Infinity Army 7 (N4) Updates & Bugs
Tema en 'Infinity Army' iniciado por Koni, 25 Sep 2020.
Estado del tema:
  1. toadchild
    22 Feb 2017
    Army: Combined
    Version: ios app
    Troop: Kendrat
    Issue: Kendrat is not available in vanilla CA
  2. toadchild
    22 Feb 2017
    Army: MAF
    Version: ios app
    Troop: Kendrat
    Issue: Kendrat has two profiles that are completely identical, except the second one has Duo. There does not seem to be a reason for both to exist.
  3. Mahtamori
    Army: ISS
    Version: Android app
    Troop: Yudbots
    Issue: 3 or 4 yudbots in same group as Sophotect doesn't validate, app says the peripherals need to be in the same group as doctor/engineer. 2 yudbots work fine.
    #643 Mahtamori, 19 Oct 2020
    Última edición: 19 Oct 2020
  4. colbrook
    You can only have a max 2 Servants per controller, so that seems to be working as designed.
    It does raise the question why ISS get AVA4 Yudbots when they only have a single AVA1 Doc/Engi though.
    A Mahtamori le gusta esto.
  5. Mahtamori
    Ah, thanks, I see the issue...
    Army: ISS
    Troop: Yudbots
    Issue: AVA at 4, should be 2 according to Sectorial Chart
  6. kensai
    kensai Member
    7 May 2018
    that seems awfully clunky... maybe ISC should be the primary sorting by default.
    A toadchild le gusta esto.
  7. colbrook
    Army: NA2
    Troop: Snr Massacre
    Issue: Not sure if intentional but N4 Regeneration no longer contains Immunity (Shock), so Mr. Deadpool is now vulnerable to Shock ammo.
  8. JordanJoestar
    JordanJoestar Member
    26 Sep 2020
    • Army: Varuna
    • Troop: Clipper Dronbot
    • Browser used & Operative System: Chrome and ios app
    • Description of the bug: Has note "the Varuna Div. option can wildcard" but there is no Varuna division option. I'm not sure if its vaguely referring to the fact that clippers in Varuna are counting as "Varuna Div" which I find unlikely since in N3 they had an aquatic terrain profile called the Varuna Div version that could link.
  9. meikyoushisui
    28 Nov 2017
    Troop: Neema Saatar
    Bug (Potentially): Neema's Advanced Command (+1 Command Token) was replaced with +1 LT Order.
    Just want to make this visible again -- it looks like @Engorn mirrored my sentiment on the forums en espanol slightly after my original post, but we still have not received confirmation about whether this is correct or not.
    A Engorn le gusta esto.
  10. Dragonstriker
    3 Dic 2017
    I believe it is, which is why sorting by name causes an unexpected order (based on the description of the problem earlier)
  11. Lucian
    Lucian Catgirl Nation
    27 Nov 2017
    Can you bring back "show type" option? It really helps to visually search for certain units in horizontal menu.
    A SilkyDJ, Daniel Darko y Delta57Dash les gusta esto.
  12. the-cultist
    the-cultist Member
    23 Oct 2019
    Army: every
    Troop: every troop with x-visor
    Issue: Link to Wiki does not work.
    Solution?: found out that wiki is x-visor (with a dash) and troop ist x visor (without dash) maybe thatll help...
  13. tox
    21 Feb 2017
    It is not supposed to work yet.
  14. ijw
    25 Abr 2017
    The app has linked to the wiki pretty much since launch.
  15. chromedog
    Tuesday, October 20, 2020 (last time used. Army gets used only when I MUST use it).
    Windows 10. Firefox browser. O-12. Army crashed on attempting to print (multiple times). Printer was on and awake.
    First time I've used it for N4 (I only play a few times a month at most).
    When will the courtesy list function be enabled. This app is at best, half-functional until then (i.e. an ios app :p )
  16. paraelix
    paraelix Seed Embryo Scholar
    31 Ene 2018
    Army: Combined Army
    Version: Android app and Browser (Chrome)
    Troop: Sargosh
    Issue: Sargosh is a Jayth Cutthroat but has Martial Arts Level 2 instead of Martial Arts level 3, like all other Jayth?
    This on top of his profile having a light shotgun instead of light flamethrower, and only having a DA ccw (like all other Jayth) despite having a big drill arm... Feels like balls were dropped on this profile...
  17. toadchild
    22 Feb 2017
    Army: Druze
    Version: iOS app
    Troop: Anaconda
    Issue: In the sectorial chart, anaconda does not have duo. The skill should not be present.
  18. paraelix
    31 Ene 2018
    Army: Combined Army
    Troop: Seed Soldier + Cadmus
    Issue: Silhouette for both Seed profiles is '0'. Silhouette 0 doesn't exist in N4 and should be 'X'? Or Rulebook needs to be updated to explain what S0 is.
    A Reece le gusta esto.
  19. toadchild
    22 Feb 2017
    Army: PanO
    Version: Chrome
    Troop: Tikbalang
    Issue: Tikbalang does not have a Dodge (PH=XX) skill on its profile. It appears to be the only TAG in the entire game that dodges on full PH. Is this intentional?
    A Delta57Dash y Teslarod les gusta esto.
  20. Arhnayel
    Arhnayel Member
    13 Oct 2020
    Army: Corregidor (possibly also Nomades generalist and all other armies having access to Geckos and Jazz & Billie)
    Version: Windows 10, Firefox/Edge
    Troop: Jazz & Billie, Geckos
    Issues: * when printing my list (composed on Firefox first, then loaded with Edge to use the "print to pdf" option - see https://forum.corvusbelli.com/threads/infinity-army-7-n4-bugs.37729/page-31#post-371769), the Gecko Pilot does not have his Assault Pistol (+1B) and his CC Weapon, and the Terrain Skill does not mention Zero-G.
    * When printing the list, Jazz appears without UPGRADE: Trinity (+1DMG) ; her PARA CC Weapon and her Pistol are also missing. Same for Billie.
Estado del tema:
