Infinity Army 7 (N4) Updates & Bugs
  1. AmPm
    AmPm Well-Known Member
    • Army: JSA
    • Troop: Keisotsu
    • Browser used & Operative System: Chrome 85, Win10, Android
    • Description of the bug: States that Kempeitai can be part of a Core Link of Keisotsu; Kempeitai are Wildcards. Extraneous note.
  2. kensai
    kensai Member
    • Army: all
    • Troop: mercs
    • Browser used & Operative System: Firefox 81.0 Win10-64bit
    • Description of the bug: toggling NA2-Mercs on and back off does not remove them from the list, also mercs are listed as options twice NA2-lists (or is this intentional)
  3. kensai
    kensai Member
    • Army: all
    • Troop: all
    • Description of the bug: troops are not listed alphabetically, naming is inconsistent
    https://imgur.com/a/S16MB8m
  4. Nuada Airgetlam
    Not a bug, you did not enable sorting by Name in Options.
  5. toadchild
    Army: Combined
    Troop: Bit & Kiss (updated)
    Version: ios app
    Issue: Kiss has a repeater in its equipment line; should be removed so that only the (Repeater) version has a Repeater.
  6. schlaf
    schlaf New Member
    can confirm inconsistent alphabetical order.
    croc men appears at P place instead of C as expected, the title of the unit description is "paradiso croc men"
    --> solution, sort on the "short name", not the full descriptive name, or make sure both are alphabetically consistent.
  7. archon
    • Army: Nomads CJC
    • Troop: Salyuts
    • Description of the bug: AVA is 1 but in the oversight picture showed with the N4 videos its AVA 2 (wich makes sense for the engineers sectorial;-)
  8. VisOne
    VisOne Member
    Sorry if this is already being reported I don't have time to dig through the thread.
    • Army: Onyx contact force
    • Troop: Multiple
    • Browser used & Operative System: Chrome - Win 7
    • Description of the bug: When I printed out my list onto A4 paper one column was all imperial measurements one column was all metric measurements.
    P.S. I believe there was another issue but I don't have the list with me at the moment but this way the obvious one that really threw me.
  9. Tourniquet
    Tourniquet TJC Tech Support
    Army: Corregidor
    Troop: Jaguar
    Browser: any
    Description: Asking for clarification, is the Jaguars no longer having stealth intentional?
  10. paraelix
    paraelix Seed Embryo Scholar
    Bit is also missing Pistol/CCW on the KHD profile.
    Also, were the costs increased for both B&K versions intentionally? Because functionality was removed from both and they both now cost more than they did.
    toadchild likes this.
  11. M0rk4
    M0rk4 Member
    • Army: ariadna / tartary army corps
    • Troop: kazac spetsnazs
    • Browser used & Operative System:App
    • Description of the bug: the sniper loadout cost 1,5 swc instead ou 0,5
    • Army: all
    • Troop: flammenspeer
    • Description of the bug: the hit mod is just a blast mod without blast template
    • Army: haqqislam
    • Troop: daylamis
    • Browser used & Operative System: app
    • Description of the bug: the two panzerfaust versions cost the same points
  12. ijw
    Almost all Warbands lost Stealth in N4. It’s intentional.
    Dragonstriker and Tourniquet like this.
  13. Aemaru
    Aemaru Well-Known Member
    • Army: spiral
    • Troop: aelis
    • Browser used & Operative System: firefox pc / ios app
    • Description of the bug: not showing haelis as a wildcard when n4 fireteams charts does
  14. paraelix
    • Army: Combined Army
    • Troop: Sphinx
    • Description of the bug: Loss of Stealth?
    • Army: PanO
    • Troop: Cutter
    Trying to understand in what world an O'Yoroi has Stealth but the two Stealth TAGs do not...?
    LaughinGod likes this.
  15. Reece
    Reece EI Aspect
    Confirmed. They do not have Stealth.
  16. colbrook
    Fancy optical systems that hide you from sight do not make you quieter, the O-Yoroi has clearly been specially optimised to fit the martial ethos of JSA.
  17. paraelix
    • Troop: Cadmus-Seed
    • Description of the bug: Profile has Surprise Attack (-3) with no ability to gain a marker state that allows use of Surprise Attack.
    EDIT - nevermind, Surprise Attack functions off any Marker State. Seed-Embryo just seems to be the only Marker State rule that doesn't actually call out the combined functionality...
    #617 paraelix, Oct 14, 2020
  18. Zoe
    CB Staff Warcor
    I'm noting it down.
    Units are listed using their ISC instead of their name. For that reason, whenever you sort by Name, the "Paradiso CROC MEN" unit appears in the "P" position, even though their ISC is "Croc Men"
    Nuada Airgetlam likes this.
  19. Arhnayel
    Arhnayel Member
    Army : Corregidor (but certainly all of them, didn't try the others).
    Browser used & operative system : Firefox 81.0.1, Windows 10
    Description of the bug : I can't print the army list from ARMY 7. A little window appears in the superior left corner of my screen, in minimum size (I can't even read my list) then the window to select a printer appears. When I click on "print" after having selected a printer (e.g. print to pdf), nothing happens (no download windows/pop-up) except for my browser to crash sometime.
    I tried to print the list while having :
    - authorized pop-ups ;
    - deactivated AdBlock+ ;
    - deactivated my antivirus.
    Nothing could fix the bug...
    I could print my list using Edge, but the copy/paste link didn't work (my army list didn't appear). I had to log in and load the list from the server, and then print it.
    But - second bug : the Gecko Pilot appears in the printed list without its CC weapon and its Assault Pistol (+1b). It has only the Combi Rifle.
  20. HellLois
    ARMY FIX LIST – 14-10-2020
    BIT: changes on profile (hacker without device is intended)
    Tracktor Mul: Added Note
    Kuryer: Added Note
