Ideals for new PanO tech
Discussion in 'PanOceania' started by andre61, Jul 28, 2018.
  1. MrNailbrain
    I think he meant "Add a 4th profile", which would be pretty baller, but I'd probably prefer one built on a new Guard chassis from the ground up.
  2. Golem2God
    I think the Aquila should keep his MSV3 but should also have Stratgeos. A nanoscreen would be a nice addition to the unit or any other PanO unit for that matter.
  3. andre61
    andre61 Well-Known Member
    Ok, that would very cool
    I agree.
  4. Zsolt
    Zsolt Well-Known Member
    Nanoscreen seems to me like lazy people's cover. It gives you some mobility, as you bring your own corner with you, but doesn't give you anything more that you can't get otherwise.
    theradrussian likes this.
  5. andre61
    Ok! may ask you. what do you think about Full Auto?
  6. Skoll
    Skoll Well-Known Member
    It also seems to vary wildly in cost. On some units its not so much, but it has to cost a metric fuckton on sheskin
  7. Zsolt
    I don't really understand why you ask this. Full auto is awesome. Burst then BS mods win firefights. It gives you both. It's like being in a Haris and having uncounterable mimetism.
    What's sheskin? Also am I missing some great use of nanoscreen?
  8. Death
    Death Well-Known Member
    [​IMG] Combined Army
    [​IMG]1
    [​IMG] SHESKIIN Lieutenant Red Fury, Pulzar, D-Charges / Pistol, DA CCW. (1 | 51)
    1 SWC | 51 Points
    A cute little Shasvastii thats kind of beastly in melee. Shes expensive for what she does though.
  9. Zsolt
    Didn't spend the time to break it down, but it has a lot of expensive stuff on it, not sure if actually the nanoscreen breaks it.
  10. Cartographer
    Nanoscreen cost must vary with (at the very least) BS, since Sheskin has Achilles' stats and his fabulous BS of 15, she pays for it.
  11. nehemiah
    nehemiah Well-Known Member
    That would require you to take the Lt option which is currently only the Multi Rifle.
    Though it would be cool if the non-Lt versions had the NCO rule that is on the HMG Yadu and is rumored to allow the unit use the Lt. order.
  12. andre61
    (IMO) I ask you about Full auto because, I would like to the Aquila get that, and just wanted to know your point of view.
  13. Stiopa
    Stiopa Trust The Fuckhead
    As much as I'd like to see FA somewhere in PanO - does it really fit Aquila?
    Now, a stationary turret REM with FA...
  14. Skoll
    She is a full 7 points over the samaritan spitfire, while having as close stats as possible.
    She has superior ph +bs . But he has hyper dynamics, super jump, more armor and a vorpal ccw (which also mono in melee) as well as a higher version of protheion (specifically the one that gives burst 2 and is prob at least 1 full point over lv 3)
  15. AdmiralJCJF
    Full Auto is one of those rules that I wouldn't really want to see on a PanOceanian unit, other than maybe a remote.
    We are supposed to be the disciplined, regular army. Spraying bullets into the air heedless of supply runs contrary to that.
    But on a remote, which could have nearly limitless ammunition available, it would be less egregious.
  16. HeckMeiser
    HeckMeiser Well-Known Member
    Or Assault Guard maybe. Their whole thing is supposed to be relying on overwhelming firepower more than armor, right
  17. Skoll
    Is it really ? Full auto fire in a target rich enviroment and aimbot on our guns... sounds pretty pano to me.
    Well maybe on a named tag character.
    Deltervees likes this.
  18. Shoitaan
    Shoitaan Well-Known Member
    I wouldn't mind seeing REMs in PanO that had modes via multiple profiles. Kind of like the old starcraft siege tank.
    Say its just a 6-4 rem with something defensive on it and ability that let it change profiles at the cost of 'stunning' itself. Then from the next turn onwards, its a 0-0 REM that's super killy with Full Auto, a variation of TR that doesn't interere with B in active turn and some other shooty things. Effectively a mobile turret that you wouldn't realistically 'deploy' more than once per game. Pick the wrong position and you've wasted the points. Pick the right position and your opponent better pray they're packing a lot of smoke or a lot of missiles.
    Also I'll say it again, AD TAG plx.
    I mean honestly, our TAGs are unamanned as well. Surely that makes the tech to drop a killer robot easier given all that cockpit weight capacity can go towards shock absorbtion or something.
    #58 Shoitaan, Aug 9, 2018
  19. Zsolt
    That's one of the problem with full auto, it's name, so it doesn't fit Pano.
  20. eciu
    eciu Easter worshiper
    Shitload of things seems to not fit PanO "because regular proffesional army', proper CoC, unit synergy and cooperation, optimized profiles (like irregular AD and regular FTO units xD) etc.
    Yep, PanO space is severly limited.
    AdmiralJCJF, Golem2God and injenegr like this.
