "higher than the boundaries of the table".
    So it is defined as being too high to place troops there.
    Why do you desperately try to find a way to break the game,
    when noone else has a problem with this?
  3. ChoTimberwolf
    Yeah thats true. I actually agree with him that its no really a clean solution. I like the objective room but in most games I play with it we forget it at least once and draw LOF through it or at least one forgets it and moves in a dumb way because of that.
  4. Robock
    Robock Well-Known Member
    we actually do that often with some buildings at my club. We can it fragile glass roof.
  5. Hecaton
    Wack.
  6. FatherKnowsBest
    Who are you responding to? I probably have them blocked, but I can't imagine anyone being that stupid
  7. daszul
    Well, i would not call it stupid, because you need some brain to find holes in the rules, or rather "grey areas",
    but Hecaton seems to be famous for being desperately looking for exploits.
  8. Ogid
    Ogid Well-Known Member
    That's not a bad thing tho. That's how you detect holes in the rules or exploits and fix them.
  9. A Mão Esquerda
    Depends on how it’s approached and presented, though...
  10. Ogid
    Manners matter of course, but a good point is worth considering even when it's presented in a less than ideal manner.
  11. colbrook
    Not every point is a good point.
    Sometimes the beating needs to stop before the equine is deceased.
    tox, daszul, inane.imp and 3 others like this.
  12. A Mão Esquerda
    True, but as you mentioned, manners matter, which we ofttimes forget.
  13. kinginyellow
    For this topic, the answer I feel was from like the first page where tactical drop from ITS says "no" in an objective room. It is possible to be pedantic and state that due to the room in armory isnt actually officially called an objective room but suggests using an objective room from micro art studios or a command bunker from warsenal (etc). It only goes on to state that the zone of operation requires only 4 walls and 4 doors. So the people who state it HAS to have a roof is wrong but the rules does not state it cannot have a roof.
    So: if the zone of operations in the center of the table in armory is an objective room by micro arts then no combat jump regardless of the lack of roofing, if the table creator gave that room a domed roof, no combat jump (be careful with a flat roof as then they can just jump on the roof and still be scoring for the zone of operation, which is less than ideal). I believe the command bunker is actually partially domed roof which is enough to be consider "inside" so also cant jump.
    The big thing to understand is that the walled area in the center of the armory is it is NOT, by definition, an objective room. It is called a zone of operation in the its and recommends which terrain to use to represent it and one of those suggestions is called an objective room.
  14. Ogid
    Just keep beating, the dead are cheaper than the crippled... Ok, that was dark.
    Jokes aside, I'm not defending clear exploits or wild theories, but good reasoned points.
    Well, we all are humans, but in general I don't think this forum has a lot of bad manners. If someone lost his temper once, well, that can happens. Losing it each time is a different story tho.
  15. ijw
    Sure. In that case you can't open the gates.
    • Allows the Specialist Troop to make a WIP Roll to Open the Gates. A success opens all Gates to the Objective Room.
    WarHound, Mahtamori, daszul and 4 others like this.
  16. kinginyellow
    Lol, fair enough point ^.^ didnt see that it was referenced as such.
    ijw likes this.
