Noone discussing NCA upcoming changes ?
Discussion in 'PanOceania' started by eciu, Feb 25, 2019.
Tags:
  1. Death
    Death Well-Known Member
    I really don't think access to Chasseurs makes up for losing access to powerful links and SWC 0 tank hunter COC. But I guess thats a subjective call.
  2. Maksimas
    Considering button-pushing heavy tournaments still being very popular I hear... Chasseurs are very understandably strong.
  3. Teslarod
    Key piece definitely are Chasseurs, the threat that every Camo Marker could be a Sixth Sense LFT makes a big difference
    Galwegians, Volunteers, Caterans, Uxia, Hardcases and Cameronians also come to mind.
    Vanilla Ariadna is damn scary and 2 Spetsnaz HMG is all the firepower you need without having to rely on a Link.
    Ariadna doesn't really need CoC, but they still have it available.
    BTT, man it's hard to fit that stupid Aquila in there without cutting down on Orders.
  4. Vijel
    Vijel Member
    Unrelated question to all the Pan-O/NCA pros here:
    I will go and play FC for sure. So i tought i could start a Pan-O sectorial alongside to use the Pan-O troops i will get for FC.
    So the question is, are Orcs good enough in NCA to field them? I know they are good in Varuna but there i can't also use the Bolts.
  5. Maksimas
    Pretty sure @barakiel knows a thing or a couple dozen about NCA.
    He should be able to clarify that, I'd hope.
    barakiel likes this.
  6. MikeTheScrivener
    They're not bad. Since their Haris got cheaper they're a lot more flexible. Couple that with the CoC bolt and the HMG LT is a real viable option now. As far as HI goes in NCA theyre definitely the weakest of the bunch, but fun none-the-less
  7. colbrook
    BSG+Haris, HMG, and either Bipandra or the Aquila seems like it could do a lot of work.
  8. Teslarod
    Orcs themselves still do nothing Important in NCA.
    Can't slot one into Bolts or Fusiliers, the Hacker is still a terrible Specialist, Swiss or Aquila still outshoot the Haris and they're expensive to boot (3 Orcs cost as much as 2 Guards).
    Even though they can fit the Aquila FTO, Balckfriar and Bipandra into their ranks, they remain NCA's big losers. Aquila + Bolts just seem so much better now.
    Well they gained Fireteam Core, I guess they are an option for a LI Paintrain with Doc + Aquila.
  9. Section9
    I'd be a lot happier if CB would adjust everything at the same time when they change the pricing formula. Would avoid charges of hand-adjusting costs, at least.
    Because Bolts would have gotten two small adjustments in cost last year if they did. Once when JSA dropped (change to Combi+LSG with Aragoto), and again when OSS dropped (change to Drop Bears with Yadu).
    eciu and Maksimas like this.
  10. barakiel
    @Vijel
    ORCs aren't fantastic in NCA, but you can always get the minis and use them as an Aquila or Swiss Guard. Heavy Infantry as generic proxies and PanO REMs are going to cross over between FC and NCA. A lot of NCA's best units (Fusiliers, Hexas, Auxilia) can serve as proxies in either force. But Foreign Company and NCA are pretty different beasts. The best Foreign Company setups I've seen discussed are pretty heavy on Nomad troops...
    AdmiralJCJF likes this.
  11. eciu
    eciu Easter worshiper
    Mean people would say that Bolts were ONLY addressed because Voreign Company and not NCA.
    And today in a single match with OSS Ive deployed more Dropbears than with NCA ever ;P (I like more and more Yadu Haris).
  12. AdmiralJCJF
    There IS stuff you can do with them:
    Neoterran Capitaline Army
    [​IMG]10
    ORC HMG / Pistol, Knife. (2 | 44)
    ORC Lieutenant MULTI Rifle / Pistol, Knife. (0 | 40)
    ORC Hacker (Assault Hacking Device) Combi Rifle / Pistol, Knife. (0.5 | 42)
    ORC Boarding Shotgun + 1 TinBot A (Deflector L1) / Pistol, Knife. (0.5 | 36)
    ORC Boarding Shotgun / Pistol, Knife. (0 | 35)
    BLACK FRIAR (Albedo, Biometric Visor L1) MULTI Rifle, Nanopulser, Drop Bears / Pistol, CC Weapon. (0 | 28)
    BOLT Spitfire / Pistol, Knife. (1.5 | 23)
    BOLT (Fireteam: Haris) Boarding Shotgun, Drop Bears / Pistol, Knife. (0 | 19)
    MACHINIST (NCA) (Bioimmunity, Veteran L1) Combi Rifle, D-Charges / Pistol, Knife. (0 | 16)
    TRAUMA-DOC Combi Rifle / Pistol, Knife. (0 | 14)
    PALBOT Electric Pulse. (0 | 3)
    4.5 SWC | 300 Points
    But it ends up being pretty painfully ordinary.
  13. Death
    Orcs work better in VIRD were you can mix in Kamau to low the links cost while retaining combat potency.
    Balewolf, Teslarod and Section9 like this.
  14. Ayadan
    Well, I think I wil rather try this list:
    [​IMG]10
    ORC Feuerbach / Pistol, Knife. (2 | 42)
    AQUILA FTO (Specialist Operative) MULTI Rifle / Pistol, Shock CCW. (0 | 59)
    BIPANDRA Combi Rifle, Nanopulser / Pistol, Knife. (0 | 23)
    4 SWC | 300 Points
  15. Palomides
    Palomides Well-Known Member
    Pick one. The sectorials have always done well, or only the new ones are good.
    I mean, the ITS rankings show USA and TAK performing equally well. NCA still top ten.
  16. eciu
    It's not exactly what I ment.
    Play old QK, MO, HS, versus VIRD/OSS/TAK. (especially MO prior to HSN3)
  17. Death
    My point is the new sectorials out preform a lot of older sectorials. Pano 3 planetary sectorials are all in a good shape right now and have always been pretty good. But that is hardly the case for the rest of the sectorials in the game.
    I'm not complaining about Pano balance, I'm complaining about the balance of the entire game. VIRD is certainly part of the "new sectorials out classing older ones" pattern. CB has the classic 40k new codex syndrome.
  18. Nemo No Name
    Bolts were discounted because Foreign Company got them, and only because of it. You know how you can tell? Aquila still pays the freakin' 13 points for MSV3.
  19. BarbeChenue
    BarbeChenue Well-Known Member
    I can't believe I can play this list:
    I can't believe I can do this
    GROUP 1[​IMG] [​IMG] [​IMG]10
    BOLT (Killer Hacking Device) Boarding Shotgun, E/Mauler / Pistol, Knife. (0 | 21)
    BOLT (Multispectral Visor L1) MULTI Sniper Rifle / Pistol, Knife. (1.5 | 27)
    BOLT Missile Launcher, Light Shotgun / Pistol, Knife. (1.5 | 26)
    GROUP 2[​IMG] [​IMG] [​IMG]2 [​IMG]2
    FUSILIER Lieutenant Combi Rifle / Pistol, Knife. (0 | 10)
    AUXILIA Combi Rifle + AUXBOT_1 / Pistol, Knife. (0 | 14)
    [​IMG] AUXBOT_1 Heavy Flamethrower / Electric Pulse. (- | 4)
    6 SWC | 300 Points
    Group 1 can be linked and re-linked in so many ways, it's ridiculous. 7 people are Veteran (including the Engineer). Turn 1 I leave the two Missile Launchers and Sniper on ARO duty, if they bite it, I reform with the other Bolts.
    Edit:
    Ironic how the thread title now refers to this thread itself? The discussion has shifted towards power creep or not, rather than NCA changes.
    I'll name one completely unnoticed change: the Machinist with linkable NCA (Veteran L1 +Bioimmunity) profile went from 17 points to 16 during the update.
    Also, here's another list I'm curious about:
    AHD +KHD +Eng +Doc +9VetOrders
    GROUP 1[​IMG] [​IMG] [​IMG]5 [​IMG]2
    DEVA (Assault Hacking Device UPGRADE: Lightning) Boarding Shotgun, Nanopulser / Pistol, Knife. (0.5 | 28)
    DEVA Lieutenant (Sensor) Combi Rifle, Nanopulser / Pistol, Knife. (0 | 24)
    GROUP 2[​IMG] [​IMG] [​IMG]10
    BOLT Hacker (Assault Hacking Device) Boarding Shotgun, E/Mauler / Pistol, Knife. (0.5 | 24)
    BOLT Boarding Shotgun, Drop Bears / Pistol, Knife. (0 | 18)
    5.5 SWC | 300 Points
    #759 BarbeChenue, Apr 1, 2019
    volgo, eciu and A Mão Esquerda like this.
  20. eciu
    Well sir, you won the prize for actually making damn use of that AVA:TOTAL of Bolts and fact we have 8(geneal release) models for them.
    Deltervees, Judge Dredd and Section9 like this.
