Isnt it too much?
Tema en 'Nomads' iniciado por Angry Clown, 5 Mar 2022.
  1. Time Bandit
    21 Feb 2019
    Thought you were eagerly awaiting data on prevelance, Child9? Did it come thru in the past hour? ;)
    A Hecaton le gusta esto.
  2. Child9
    Child9 Well-Known Member
    16 Feb 2018
    Really? You need data on prevalance to state that no, 50% of tournament lists aren't Nomad-GML lists? Don't be of bad faith here... ;)
    A chromedog y A Mão Esquerda les gusta esto.
  3. Tourniquet
    Tourniquet TJC Tech Support
    18 Feb 2018
    Not just nomads. ForCo, DBS, OSS, Onyx, HB, and O-12 also heavily leverage this because it allows them to not only kill LT's but key elements of the army without risk.
    Yes we would, a sneaky guy with a dep rep while more order intensive is often just as easy, even it is a suicide run. If you could trade a 20 point skirmisher to enable you to delete their main assault piece/ fireteam and cripple them you would, and it does happen quite frequently to any army that is able to do so (hell I even see pano pulling this shit on the regular).
    The biggest issue is that there is ABSOLUTELY ZERO counterplay to a GML alpha, beyond reset and pray.
    A WiT? y Modock les gusta esto.
  4. Hecaton
    Jazz is the most egregious example of the issue, and her power level is very much related to why this is an issue. Vanilla Nomads/Corregidor are the ur-example of a shitty gameplay style, and overall that gameplay style shows up quite frequently in competitive play.
    Because part of the point is that Corregidor gets way too much stuff compared to the other Nomad sectorials.
  5. Hecaton
    How do you adapt when a player w/ a repeater net kills your lieutenant top of 1, and all your attack pieces after your first turn?
  6. Tourniquet
    18 Feb 2018
    Probably not, most of the people I hear dont buff KHDs from are people that dont play nomads and dont want them getting better because everyone is now on the same playing field when it comes to hacking.
  7. Hecaton
    I read your post in detail and addressed it in detail, but you didn't read my earlier post because you're saying I said things I didn't say. And you're still doing that. When I say that KHDs *SHOULD* provide a counter to an overextended repeater net, I'm not saying that they do. But you seem to not be able to understand the difference between WHAT IS and WHAT SHOULD BE.
  8. Hecaton
    Does anyone have that data? Maybe the German dudes who were scraping the ITS site.
  9. Hecaton
    It's related because Nomads use that strategy quite frequently.
  10. Knauf
    Knauf Transhumanist
    3 Mar 2018
    We've found something the other day which is probably not too common an occurrence:
    Placing stuff inside buildings with interactable doors that are otherwise closed, thus not allowing a valid trajectory.
  11. Papa Bey
    *gasp*
    Insides?!?.
    A A Mão Esquerda y Knauf les gusta esto.
  12. Hecaton
    Citation needed. White Noise being in a faction or not changes how its gameplay works dramatically.
    No, that's not true. Their hacking and gunfighting is on an entirely different level.
    This is untrue. Corregidor was lacking White Noise and beefy TAGs for longer than it was lacking infiltrators. So lacking White Noise and durable TAGs is a more important "restriction" for it than Bandits' presence, or lack thereof.
    A RolandTHTG le gusta esto.
  13. Hecaton
    Assuming they haven't covered 100% of the approaches to it, and assuming that it doesn't lost a FtF roll on the way in, and you stick the landing? It's very dodgy to have a *chance* at a fair game. Again, just running a repeater net setup in your list means your opponent has to take risks to make the game fair.
  14. Tourniquet
    18 Feb 2018
    Uturn doesnt do anything, you need to put something like zero pain back in in greater numbers.
    That just ends in further DTW spam degeneracy and repeaters in locked rooms where you cant dig them out without extreme cost. And not to mention that unless you are playing in TTS interiors are a nightmare and if you are using an interior you rule out being able to use the roof and vis versa.
  15. Hecaton
    One, what meta is that, and two, there hasn't been an Interplanetario since N4.
    Also I know at the last Interplanetario someone scheduled the rounds for like 75 minutes in length, meaning most games went to two turns even if you played fast. That's not how Infinity is meant to be played, really.
  16. Tourniquet
    18 Feb 2018
    Also assumes you got first turn and/ or havent taken crippling hits to knock you out of the game.
  17. Hecaton
    If you're asking that seriously, it's a sportsmanship issue. People don't like doing it in person.
  18. Hecaton
    I agree but as I mentioned upthread I'm focusing on Nomads in this thread.
    Yup!
  19. Knauf
    Knauf Transhumanist
    3 Mar 2018
    It really hinges on the terrain, but I've found it to be not much of an issue with adequately modular terrain. Corvus' Terrain is really good for these kinds of interactions, as are many MDF based series. It adds another layer of complexity and decision making to the game and it's nice to shake things up a bit. Not sure it would be feasible as a balancing mechanism, though.
  20. Child9
    16 Feb 2018
    Absolutely not, as Jazz is largely absent in most of all tournament lists while you claim you encounter the issue in 50% of your games. You're not even being coherent with yourself.
    Several people explained you several times that your problem is about pitchers/GML (amongst a gazillion others things...).
    Say it. I can see that big vein on your forehead as you're trying not to. G.... Gu.... Gut.... :joy:
    So what? It still doesn't change that issue into a Nomad-specific issue. Open a dedicated topic to discuss repeaters/GML issues. You're being repeatedly off-topic here, we are going round in circles.
    A Spitfire_TheCat y A Mão Esquerda les gusta esto.
