Infinity Army Bugs
Tema en 'Infinity Army' iniciado por toadchild, 15 Dic 2017.
Estado del tema:
  1. Ayadan
    25 Nov 2017
    I've discovered when checking the rules of Drop Bears that there is a conflict in the MODs given by the Rulebook/Wiki and Infinity Army: the MOD for the range 8"-16" is -3 in the Rulebook/Wiki and -6 in Infinity Army. So which one is the good one?
  2. ijw
    25 Abr 2017
    It should be -3, the same as Grenades.
  3. -V-
    -V- A! Team member
    31 Ene 2017
    It will be updated next time. Thank you both!
  4. Dhan-Keth
    Dhan-Keth New Member
    28 Nov 2017
    Hi!
    I don't know if it is a bug or a mistake but in the hacking chart the EI HD appears to have access to the claw lvl2 programs.
    The rulebook states that it should only have access to lvl 1.
    Am I missing something?
    Thx!
  5. gregmurdock
    When will the Kamau HRL and Kriza Borac MK12 LT be fixed in english Army?
  6. eciu
    eciu Easter worshiper
    A ijw le gusta esto.
  7. eciu
    Yay, seems it's fixed ^^ (finally)
  8. Yvain
    Yvain Well-Known Member
    2 Dic 2017
    So lately, I can't seem to get the program to work correctly.
    After I install and try to run the link via the shortcut, it never is able to connect to the server to search for updates. If I hit cancel, program just terminates instead of opening. Anyone have this problem?
  9. Rannith
    Rannith Well-Known Member
    1 Ene 2018
    Is there a version that gives functionality when you don’t have net access?
  10. gregmurdock
    When will the Army app get the latest update?
    A Reece le gusta esto.
  11. Zoe
    CB Staff Warcor
    23 Ene 2017
    Soon, I promise.
    :pensive:
  12. Zoe
    CB Staff Warcor
    23 Ene 2017
    The app doesn't need a connection to work. You only need one connection to save your lists on the server.
  13. Rannith
    1 Ene 2018
    Whenever I try to use it without an active net connection I get the interface frames but no unit data.
  14. xagroth
    Since I changed my phone to a BQ Aquaris U, I have to start the Army App twice... once is always a failure in a black screen, then I remove the screen and launch again, and it works.
    Executing that second time in plane mode works fine.
  15. Rannith
    1 Ene 2018
    Is there a mobile device app that does not require a net connection to work?
  16. gregmurdock
  17. Rannith
    1 Ene 2018
  18. jackfrost
    jackfrost Active Member
    If they're going to remove it from there they need to put it somewhere else. The army builder should have all the info you need to build a list in it.
  19. Barrogh
    Barrogh Well-Known Member
    26 Nov 2017
    Perhaps add to fireteam options box that is currently only displayed for units with Special Fireteam options?
  20. Rannith
    1 Ene 2018
    Yuan Yuan (Fat or otherwise) do not appear to be available in Inf Army.
    Also apart from Knauf none of the Outrage people seem to be there. This may be just timing but the Yuan Yuan has been around for a while.
Estado del tema:
