Infinity Army Bugs
  1. Brother Smoke
    Mobile app won't run unless connected to wi-fi. Throws out unsuccessful connection error
  2. Zoe
    CB Staff Warcor
    The latest version is the 6.7.4 and, as you say, you can download it from here::https://www.infinitythegame.com/resources/tools/infinityarmy
    Try again, please.
  3. eciu
    eciu Easter worshiper
    Well apparently windows x64 version is still 1.7.10 as it is the value in the "version" file. (even though I've just downloaded the fresh).
    So apparently x64 has problems as I've installed 32 bit one and it works fine.
    Also: would be probably good to update the "version" file as it doesn't match the version reported inside the application (also maybe adding version info to executable assembly?).
  4. DukeofEarl
    DukeofEarl Well-Known Member
    NA2 SpecOps are showing a 0XP cost Vulkan Shotgun option. No option for it at all in my book
  5. colbrook
    They're also showing an option for an EVO Repeater which doesn't exist any more!
    meikyoushisui and DukeofEarl like this.
  6. meikyoushisui
    Tohaa specops is completely broken. Doesn't display at all.
  7. DukeofEarl
    Came up for me. Though the first box for Weapons and Equipment are displaying oversized and with the text in black until you hover over it.
  8. Hiereth
    Hiereth AI Artichoke
    That's a Muyib? Stat line though
  9. DukeofEarl
    I was looking at Muyibs before changing armies...
  10. meikyoushisui
    Spiral Corps has the NA2 Spec-Ops options (not sure if this is a bug, but it is kind of weird since their specops is a Tohaa)
  11. DukeofEarl
    They are an NA2 army so that would be correct. Same as JSA
  12. Insertdumbnamehere
    Insertdumbnamehere Active Member
    NA2 Spec-Ops has a 0xp Vulkan Shotgun, as mentioned above, that should be a 6 xp Molotok. Their 1xp Heavy Pistol is 2 Heavy Pistols in the book's chart, would like to know if that's an error in Army or an error in the book.
  13. meikyoushisui
    Are we sure about this? I was under the impression that the specops is a Taagma rather than a Brawler for mechanical reasons rather than just fluff reasons.
  14. DukeofEarl
    The SpecOps options are assigned by army group, not by SpecOps unit type, so it holds water.
  15. gregmurdock
    Nomads and all sectorial Spec Ops have plasma sniper (4) when it should be shock marksman (4).
  16. TheDiceAbide
    @Zoe keep up the good work! One more thing to note is that the Spec Ops should count against the AVA of the unit they're drawn from now.
    Robock and DukeofEarl like this.
  17. RobertShepherd
    I currently cannot load Tohaa lists using the web version of Army. Mobile app works fine.
    Sample list codes:
    MAAT76TC
    BwBgjAPgzCIQogDwMYBsCuBnAlgewHYAEAWgQKaaEByuhA4gIa4C0ASg2aptAOwCkYGADY+AFmABWEQEJgfIRKh8ATMqEBOPrPmKVazdOXzR/VaNFblIPjzCbloqEu0KlqjVrAT5Q66uDOgjpy/tbSYNYK3qo8gZES0cqxfAACDjbq1jBQcobWtvaOznKueh7SUBZgysBGJgmW3jzqYHwwjo0Zre1xOonJ4fH9SikpQA
  18. Mcgreag
    Mcgreag Well-Known Member
    One more error for NA2 spec ops, It has D-Charges listed twice, second listing should have been Grenades (2).
  19. RobertShepherd
    Update: can now no longer load Tohaa lists on mobile app either.
    OrderMonkey likes this.
  20. Hiereth
    yep cause they pushed the busted desktop stuff straight to the mobile app :/
