Minion Placement Question
Tema en 'Masters of Puppets' iniciado por KingNova3000, 13 Ago 2021.
  1. KingNova3000
    KingNova3000 New Member
    5 Nov 2020
    Hello! A bit of a fringe rules question regarding minion placement that pertains mostly to Fiddler and her Deployment action.
    The rules for minion placement state:
    "The Controller cannot deploy their Minions Adjacent to any Allied Minions"
    My question is this. Does the placement of Fiddler's Jackbots occur simultaneously, or sequentially (i.e. at the same time or one after the other). Following the precedent set throughout Aristeia's rules, simultaneous seems to be the likely answer. Now assuming the placement is simultaneous, can Fiddler using a single Deploy action to place both Jackbots adjacent to one another as neither already exist on the board to apply the restriction, or is it a case that the final position of a deployed minion can't be adjacent to a minion.
  2. Ealthril
    Ealthril Well-Known Member
    22 Nov 2018
    Hello,
    Indeed you cannot put them adjacent to one another. Or if you play Gaia, adjacent to one of her bots also.
    But once your bots are placed, you can then displaced them to put them adjacent, with Hexxer for instance to block a passage etc.
  3. KingNova3000
    5 Nov 2020
    You're 100% correct, but that's assuming my timing query leans toward placing be sequential.
    Gaia's minion placement works sequentially, one down via a switch and then another via the action, each of those occur at different times. so the second minion can't go down adjacent to the first as its already there. When Fiddler places her minions via a single Deploy action, they both arrive at the same time within a single step of the action.
  4. Delta57Dash
    Delta57Dash Well-Known Member
    25 Sep 2020
    Even if they come down simultaneously, you're still placing them next to each other, so the placement would still be illegal.
  5. Croepoek
    Croepoek Well-Known Member
    2 Ene 2018
    Good question, maybe @Damiel or @-V- can help us here?
  6. HarlequinOfDeath
    14 Dic 2017
    I would assume the phrase "one by one" is missing. I highly doubt that it is intented that you can place them at the same time next to each other.
  7. KingNova3000
    5 Nov 2020
    Totally, its a hyper niche query. Like my obvious rules as intended brain makes the answer very clear. But we all know sometimes those niche rules are totally intended when it comes to CB, especially when spanglish occurs. Our local meta plays it the obvious way, but when it came up we thought we had to ask.
  8. HarlequinOfDeath
    14 Dic 2017
    Aristeia! is different from Infinity though (afaik a different design team) and it tends to have very clear rules. However, there are very few translations errors or let's say not so clear rules after the translation because a comma or word is missing. See the discussion about Side Effects (Bachmann), for example.
    Talking about minions I would place them one by one.
  9. -V-
    -V- A! Team member
    31 Ene 2017
    It should be added something like "one by one", as @HarlequinOfDeath said. However, if you cannot deploy a Minion Adjacent to another one, you shouldn't be able to do though you do at the same time.
    A Croepoek, Ealthril y HarlequinOfDeath les gusta esto.
