Infinity Army Bugs
  1. meikyoushisui
    Taagma Specops are missing the Fireteam:Triad skill.
  2. kensai
    kensai Member
    3840 x 2160
    on a second system with 1600 x 900 , there is no error
  3. Nuada Airgetlam
    After putting in a different value of pts and pressing Enter, the army list box text gets moved up and doesn't show a slider on the side.
    I cannot rename the list like this, for example.
  4. Ben Kenobi
    Ben Kenobi Well-Known Member
    Deva-SpecOp
    BTS can go till 12, seems to be a bug, cause other base profiles have a BTS value of 0
  5. Sabin76
    Nexus SpecOps starts with BTS 3
  6. colbrook
    You can buy 3 x +3 BTS increases, so that's working as designed.
    Celestial Guard Spec-Ops have been able to reach BTS 12 since inception.
  7. meikyoushisui
    This isn't a bug, the base Nexus profile has BTS3.
  8. Sabin76
    Yeah, I didn't make my post clear. I was responding to @Ben Kenobi to say that there are other profiles that start with BTS 3.
  9. Robock
    Robock Well-Known Member
    When adding SoF Mercs, their fireteam allowance (but not the notes) is added to the printed fireteam chart, even though they are not part of that sectorial's complete fireteam chart. It is almost perfect, as without the notes, you are limited to making fireteam out of the same unit. Which even for CSU is only AVA 1 for Mercs and KTS don't have the Haris loadout in mercs. But it would be even more perfect if they were outright removed from the chart.
  10. Aspect Graviton
    Spec opps problem, if you select an option with holo projector it's not got the Holoprojector option when requesting a courtesy list.
  11. Abrilete
    Abrilete Well-Known Member
    So... any news?
  12. JakeOlantern
    JakeOlantern New Member
    Why does the Shukra's Counterintelligence show up in the courtesy list if it is private information?
    Abrilete and Robock like this.
  13. Russ
    Russ New Member
    Asura Lieutenant L2 also shows up on the courtesy list but (per the wiki) should be private information.
    JakeOlantern likes this.
  14. toadchild
    For spec-ops, max PH value (14) is not applied.
    A Morat spec-ops with two PH upgrades shows as PH 15.
  15. ChoTimberwolf
    In Tohaa Reex have Special Fireteam Triad 2 Reex + 1 Kriigel
  16. Ariwch
    Haqqislam SpecOps with Assault Hacking Device does not count as allowing to field remotes.
  17. toadchild
    Nexus Spec-Ops has a Shasvastii logo (old seed-soldiers logo?) instead of the logo base Nexus and Kerr-Nau use.
  18. Sabin76
    Only in Vanilla. Onyx has the correct logo.
    toadchild likes this.
  19. Ben Kenobi
    Don't know if it's a bug or intended, but Bashi Bazouke has the Special Operativ profile and in the wiki it 8s mentioned to be only for Druze
  20. NorthernNomad
    NorthernNomad Well-Known Member
    When you have EI Hacking Device in a list with a HD+ or AHD, army incorrectly lists the EI HD as being able to use Claw 2 programs.
