My Infinity 3D FanART/Concepts
Discussion in 'FanArt' started by Vult ji, May 28, 2022.
  1. Vult ji
    Vult ji Well-Known Member
    Okay. Finally made the first concept weapon options. Big immage :D
  2. Vult ji
    Some more models one older and already released another in the making :P
  3. Modock
    Modock Well-Known Member
    Beatiful work, remotes look really cool. Keep them coming. :+1:
    Vult ji likes this.
  4. Vult ji
    I will :D.
  5. Errhile
    • The missile pod looks good. You can either tweak it a bit (add some panels / surface details to the side of it) or leave it as-is.
    • The sensor pod is fine. IMO it looks better on the side, opposite to a missile pod, than centrally on the "tail" under two missile pods. But that's just my opinion.
    • The rifle is OK. IMO it needs more surface details on the ammo hopper (I assume that is the box under the action of it) to show it is an ammo hopper.
    • The HMG needs a source of ammunition. Given it is HMG, and a Total Reaction one to boot, I'd say it should have a large one. With lots of ammo. Personally, I guess the best thing there would be a big effin' ammo box mounted on the other side of the tail, and linkes to the gun iteslf with an ammo belt, but I guess this might be difficult to make as a project.
    • I'd suggest designing one (or preferably two) additional "sensor package" bits, so a FO/Sensor REM could have its own, and the Flashpulse REM a yet different one (it would be perfect if it looked like a part of the FO/Sensor kit, "one that contains only the Flashpulse bit of it").
    Vult ji likes this.
  6. Vult ji
    As always tanks for the feedback and the time you take to write it :D. Sure more details are coming ( the are there but i failed to make them all show up good on render )
    - A for the ammo belts...i personally think they are cool but it is a little limiting for the model and because resin can contract a little it will not fit 100% ( nothing some green stuff can not fix) but also it would be quite a brittle part if i don't make it very thick running along the model.
    - about the ammo hopper. I kept the way Corvus makes them.( strapping the gun on the model). But made the ma little more integrated. The ammo box is situated on the top. But is true that the details are missing so it cant be discerned properly.
    -I will try to make as much equipment as i can :P. Sadly i have a bad habit of doing 3 project at a time XD when it comes to weapons. Will take some time.
    Errhile likes this.
  7. Errhile
    Well, it is not like any of us is in a hurry about this :)
    Regarding the ammo hopper - sorry, but unless you mean the bit linking the gun to the REM's tail, there is no hopper on the top of it. Also, both guns have visible ejection ports on the side, and a box of some sort located straight below one (which is, more or less, where it should be if it was a bottom-feeding ammo box on a real firearm). So, the location of the amo boxes is essentially fine, especially for the rifle.
    For the HMG, I'm sure it could be larger.
    Vult ji likes this.
  8. Vult ji
    HMG done and printing. Results soon....
  9. Errhile
    Uhh... hoses? Cables?
    I mean, if the "machinegun" is a direct energy weapon, sure.
    If it is a slugthrower of any kind, however...
    Waiting for the print results :)
  10. Vult ji
    Heloo back with the prints.
    Saddly my digital camera is on strike again so i tried to do some pick with my phone, not to great but at least i can show it was a succes.I can see all the details i made but i will make some of them stonger
    Also the resin i use will take some more time to cure fully so details will come out better soon
    So here it is :
    next post more
  11. Vult ji
  12. Vult ji
  13. Errhile
    Looking good.
    The Haqq HMG drone - from these angles, the bit I was concerned about looks more like an ammo belt, less like a pair of power cables. Which is good (I'd say it could be better - if it had less "dent" between the edges). But again: it's good.
    The missile launcher pod is good, too. Of course, those two systems shouldn't be paired on the same model, but I understeand this print to be for test purposes only.
    Overall, the drone seems to be too big - it barely fits the 40mm base. I'd make it, dunno, 10% smaller overall. Still, that's something everyone can adjust for themselves when printing, right?
    The other two REMs also look good :)
  14. Vult ji
  15. Kumatake81
    Kumatake81 Well-Known Member
    This is truely amazing work! Thanks for sharing!
  16. I don't know if the best place to share material that goes against the sales of a company's material is the company's own official forum.
  17. jherazob
    Don't think there's any danger of lost sales by CB from proxies, might be mistaken but from what i see in general hardly anyone bothers because CB's minis are just too good and not too expensive (unlike what happens with... other games)
    Jumara and Errhile like this.
  18. The point is not whether these proxies are going to affect CB sales (which I don't think they will), the point is whether this is the best place to share them (which I don't think it is either).
  19. Vult ji
    Well i do agree it might be...and i would happily remove them if said so. I did check the fan art section and i saw some models or concept arts being made so i thought it would be fine. And as you both pointed out this are nowhere near the detail and standard of the company and i never meant as a standing only wanting to share, maybe someone like to take parts and make conversions as we know those area allowed.
  20. Vult ji
    Some new stuff :D i tried to make for learning purposes
    [​IMG] [​IMG] [​IMG]
