Invincible Army post mortem
Discussion in 'Yu Jing' started by Triumph, Oct 16, 2018.
  1. Mahtamori
    With less than 14 days to go? Nah, let's just keep these threads alive until they're completely irrelevant (for realsies) so we can start a proper post-mortem of an actual release. Not that I expect YJ to be dead an buried, but still...
  2. Aspect Graviton
    I was going for a summary in this one (but I'm not the one to make it), and yes it definately need a new thread when the list actually drops.
  3. Shiwen
    Shiwen Commissar, Yu Jing Political Work Department
    Uprising threads, Invincibles threads... we may not be able to supplant the Hyperpower (yet), may not be able to carry out even semi-competent counterinsurgency operations, but there is no doubt Yu Jing can post. ^_^
    Death, krossaks, Kallas and 4 others like this.
  4. Janzerker
    Janzerker Well-Known Member
    Actually between 6 and 9 days. Koni has said it won't happen on 30th because it's a local holyday. That leaves 26th, 27th, 28th and 29th as the only possible dates.
  5. ambisinister
    ambisinister Broken Zoetrope
    Here's hoping for 6!
  6. Section9
    OK, thank you for that, I had not seen the Suryat profiles.
    But for some reason the Santiago knights got ~4pts cheaper, so there may be a points adjustment lurking in the 3O update.
  7. Maksimas
    We fight the war in the communications networks to sour enemy morale.
  8. Triumph
    Hospitaler Knights got cheaper too and I have no explanation for that one either.
  9. Mahtamori
    Hospitaller also got 1 or 2 points cheaper and had their AP CCW upgraded to the more expensive DA CCW across the board at the same time. Add to that the Raicho had its stats adjusted to exactly match the Guijia, but retains the costly Morat rule (which amounts to a cost reduction of about 3 to 5 points), I think there is something that's changed in CB's formula that hasn't been implemented on the older units yet.
    Kallas likes this.
  10. Maksimas
    If it has, I sure hope it gets implemented at the end of the month.
    Which would make sense, at least to me:
    ''Why implement the changes now... when we can implement them a week later next to all the other changes we plan on implementing anyways?''
    Section9 and Mahtamori like this.
  11. Section9
    The classic, from @Bostria himself:
    :stuck_out_tongue_closed_eyes:
    Shiwen, Ariwch, Gunmage and 3 others like this.
  12. Gunmage
    Gunmage General Contact Unit
    So that's how isolate works on Remote Presence troops. I always wondered about that.
  13. colbrook
    From Facebook:
    Haido Special Support Group
    Special Fireteam. Wildcard Trooper. Up to 1 Haido can join any Fireteam
    Tai Sheng Zuyong Invincibles NCO
    Counts as a Zuyong for Fireteam composition
    Zuyong invincibles
    Special Fireteam: Haris 1 Zuyong (Fireteam: Haris) + 2 Yan Huo FTO
    Son-Bae Yaokong
    Special Fireteam. Wildcard Trooper Up to 1 Son-Bae can join any Fireteam
    Yan Huo Invincibles
    Yaopu Pangguling
    Special Fireteam. Wildcard Trooper Up to 1 Pangguling FTO can join any Fireteam
    Shang Ji Invincibles
    Special Fireteam. Wildcard Trooper Up to 1 Shang Ji can join any Fireteam
    SpectralOwl likes this.
  14. paraelix
    paraelix Seed Embryo Scholar
    Now the wait to see which profiles these are...
    Any of them are actually pretty scary - burst 3 missile launcher is pretty heinous.
  15. Triumph
    This one bothers me. If the Son-Bae isn't getting an FTO tag then there's the possibility that it's not getting a regular ML profile and is stuck with Guided. Guided has a big problem in Season X because of the prevalence of deployable civilian models being able to block template attacks, which happens to be another issue the Liu Xing faces that people like to overlook.
  16. colbrook
    Druze and Ikari get the choice of either ML or SML.
    OS only get the option of ML, though it pays a premium over the (unlinkable) SML.
    Guess we'll find out soon.
  17. SpectralOwl
    Ran into this myself a few months back, with the GML not being able to finish off a Datatracker hiding behind a HVT. Wouldn't have swung the game, but sucked nonetheless. On the bright side, there is a chance the Son-Bae may pick up a Feurbach or HGL profile or something as well as a ML for more variety.
  18. Maksimas
    Linked HGL ofboyo.
  19. Koni
    Koni BanHammer
    Will have regular ML profile.
    Xeurian, Shiwen, Section9 and 11 others like this.
  20. Stuffist
    Stuffist Well-Known Member
    owo
    Those remotes wildcards are actually great. :D
