Mayanet Roster Creator
Discussion in 'News' started by toadchild, Dec 5, 2017.
  1. toadchild
    Beta will be going out tonight with PanO updates!
    Known issues:
    • Unit icons have not been added yet for new entries
    • MAF updates are not yet in place
    • Yu Jing updates are not yet in place
    Please review the changes to PanO and let me know if you find any issues, no matter how small :sunglasses:
    E-Warden and inane.imp like this.
  2. inane.imp
    It appears Kamau get SI for free.
    Or did you only mean issues you've introduced? [emoji14]
    (Lovin' the work as ever).
    toadchild likes this.
  3. toadchild
    I'm uploading a second beta that includes Combined Army and Yu Jing updates. It should be available to people next week; if there are no issues reported I'll do a public release shortly after that.
  4. toadchild
    In light of all the discussions about how Army 6 handles fireteam notes, I decided to update MayaNet to have the full sectorial fireteam chart listings for each unit. This required that I redo how I'm showing notes. They're now on a selector tab, visible either when you're choosing a unit loadout or when you're looking at weapon selection, such as in Play mode.
    Hopefully this display gets the @ijw seal of approval :sunglasses:
    Guardian, Nat Lanza, dlfleetw and 2 others like this.
  5. toadchild
    Sadly I missed the holiday deadline for the app store, but I'll put out the new version after they open the process back up on the 28th.
  6. dlfleetw
    dlfleetw Well-Known Member
    Thanks as always for your work
  7. Kwisatz Haderach
    Kwisatz Haderach Zelenograd Shasvastii
    Found some bugs to dig in.
    In SSS Aleph, if you choose Assault hacker Deva or Shakhti - they don't count as hackers on the list. Also they don't have Hqcking charts.
    Same for Assault hacker Yadu.
  8. toadchild
    Thanks for the report, I'll check those out. There's always the chance I put the hacking label on that loadout and then forgot to add the actual device.
    Kwisatz Haderach likes this.
  9. Henshini
    Henshini Well-Known Member
    Found a tiny mistake on the Liu Xing, Army has it listed as veteran but Mayanet lists it as Spec. Trained.
  10. toadchild
    Thanks! I’ll add a note to fix it in the next release.
  11. toadchild
    I'll post an update this weekend that has the couple of reported bugfixes and the new 112 motorcycle profile.
  12. toadchild
    I'm uploading build 3.1 to Apple today!
    Changes:
    • Support iPad Pro screen resolution
    • Support iPad multitasking (split screen)
    • Add 112 Emergency Services (Motorized)
    • Fix Liu Xing unit classification
    E-Warden, Nat Lanza and inane.imp like this.
  13. toadchild
    I realized I forgot something, so I'm uploading a quick point release - baggage/retreat calculations are now FAQ-compliant
    Postmortem and inane.imp like this.
  14. toadchild
    I made a minor bugfix release - I fixed a small crash and I corrected Exorcism's range in the hacking notes.
  15. PappaChu
    PappaChu Well-Known Member
    The app is fantastic, super helps keep games running smoothly!
    Just noticed the Libertos Freedom Fighter isn't available for any armies when SoF Mercs are enabled, as a heads up
  16. toadchild
    Good catch, I’ll add a note to address this in the next release.
  17. toadchild
    I'm uploading a new build with the updated Khawarij loadouts.
    I've also (finally) added proper Soldiers of Fortune support - activating mercs costs 1 SWC, and you'll get a validation error if you have more than 75 points of them. As part of this, you will also find that the mercs toggle button has moved over to the right-hand pane. Please test this feature thoroughly and let me know if you find that anything at all about it behaves incorrectly or even just oddly.
    Guardian, Barrogh, E-Warden and 2 others like this.
  18. Postmortem
    Postmortem Kazak Arachnophile
    Thank you toadchild.
    Amazing resource.
  19. Romulas
    Romulas Active Member
    Getting a crash when I open the program on my iPad mini. Shows it running in the background but kicks out to main window in a second or so. (Older mini issue? Was working last week though)
  20. toadchild
    Sorry to hear that! I’ll check the crash logs from Apple to see if I can find anything.
