Infinity Dice Calculator
Discussion in 'News' started by toadchild, Dec 5, 2017.
  1. Ashtaroth
    Not all heroes wear capes.
    zapp, Ugin, toadchild and 2 others like this.
  2. toadchild
    As always, you are all very kind.
    Florian Hanke and Daniel Darko like this.
  3. Barrogh
    Barrogh Well-Known Member
    I mean, I don't know what toadchild wears when he codes.
    jherazob and RolandTHTG like this.
  4. toadchild
    Not a cape.
  5. inane.imp
    Underwear outside your tights then?
  6. toadchild
    Slowly making some progress. From the dice roller perspective, the changes from N3 to N4 are actually much more involved than the changes from N2 to N3 were. This afternoon I spent some time disentangling things so that saving throws are now a weapon property instead of an ammo property. Unfortunately I still have a ways to go before I'm quite ready to share a link.
  7. toadchild
    I haven't been able to make progress on this lately, but wanted to share the link with people to start playing around with: http://inf-dice.ghostlords.com/n4/
    No unit data built in, so lots of manual entry, and not everything is supported yet or updated to N4 rules yet.
  8. Triumph
    I've been using it for a few days now, it's working well enough that I can illustrate arguments with it so keep up the good work.
  9. toadchild
    Heh, guess the URL wasn't so unguessable after all.
    Glad you're finding it useful!
  10. Lesh'
    Lesh' Infinity LATVIA
    the new crit mechanic is in, right? so basically we can configure everything what we want with current setup.
    and you've mentioned that some skills are not yet properly implemented.
  11. toadchild
    New crits are in!
    A bunch of special rules need at least minor tweaks, but I think I've got most of the core mechanics fairly solid. T2 is going to be a giant pain, because the extra saves from crits are only 1 wound, not 2. Berserk needs to be parameterized so that it can have different mods. Ikohl needs to be redone to reflect the new rules and FAQs for CC(-X) skills/weapons. The martial arts table needs to be updated, and protheion needs to be redone to not require the use of a special weapon. The list goes on, but almost all of those can be worked around if you manually set the right values.
    inane.imp, Barrogh and Lesh' like this.
  12. Triumph
    Actually I checked my posts it's more like a couple of weeks, I linked someone to it in the JSA forums in late january. Were Crits working correctly on the 25th?
  13. toadchild
    Yeah, I did that part a couple months ago - you can page back in this thread to find when I said I made those changes.
    Anyway, consider it officially in beta now.
    wuji, Barrogh, Reece and 4 others like this.
  14. jfunkd
    I was trying to see what Kriza in a Fireteam could do vs Armored targets. :cry::cry:
    Love your work as always @toadchild thanks for making the WIP available to us!!
  15. toadchild
    I can increase the per-player burst cap to 6, but for performance reasons, the overall maximum burst is going to remain at 9. Linked Kriza vs. a TR HMG is going to remain impossible to calculate.
    wuji likes this.
  16. Triumph
    #276 Triumph, Feb 11, 2021
    toadchild likes this.
  17. toadchild
    Yeah, if you check the raw output, the 1.188% chance for 2 wounds corresponds to the 4.750% crit chance (causing two hits) followed by failing both armor saves.
  18. Ugin
    Hello, mate! I just wanted to check out if others have the same problem I now have. The Calculator shows no other unit selections other than the custom unit.
  19. Robock
    Robock Well-Known Member
    That is what i have too. I feel like the calculator was not able to pull the N4 unit data and therefore we have to enter it as a custom unit every time we use the calculator.
  20. toadchild
    That is correct, I was not able to automate a system for adding unit data to the N4 calc.
