MO crusade lists for Killing oriented missions
Discussion in 'PanOceania' started by Guardian, Mar 24, 2019.
  1. Maksimas
    The virgin Joan and Tarik next to the chad Sheskin
    mrstream, Judge Dredd and eciu like this.
  2. eciu
    eciu Easter worshiper
    Check Shasvastii ;P
    Plus I was reffering to a link.
  3. Death
    Death Well-Known Member
    MO really need a cheap COC option. It would help knight fireteams lists tremendously. Right now, if you want a good HI fireteam sectorial, play Invincible army. MO does better with a defensive OS link.
  4. eciu
    Too late.
    Enjoy current MO for next 1.5 year at least...
  5. Guardian
    Guardian Well-Known Member
    Maybe it turns out MO is infiltrated by shasvastii and they make them NA2!
  6. Janzerker
    Janzerker Well-Known Member
    Working as intended. :P
    Besides you can hardly fit 7-8 HI in a IA list, the most flexible and better performing lists have 5-6 HI only. It's not possible to fit 10 HI at 300, while I have just seen a playable 10 knights lists in this thread a few posts ago.
    And don't forget almost all IA HIs are plain HIs, average ARM and BTS is 3, PH 12, vulnerable to CC, lack of template weapons and deployable weapons. Meanwhile, Knights are slightly worse Crane level profiles enjoying very generous discounts from frenzy exploit and hand adjusted discounts in order to fit the 300 pts box. While also enjoying the flexibility of OS with their links and the TO infiltrator profiles.
    Not to say that YJ lost one sectorial 15 profiles worth in order to get IA. Only to be flooded by the bazillion of E/M weapons generously distributed between all armies (except YJ ofc), the powercreep from the new "shock/bio immunity + NWI while not HI units" and the OP absurdity of retarded Fatality lvl2 B5
  7. Death
    Except that the Riot girls are still the best HI link. :P
    I suppose Pano and Yu Jing can join forces in decrying this GW style "playtesting".
    injenegr and AdmiralJCJF like this.
  8. Death
    At this point I'd be happy for MO to go NA2 if it means getting a separate unit scuplt for the TO camo OS and for a cheap CoC option.
    Seriously, MO is a far better force when playing Spec-op rules. All of a sudden MO can play with all the aggressive HI LT that its mean to use.
    eciu and Guardian like this.
  9. eciu
    Yep. This.
    Funny enough you will still be punished for losing Joan (Warcor+Techbee still became Irregular) but it won't be automatic "dead turn" for you.
    It's not even funny how obligatory this poor OS Spec-OP CoC+Engi/Doc+Minelayer is.....
    AdmiralJCJF likes this.
  10. Death
    Heck, I'd take a 25-34 point CoC for MO. The points save over the spechuler will still make it worth taking.
    AdmiralJCJF and Teslarod like this.
  11. Teslarod
    Starts stinging a little bit now, doesn't it?
    Man MO could have been good, such a sloppy job compared to the entire new book.
    Actually nevermind ...I'm sorry. We all just wanted MO to be good so we can enjoy it.
  12. Death
    MO still works......you just need to ignore HI links. So CB defeated the whole purpose of making only Knight LTs by making them unviable for aggression. lol
  13. Skoll
    Skoll Well-Known Member
    Might as well change name from Military orders to Men at Arms the sectorial then.
    The knights are the core identity of the religious orders that comprise the sectorial. And even outside links the knights are eh... solo pieces outside of corner cases.
  14. mineisred
    mineisred New Member
    Self forum virgin hereBut I’m just curious about the term crusade list. What is the origin and exact meaning. Also here’s my 9HI listZw9taWxpdGFyeS1vcmRlcnMYSm9hbiBkYXJjIGtpbGwgbGlzdCA5IEhJgSwBAQoBFAEEAAKF0QEIAAMbAQIABAYBBgAFBgEEAAaEuQEDAAceAQMACB4BAgAJHgEBAAoyAQEA
  15. Skoll
    A crusade fireteam is a special fireteam composed of hospitallers and Joan, it used to need exactly 4 hospitallers and joan. now wildcards may substitute them in the link
    mineisred likes this.
  16. fari
    Wildcard always could replace hospitallers. What is use to be needed is being a full core. Nos you can lose members and remain as a crusader fireteam
  17. Sungwon
    Sungwon Well-Known Member
    Fireteam does not break even if it lose a member who isn't a leader. What changed is that now you can form a Crusade fireteam with less than 5 members. However, it still takes the core fireteam slot.
  18. mineisred
    Thanks, any input on my linked list? Also how are ppl putting the lists right into the post?
  19. fari
    in the web army, clic the comic bubble, copy and paste
    #99 fari, May 5, 2021
  20. tox
    That button results in this output:
    Joan darc kill list 9 HI
    [​IMG]9 [​IMG]1 [​IMG]1
    JOAN OF ARC (Lieutenant) MULTI Rifle, Nanopulser / Pistol, EXP CC Weapon. (+1 | 45)
    KNIGHT OF JUSTICE (Forward Deployment [+4"]) Spitfire, D-Charges / Heavy Pistol, DA CC Weapon. (1 | 50)
    KNIGHT OF SANTIAGO (Hacker, Killer Hacking Device) Combi Rifle, Nanopulser, D-Charges ( | TinBot: Firewall [-3]) / Pistol, DA CC Weapon. (0 | 39)
    KNIGHT HOSPITALLER (Doctor) Combi Rifle ( | MediKit) / Pistol, DA CC Weapon. (0 | 33)
    KNIGHT HOSPITALLER Boarding Shotgun / Pistol, DA CC Weapon. (0 | 29)
    KNIGHT OF MONTESA Red Fury, Chain-colt / Pistol, DA CC Weapon. (1.5 | 34)
    TEUTONIC KNIGHT Missile Launcher / Pistol, DA CC Weapon. (1.5 | 28)
    TEUTONIC KNIGHT Light Shotgun, Panzerfaust ( | TinBot: Firewall [-3]) / Pistol, DA CC Weapon. (0 | 20)
    TEUTONIC KNIGHT Light Shotgun, Panzerfaust / Pistol, DA CC Weapon. (0 | 19)
    WARCOR (360º Visor) Flash Pulse ( ) / Stun Pistol, PARA CC Weapon(-3). (0 | 3)
    4 SWC | 300 Points
    Urobros and mineisred like this.
