Infinity Army Bugs
  1. Bulletcore
    Bulletcore New Member
    Pi-Well's profile isn't appearing when I print the list. He is added, army is counting his points and his order, but the profile doesn't print under Zoe's like it used to. Using the web based App.
    Maniac-Eye likes this.
  2. Florian Hanke
    Florian Hanke Does not know how to stop building terrain.
    Thanks for the great tool!
    I was surprised to see FO etc. in the list‘s weapons list when adding just a single Cadmus (see image). Is this a bug or did I miss something?
    #742 Florian Hanke, Jan 13, 2020
  3. RomanLegion
    RomanLegion New Member
    I have the problem on 2 Android phones where the app will fail to load and get this 'the connection to the server was unsuccessful (file:///android_asset/www/index.html)'
    Anyone got a solution?
  4. colbrook
    https://forum.corvusbelli.com/threads/infinity-army-bugs.791/page-36#post-304390
    Put your phone in airplane mode, launch the app, turn airplane mode off again.
    The error seems to occur when you have a spotty or filtered Wi-Fi/data connection.
  5. Doa
    Doa Well-Known Member
    making list with qapu khalqi, I add a specops with ahd. Then add a couple of rem but the list wasn't correct. The army doesn't see specops as hacker
  6. Doa
    Double message
  7. Maniac-Eye
    Maniac-Eye New Member
    still bugged
  8. Doa
    In hassassin bahrami if you use the specops as hacker and field remotes, the army doesn't validate the list
  9. QueensGambit
    [Solved, not a bug].
    #749 QueensGambit, Jan 25, 2020
  10. colbrook
    If you're the same person that posted on Facebook you had McMurrogh, Valk, and Avi, so were over the 75 point SoF limit.
  11. QueensGambit
    I'm the guy replying to the guy on FB but yeah, problem solved. Thx :-)
    Not a "bug" but a feature request: make the error message more clear so that users know the issue with the list is >75 pts of mercs.
    colbrook likes this.
  12. PPB_Timmy
    PPB_Timmy Just Timmy!
    Hi,
    the Aragoto KHD profile lacks the Hacker Keyword behind the name of the unit.
    Cheers
    Timmy
  13. Major_Gilbear
    Major_Gilbear New Member
    Hi,
    In the Ariadna Merovingian list, Armand Le Muet has been replaced with Knauf... Surely an error?
  14. colbrook
    Le Muet has never been in Merovingia. Knauf has been in there since Knauf was released with the Outrage comic.
  15. Hachiman Taro
    Hachiman Taro Inverted gadfly
    When I add Jazz FTO to a list in Corregidor it seems to add Billie to the PDF / Print out of the list when Bille is not in the list, Screenshot 2020-01-31 06.59.23.png Screenshot 2020-01-31 06.59.05.png
  16. DukeofEarl
    DukeofEarl Well-Known Member
    Printouts from Army are including the Forward Observer Skill on Seed Embryos. [​IMG]
    Florian Hanke likes this.
  17. danilapal
    danilapal Member
    Missing description in mobile version and Android app (Jazz - UPGRADE:Maestro)
  18. inane.imp
    As per @danilapal post above, Billie is labelled on Infinity Army with an ISC of 'Support Troops'. When the 'Character' ISC became important @HellLois stated that "if it has a unique name it must be considered a character". Based on that, Billie's ISC appears to be a bug and it should read "Character".
    Jazz and Billie's profile version released as part of the Defiance Kickstarter does not list Billie's ISC at all. [​IMG]
  19. Bobblehead
    Bobblehead Well-Known Member
    Netrods have the REM classification making lists without hackers illegal in ITS.
  20. VisOne
    VisOne Member
    Screenshot_20200222-100355.png Found the following spelling mistake nothing serious.
    Invincibles spelt Invencibles in dashat company using Army 5 from my Pixel 2 XL.
