Nehemiah Hobby's conversion thread
Discussion in 'Miniatures' started by nehemiah, Feb 3, 2021.
  1. Savnock
    Savnock Nerfherder
    Thank you for the excellent example of reposing in practice- I learned a lot just reading that.
    nehemiah likes this.
  2. Savnock
    Savnock Nerfherder
    This phenomenon of saws, lasers, etc. (and the allowance for thickness of removed material/width of cut) is called "kerf" btw. Shared both because it's a fun word, and just in case you ever encounter it in tool settings or something.
    chromedog, Tristan228 and nehemiah like this.
  3. KedzioR_vo
    KedzioR_vo Well-Known Member
    Great job on this Beasthunter :) I already commented on FB (the one guy nagging about the size of harpoon gun :P )
    I also like to work on such conversions and about cutting, I recommend making your own, very thin saw -
    Conversion thread! what've you got going on? | Page 89 | Corvus Belli Community Forum
    PozdRawiam / Greetings
    Abydog, Ben Kenobi, Jumara and 2 others like this.
  4. nehemiah
    nehemiah Well-Known Member
    KedzioR_vo likes this.
  5. KedzioR_vo
    Precisely! :) Old modeller's trick - use a half of a razor and make the notches with a triangular file.
    Works really good. Helped me with many conversions.
    Willen, Jumara, Savnock and 1 other person like this.
  6. Sanakism
    Sanakism Member
    While the modified-razor above would probably do just as good a job, I've long liked photoetch saws for this kind of thing. Tamiya does a set that fold up to give a thick enough 'tang' to hold in their hobby-saw handle (which is otherwise far too thick):
    https://www.super-hobby.co.uk/products/Photo-Etched-Craft-Saw.html
    And AK Interactive go a step further and sell a similar set with a handle:
    https://www.super-hobby.co.uk/products/PHOTO-ETCHED-SAW-SET.html#gallery_start
    (Although for years I've used an old Hasegawa panel-line scribing set which isn't even meant to separate pieces, let alone saw through metal, but still did a perfectly good job with a bit of care!)
    The advantage of this kind of saw - and the modified-razor option above - is not just that the blade is paper-thin, but also that the teeth don't have 'set'. Normally saw teeth are bent slightly to alternating sides, in order that the kerf they cut is a bit wider than the saw and the saw blade doesn't bind in the cut. So saws like these without set have all the teeth fully in-line with the flat of the blade, cut the thinnest possible kerf... but you do have to be careful to keep them perfectly straight in both axes because they bind very easily as a result!
    nehemiah, Wizzy, Willen and 3 others like this.
  7. Mob of Blondes
    Use soap or oil or even graphite dust to help with the binding issues. Wash once done.
    </déjà-vu>
    nehemiah, chromedog and jherazob like this.
  8. chromedog
    I've used candle wax (Those candle nubs that would burn too low if you left them in the holders ...), soap, WD-40 ... all help to lubricate the blade and reduce the binding (and they all worked well with metal OR resin chunks that I was sawing off.)
    nehemiah, Mob of Blondes and jherazob like this.
  9. chromedog
    Just don't use graphite powder inside a spray booth. The exhaust fan won't like it. Voice of experience.
    dulydude and Mob of Blondes like this.
  10. nehemiah
    Converted up a motorized Bounty Hunter for my Tunguska.
    Sangarn, khepri, Ugin and 13 others like this.
  11. nehemiah
    Finished up a conversion of a Veteran Kazak with Boarding Shotgun. I kind of got on a kick of using bits of the base tab as the superstructure for converting weapons.
    khepri, Ugin, Savnock and 11 others like this.
  12. nehemiah
    Finished up my conversion of Dr Worm, who has been deeply embedded with the Morat Aggression Force and has taken on some of their customs.
    Sangarn, khepri, LeGweg and 12 others like this.
  13. nehemiah
    So not really a conversion, but considering the news CB has put out, I got the jump on making a Rem Racer. Working on getting it cast as part of the swag for Rose City Raid 5. I have only made a few minis in 3D, so generally the newest one is always my favorite, but I think this one warrants it.
    Daaz, meikyoushisui, Abydog and 14 others like this.
  14. burlesford
    Amazing. I feel like there's a reference I'm not getting though...
  15. jherazob
    Abydog, Koin-Koin and nehemiah like this.
  16. archangeleong
    This so much should be a real model!
    CB please employ Nehemiah to make one!
  17. Ugin
    OMGWHATARETHOSE IWANTTHESE
    for real, your sculpting skills are spectacular
  18. burlesford
    Luckily the name was in the gif link XD Otherwise I still wouldn't have gotten it.
    chromedog and nehemiah like this.
  19. jherazob
    Dude, stop everything you're doing right now and run, not walk to watch Cowboy Bebop! Yes! Even stop working, THIS IS IMPORTANT! :smile:
    anubis, nehemiah and burlesford like this.
  20. burlesford
    I'm already not working, so step 1 is taken care of :D
