HVT and Smoke
Tema en '[Archived]: N3 Rules' iniciado por avanst, 3 Sep 2018.
Etiquetas:
  1. avanst
    avanst Member
    29 Nov 2017
    Can you put a smoke template onto a civilian model? If so what rule allows it?
  2. meikyoushisui
    28 Nov 2017
    Are there any rules against placing a smoke template on any model? The rules already have ways of handling smoke placed on a model, is there any indication those rules would not apply in this case?
  3. Mahtamori
    Do you possibly mean targeting the actual HVT, as in centring the template inside the HVT's silhouette as a way of not having to use Speculative Fire on the ground that the HVT is standing on when something's blocking LOF to that area of the ground?
  4. avanst
    avanst Member
    29 Nov 2017
    The civilian rules actually state that they cant be subject to any attacks. And any template that effects them are canceled.
    Smoke is an attack, template, even if its non-lethal. So I am interested in knowing if the smoke template touches an hvt or civi is it canceled.
    Especially because you dont get to place the template before you pick a target (the ground)
  5. n21lv
    n21lv SymbioHate
    27 Nov 2017
    I was about to respond that if you do not target the HVT specifically, you can land a Smoke grenade next to them, but then I read that the stack is cancelled automatically. I'm actually curious how it is possible to harm the HVT at all if any attacks that touch it are considered to be null.
  6. ijw
    25 Abr 2017
    It's a bit buried, but Smoke ammo says that it's not an Attack. Otherwise you could never place it over your own troopers, or drop Smoke at your feet.
  7. ijw
    25 Abr 2017
    @n21lv Jump and falling damage is about it.
    A A Mão Esquerda y n21lv les gusta esto.
  8. n21lv
    n21lv SymbioHate
    27 Nov 2017
    I couldn't find that in the Wiki. Is this a feat exclusive to Smoke, or any other non-lethal templates can be placed over the HVT model (Eclipse, Nimbus etc)?
  9. colbrook
    Eclipse works exactly like Smoke, so if Smoke is not an Attack then Eclipse is not an Attack.
    Nimbus is explicitly an Attack so cannot cover a Civilian.
  10. n21lv
    n21lv SymbioHate
    27 Nov 2017
    Again, I cannot find anything like that in the Wiki. Labels such as Attack are usually a part of the Skill description, but Smoke, Nimbus etc are Special Ammunition, so not sure how Attack applies here.
    The only thing that could be pointing to what @ijw wrote is the Non-lethal trait, but Nimbus also has it, as well as Stun grenades.
  11. colbrook
    http://infinitythewiki.com/en/Nimbus_Special_Ammunition
    4th bullet point of the effects
    • Firing Nimbus Special Ammunition is an Attack.
    The Smoke one is less clear-cut but I think it derives from this part (bolding mine):
    Smoke and Speculative Fire
    Certain weapons that use Smoke Special Ammunition allow the user to use the Speculative Fire Common Skill. In that case, the Common Skill Speculative Fire works normally, even though it is a Special Dodgeand not an Attack.
    Possibly it's clearer in the Spanish.
    A A Mão Esquerda, n21lv y inane.imp les gusta esto.
  12. inane.imp
    28 Ene 2018
    That means that you can't put Nimbus so that the template covers your own Troops?
  13. Hecaton
    No it doesn't. There are some implications that it isn't, but it never goes out and says it.
  14. Hecaton
    I guarantee CB doesn't play that way. Of course, they leave us to deal with the fallout of their slapdash rules...
  15. ijw
    25 Abr 2017
    Colbrook already quoted it up-thread. Please don't be obtuse.
    Based on?
    A FatherKnowsBest y A Mão Esquerda les gusta esto.
  16. Hecaton
    It reads more like there used to be an explicit declaration that Smoke ammo wasn't an attack, they decided to nix it from the rules, but didn't clean up this one passage - and it's being used in a cargo cult-style interpretation to claim that Smoke isn't an attack.
    The general "Just use common sense!" attitude we get from CB when rules are unclear that implies that they don't see situations like this as a problem.
  17. ijw
    25 Abr 2017
    We've had this conversation before. That you don't like it doesn't make it a cargo cult.
    So you can't guarantee that CB play with Nimbus being placed over friendlies. And what part of the Nimbus ammo rules is unclear?
  18. xagroth
    I found it funny back in the day how Hector was inmunne to his stun grenades, but could not drop them at his feet to affect enemies close by, since it would be an attack XD
    Also, I think a Gaki's Explosion skill could make a Morat/CA player to lose the game (the Wu Ming would use Dogged).
  19. Zewrath
    Zewrath Elitist Jerk
    28 Nov 2017
    That used to be correct, however HSN3 added an entire section about Civilians now and the last bullet points reads:
    • Automatic Attacks (as the one of the Explode Special Skill, for example) which affect a Civilian will be considered null.
    A xagroth le gusta esto.
  20. eciu
    eciu Easter worshiper
    Hilariously Smoke is not an attack so you can use it even when stunned (though you suffer -3 mod due to Stunned).
