I got myself some MAS scenery and need advice...
Discussion in 'Scenery' started by Varsovian, Nov 16, 2018.
  1. Varsovian
    Varsovian Well-Known Member
    Hm. Thanks for the advice, I didn't think of that...
    BTW. What does this product do, exactly? Is this some sort of primer for car paint? Remember that I need to find a Polish equivalent, so I need to know what I'm looking for :)
  2. Section9
    Yes, it's the rattlecan primer for car paint. It etches the metal and sticks crazy-good to metal, fiberglass epoxy, wood, whatever. It also expands slightly so you can sand out small dents or whatever.
  3. rhelyk
    rhelyk Active Member
    A few extra tips:
    - assemble the MAS buildings BEFORE you paint them. Some companies have looser fit and can be painted in pieces, but MAS use a very tight cut and if you paint the pieces first they may not go together very well
    - enamel based spray paint/primer is the best to use on MDF and HDF because it doesn't soak into the wood fibres and creates a good seal on the wood, which can be painted over with acrylics and polyurethane paints/primers like any other material. I can't recommend a Polish brand since I don't know what's available, but most cans will say "spray enamel" or "fast drying enamel" somewhere on them. Automotive primer can work OK, but enamel based paints and primers are best.
    - small correction about primer: most primers do NOT etch into the metal at all, only specific self-etching primers do (they are specifically labeled as etching primer and are often more expensive). It has an acid and disolved zinc particls that eats into the metal and allows the zinc to bond with the outer surface, sealing the metal against corrosion and rust. It does NOT grip paint well, it's a metal sealer that you then prime over with regular automotive primer. We use it at my auto body shop only where we're doing repairs that are sanded down to bare metal to make sure that the repair doesn't rust. Regular primer doesn't etch anything, it just grips the surface really well. Don't use etching primer on miniatures unless you want your paint to rub off easily
    Xeurian and jherazob like this.
  4. Section9
    OK, I stand corrected then! Trust the man who uses the stuff professionally!
    I admit, my usual favorite primer is Krylon Fusion camouflage colors, not automotive primer.
