Infinity Army Bugs
Tema en 'Infinity Army' iniciado por toadchild, 15 Dic 2017.
Estado del tema:
  1. WarHound
    WarHound Well-Known Member
    7 Ene 2018
    printout for kiranbots in English doesn't list any weapons for them.
  2. Datlasiq
    Datlasiq Well-Known Member
    11 Feb 2018
    en el perfil de mukhtar OA, al sacarlo en pdf no aparece escrita la habilidad de Observador de Artilleria tanto en español como en Inglés.
    Por otro lado, que el perfil del gangbuster solo ponga Madtrap en lugar de MadtrapS, es casualidad o errata?
  3. Ingrimm
    Ingrimm Member
    9 Mar 2020
    Hi, I recently added a PanO SpecOps to my army and equiped him with a Hacking Device. But there are no programs that are available in my List maybe because he is not mentioned to be a Hacker.
  4. VisOne
    VisOne Member
    28 Ene 2018
    Simple filtering bug in the new release.
    Get our of here TAG your not a LI yours drunk. :P
    YES I am aware its because of the pilot but not other man TAG shows up like this so its a bug. ;)
  5. Robock
    Robock Well-Known Member
    And the pilot use a silent F when he talks about his job (i'm a blue wol pilot) ;)
  6. Sungwon
    Sungwon Well-Known Member
    21 Oct 2018
    Army app(android) does not have hospitaller doc with haris in SWF.
    Adjuntos:
  7. Dr.Gonzo1909
    Dr.Gonzo1909 New Member
    6 Sep 2018
    Android app and browser version do not display d.e.p. if chosing seed-soldier paramedic. PDF also
    Adjuntos:
  8. Sabin76
    Was the Kunai Solutions Ninja supposed to be accessible to vanilla CA? I don't see it in any sectorials or vanilla at the moment.
  9. colbrook
    In C1
    A Reece y Sabin76 les gusta esto.
  10. DukeofEarl
    DukeofEarl Well-Known Member
    27 Nov 2017
    Pretty sure if it is not in the PDF it isn't supposed to be on the unit
  11. ThananRollice
    30 Nov 2017
    The Peacemaker profile is messed up on the Android mobile app.
    The profile is supposed to look like this:
    But it looks like this, and doesn't allow me to add it to my list:
  12. Amusedbymuse
    1 Dic 2019
    Few things with White Banner stuff:
    1. White banner logo when choosing faction is missing in PC version of Army List. Also logo is missing both on PC and Android in saved Lists, both local and on account.
    2. Adil Mehmut and his Kuang Shi control device. In Army List he has it only in ISS and not base YJ, is it a bug or ISS exclusive feature? Either way even in ISS when Kuang Shi are put in combat group with Adil but without Celestial Guard ITS Check report says you cannot do that.
  13. Reece
    Reece EI Aspect
    21 Feb 2017
    The note that up to two Orcs can join any Fireteam Core in Svalarheima only shows up under Orcs and Fusiliers. It's missing from Nisse and Vargar.
  14. ZKRobi
    ZKRobi Member
    26 Oct 2018
    Some Code One Yu Jing anomalies:
    Ninjas have Hidden deployment, but there is no such skill in the Code One rules :)
    One of the Quing Gao profiles have Pistol (+1 burst), the other one 2x Pistol.
    Not a bug, but it hurts my big time as it never works properly on my phone: the Army Code import and export is still a single line text box instead of the multiline field.
  15. FreezeZ
    FreezeZ Well-Known Member
    30 Ene 2018
    Riotstoppers have adhesive ammo in Army and PARA in pdf.
  16. Nuada Airgetlam
    26 Ene 2018
    Code One Army layout borks up on ultrawide (2560x1080, 21:9), it uses only the 16:9 space. Please fix, N3 Army behaves properly at this resolution.
  17. Sabin76
    Just a general question: should there be a separate thread for CodeOne bugs?
  18. toadchild
    22 Feb 2017
    Kunai are listed as Mechanized Troops, which is normally limited to TAGs. Was probably supposed to be Mercenary Troops instead?
    A inane.imp le gusta esto.
  19. toadchild
    22 Feb 2017
    If you enable NA2 Mercs on Svalarheima, it allows you to add two Liang Kai to your list.
  20. inane.imp
    28 Ene 2018
    That's only slightly more illegal than using a BSG or EM weapon, so I don't see the issue ;)
Estado del tema:
