Military Orders Color Schemes
Tema en 'PanOceania' iniciado por Golem2God, 18 Dic 2018.
  1. Lightforge
    Lightforge Well-Known Member
    5 Ago 2018
    ]Thanks guys!
    I do have a tutorial on my Instagram (Lightforge Studio) but for those who either don't have access or want to use that, I'll happily do a little breakdown here.
    first I start with a solid basecoat of Celestra grey(GW). I personally build this up over 2 or 3 consecutive layers to keep a nice smooth surface, as white is a somewhat unforgiving color and will show imperfections on the surface.
    Once the basecoat is down I layer over with a solid layer of Ulthuan grey (also GW). I'm not worrying about messing up other parts or painting "outside" the lines as white is usually the first thing I paint.
    Build up this layer over several layers and probably thin your paint a bit either with water or medium. I usually build up over 3 to 5 layers depending on the size of the area. This is honestly the most time consuming part.
    Now that the base layer is done it's time to add some shading/contrast. For that I make a mix of Ulthuan grey, Dawnstone grey (GW) and medium. Roughly 60/20/20 but do experiment a bit. You want to drag this glaze towards the dark parts of your surfaces. Building up shade on your model while leaving the lighter parts pure Ulthuan grey as this will be your brightest white, that isn't a highlight.
    Then some deeper shadow by creating a glaze by mixing pure Dawnstone and mostly medium. (30/70).
    Now darklining in between armor plates or clothing etc with a pure dark grey of your choice. I normally use Eshin grey (GW) as it is neutral and not too dark. Thin it down to help it seep into the recesses.
    Finally highlight with pure white and done!
    For the red I use much the same approach as with white. The amount of medium may vary a tiny bit as red is a much denser color than white. It is however also a fair bit more forgiving.
    Basecoat is Khorne red (GW)
    For the shading I make a glaze of Khorne red, black and medium. Mostly consisting of medium and slowly build up the glazes and progressively adding more black to the mix until I've reached the amount of contrast I want.
    Then I correct any mistakes I've made by layers Khorne red back up towards the raised areas.
    Then I highlight with Cadian fleshtone (GW) and then extreme highlights of Kislev fleshtone (GW) if I'm working on armor etc.
    [/SPOILER
    Hope this helps!
    Again thanks for the kind words
  2. Zsolt
    Zsolt Well-Known Member
    18 Feb 2018
    Which medium?
  3. Lightforge
    5 Ago 2018
    Any flow medium will suffice. I personally use Lahmian medium from GW but you can do cheaper and better I'm sure with any acrylic paint flow medium
    A GingerGiant, Golem2God y Zsolt les gusta esto.
  4. GingerGiant
    GingerGiant Well-Known Member
    28 Mar 2018
    I’m surprised you are just using grey and white! There’s a subtle cream tone to the armor in the pictures that surely comes from your light setup (given the recipe), or it’s the effect of pairing red with white. Thanks for the tutorial! I’m going to try to make my knights a little more cream/tan/beige/sand tone, and this is really helpful.
  5. Section9
    I really prefer using Vallejo Glaze medium, since that has surface-tension-increasers (forget the technical term), which means that your paint stays where you put it.
    But there are several stores that carry Vallejo Model Color (or even Mecha Color!) nearby, so it's not hard for me to buy.
    A Golem2God le gusta esto.
  6. Manfred_VR
    Manfred_VR Well-Known Member
    I really love this colour scheme, it's a true masterpiece!
  7. Zsimbi
    Zsimbi Well-Known Member
    13 Jun 2018
    With all these outstanding paintjobs I'm actually a little afraid to post mine, but here it goes :D
    I went with a "knight-ly" looking armorplates, with a unified left shoulderpad, azt an order apropriet right one. Also with red tabards 'couse everyone knows its the fastest colour!
    mrstream, Section9, Golem2God y 3 otros les gusta esto.
  8. Golem2God
    25 Nov 2017
    @Zsimbi I think they look good. Don't be afraid to post your work. The worst that can happen is something telling you they don't like it. Plus you can gain tips from constructive criticism to help get better at painting.
  9. Section9
    Agree with Golem, here. NEVER be afraid to show your models (besides, they look about as good as mine! :stuck_out_tongue:)
    I'm not much of a fan lots of metallics on Infinity models, but you did a good job on them. While they look a bit rough in the picture, that's almost entirely due to the magnification.
    IMO, the real problem with metallic paints is to get enough contrast (it's honestly easier to do non-metal metallics, NMM!). I forget how to make good 'steel' with metallics, but I have a very nice recipe for Bronze from Privateer Press.
    A MikeTheScrivener, TheEmptyRoad y Golem2God les gusta esto.
  10. Ayadan
    25 Nov 2017
    TMP is much likely like NMM. You just have to consider what color you should use for shadows and enlightments. For example, for the gold of my Seraph, I used Retributor Gold (GW) for the base, then mixed with Zameshi Desert, Balor Brown and Abaddon Black for the shadows (you don't have to use all for this, Abaddon is great to add for parts really in the dark, for example) and then just a diluted slope of Retributor to give back a bit of shine. For enlightments, mix Retributor with Auric Gold and even Stormhost Silver for the "white point" where the light come in straight.
    But like NMM, it requests some practice to know what colors you like mixing and how you'll use them.
    A Zsimbi le gusta esto.
  11. MikeTheScrivener
    5 Mar 2018
    Some really beautiful models in this thread – I haven't painted a ton of military orders but of the models I have here they are:
    and:
    I wanted to do a very simple but effective scheme. I wanted them to look very cold, fighting in a very matter-of-fact way.
    I've had a half-finished Joan in this same scheme i've been meaning to finish, I think this holiday break I might just get around to it. Let me know what you guys think! I haven't though too much about heraldry, but I might freehand something onto my order if i'm inspired enough
    eciu, mrstream, Lesh' y 3 otros les gusta esto.
  12. Golem2God
    25 Nov 2017
    A MikeTheScrivener le gusta esto.
