Infinity Army Bugs
  1. Zoe
    CB Staff Warcor
    The names of each army are written without following any typography. Imagine, Imperial service would be 无敌军, as this is how it appears in logo.
    True.
    It happens whenever a skill slot is left unfilled before another that is filled.
    I take note. Thanks for the warning.
  2. BigBadFox
    BigBadFox Well-Known Member
    MetaChemistry L1 from the CSU:
    It says "Bioinmunity", "Bioimmunity" should be correct
  3. REDVENOM
    REDVENOM Member
    The TANKO has different logo in Ikary and in JSA.
  4. Mcgreag
    Mcgreag Well-Known Member
    If you add the Panzerfaust version of Yuriko Oda to your list and then select the Weapons chart and set it to "list" it will not include Panzerfaust in the list but it will include E/Mitter.
    If you on the other hand add the E/Mitter version it will not have E/Mitter in the Weapons chart but it will have Panzerfaust.
    In both cases this also extend to the weapons chart that is printed with your list.
    Tested on the Android app and the web version of Army.
  5. locksmith
    locksmith comlog active
    Split AVA note on the non-motorized 112 in split MRRF should match the AVA note on the motorized 112. Currently, the non-motorized refers to a maximum AVA of 2, rather than 3. The motorized Split AVA note correctly refers to a maximum AVA of 3.
    As always, thanks for what you do, @-V- & @Zoe !
  6. Zoe
    CB Staff Warcor
    Fixed
    Fixed.
    True! It happens in JSA, but not in YuJing. :thinking_face:
    Fixed.
    Fixed.
    I will update all the versions throughout the morning.
    Thank you, everyone.
    inane.imp, Sabin76, locksmith and 2 others like this.
  7. Eightballz
    Eightballz Well-Known Member
    When saving and loading Lists i get the message "Army Code is wrong".
  8. Zoe
    CB Staff Warcor
    Saving on server or local? Does it happen with all lists? If not, pass me the code on the list, please.
    Eightballz likes this.
  9. Eightballz
    Was savin on Server and on local. When I generated a Code and tried to open it - there was same mistake. But two Hours later it worked. :/ Internet Connection was working. Browser were IE and Chrome.
  10. Zoe
    CB Staff Warcor
    IE... :see_no_evil::skull:
    Ok. If this fail again, let me know.
    Thank you!
    :blush:
  11. Sven F.
    Sven F. Dismember
    Right sidebar ("Options"), it says Tabla de Fireteam in the English version.
  12. Zoe
    CB Staff Warcor
    Ok. I take note.
  13. [Ghost]
    [Ghost] Member
    Since introduction of 112 (motorized) the non-motorized version no longer states that it can be part of a Fireteam. I think this is unintended as the motorized version emphasizes that it cannot. (all Sectorials)
    Nuada Airgetlam likes this.
  14. Ben Kenobi
    Ben Kenobi Well-Known Member
    Army mobile Android App and Webapp
    PanO-Varuna
    Spec-Ops has no entries for weapons in dropdown menu
  15. Nuada Airgetlam
    After recent updates, as I'm adding units in browser Army, the list window is not resizing properly and keeps adding new entries but doesn't change size every odd entry. This forces me to manually resize the window and is really annoying. Every other (even) new entry it resizes again, but for an odd number of entries in the list, it stays "a line to small".
    So, the first entry is not visible (just the order count line), after adding 2nd both are visible. Add 3rd and it's not visible. Add 4th and all are visible and so on.
    It should add a line of window size every time an entry is added.
  16. Nuada Airgetlam
    Also, not sure if intended, but are all lists saved only locally? I'm logged in with my CB ID on both desktop and mobile app and when I save a list on desktop, it doesn't show up on my mobile app. I need to send myself the number and manually import.
    Is this a completely missing functionality (saving lists server side) or is this a bug? I'm using the Android app (not sure if there's an Apple one).
  17. tox
    When you save a list, you have two tabs. Local is, well... local. ITS is server based and are the ones you can add in OTM for tournaments.
  18. Nuada Airgetlam
    Ooooh. Damn, that's not really intuitive :D
  19. Zoe
    CB Staff Warcor
    True!! Take note.
    Ok. Take note.
    What browser do you use?
    I can't reproduce this error. Is it with all lists? Can you send me a screenshot?
    Ben Kenobi likes this.
  20. tox
    @Zoe @Koni @HellLois and whomever is involved....
    Now that we have the "Special Fireteam" Option listed under the units (like this)
    wouldn't it be time to remove the non-existent Fireteam: Core skill and add the relevant info (Core/Haris/Duo) with the list below?
    For the Yadu Troopers, the list could be:
    Fireteam: Duo, Haris, Core.
    Special Fireteam: Haris. 2 Yadus + 1 Deva.
    Special Fireteam: Haris. 2 Yadus + 1 Asura.
    Special Fireteam: up to 1 Rudras can join any Yadu Troops Fireteam.
    Special Fireteam. Shakti counts as a Yadu Trooper for Fireteam composition.
    inane.imp, DukeofEarl, Robock and 3 others like this.
