Lieutenant Order and Fireteam:Duo
Discussion in '[Archived]: N3 Rules' started by McNamara, Jan 9, 2018.
  1. McNamara
    McNamara Merc Rep
    Is it legal to use a Lieutenant Order to move a Duo Fireteam?
  2. colbrook
    No, can't use an Lt. order on any Fireteam.
    chromedog, Hecaton and McNamara like this.
  3. McNamara
    McNamara Merc Rep
    Yeah, thats what I figured, but since its only a MOV Order I wasn't sure. Thx!
  4. Sabin76
    Shouldn't matter what skills are declared. It's the fact that you didn't spend a regular order activating the fireteam.
    Edit: To be clear, there is no "Move Order" other than in colloquial terms. There is a Lt. Order which can be used to activate your Lt. which then allows you to declare skills (like move).
  5. Mahtamori
    For reference: http://infinitythewiki.com/en/Fireteam_Integrity
    • If the trooper is Irregular and uses its Irregular Order.
    • If the trooper is the Lieutenant and spends the Lieutenant Special Order.
    Theoretically (meaning, this is not currently possible): if a new set of rules introduced a new type of order that doesn't currently exist, introduced a rule where a Fireteam could somehow spend Impetuous Orders, or introduced a rule that allowed a trooper to spend the LT order without being the LT - then the current Fireteam rules would not kick that trooper out. Same goes for a trooper somehow spending another trooper's irregular order (without first making it regular) or spending their own irregular order without being irregular.
