Human FAte
Discussion in 'News' started by precinctomega, Jul 17, 2018.
  1. zlavin
    zlavin Well-Known Member
    No, you are not forced to move towards her. If you are not in the 1-5 :SL: range you are not affected by the Pulse so you can move whereever you want. But if at any point during your Activation you are :H: by Prysm, inside the 1-5 :SL: and have enough Action Points to declare an Attack you have to do it.
    Flipswitch, Murt4ir and Zewrath like this.
  2. -V-
    -V- A! Team member
    You're only forced to Attack.
    But if you move once, entering in Range, if you have enough Action Points you will be forced to Attack her as second Action.
  3. Zewrath
    Zewrath Elitist Jerk
    Thank you for quick replies, I’m looking forward to play her! :)
  4. Spellbreaker90
    Just for clarity.
    If a Hero with an Attack that cost 2 begin within 5 of Prysm has to attack her 2 times at his activation start ?
    Someone that start within 5 of Prysm can move and exit the 5 range or has to attack immediately her ?
  5. Roadrunner7431
    As Zlavin said the mandatory attack is only triggered if the following conditions are met: 1. the character is taunted:H: by Prysm herself. 2. you are within :SL: 1 to 5. You have a red stripe attack and all the conditions for the attack are fulfilled including range, action points etc.
    So as -V- and Zlavin state if your attack requires LOS range :L: and that condition is not fulfilled then you cannot attack and can spend your action points freely in other actions. I guess the burden is on the enemy player playing Prysm to keep a close eye on all these conditions since in A! moving and attacking can be performed freely hex by hex.
  6. zlavin
    Yes @Roadrunner7431, you are correct. But remember that every character can use the Contender to Attack and that Prysm will have the Marked State most of the time becouse of her Guiding Light. (A Marked target can be Attacked whitout line of sigth)
  7. Murt4ir
    Murt4ir New Member
    as I understand it you cant just move out of the Pulsing Light radius to avoid mandatory attack : if you activate within 5 of Prysm and you can attack her then you must attack before moving.
  8. Taffer
    Taffer New Member
    I believe Prysm is heavy crowd control of single characters from the look of it. Pretty much choose a target of you choice who you want to be forced to fight, and your opponent can either hard engage on prysm to take her down, or be displace prysm or the target to get them out of the range.
    Yeah sounds about it also mean if you use a 2 action point cost a attack I believe you would be forced to use it twice because it would still be possible for you to attack.
  9. Spellbreaker90
    Eclypse synergize very well with her. Once you start giving out taunt you should be able to keep it on at least 2 targets.
    Elcypse open a lot of ways to keep in check enemy Heroes with status. In her ways she has access to every status in the game if you bring another hero in your team that can deal that status and in top of that she can remove stastus affecting your Aristos.
  10. Taffer
    Taffer New Member
    The interesting thing you don’t actually need to get access to a status to even use her with a high damage team can maintain the negative energy status which can help greatly for maintaining momentum during a match.
    Darts Dendro-nanoids definitely has a lot of potential mainly because it can be used on any state. Which means remove buffs from enemies for the damage or even remove debuffs from allies if in a pinch.
  11. zlavin
  12. Spellbreaker90
    Feng Shu really good card. The thing you can do with a blocked space are a lot and that without considering the natural synergies wit Bixie.
    Curse the card I like the less, it's not bad, but I think the other are better.
    Benediction This one is a must have for using Bixie after she comes out from the bench. If I am not wrong considering the displace the card provides you should be able to return from the bench at the border of One zone and be able to target an enemy up to the center of an opposite zone with Bixie attack action. This could place you in a scoring zone.
    Guided this is another good card, targeting without Los means enemy can't damage you and you can use shields to try activate Bixie Switch for extra Action Point.
    Croepoek likes this.
  13. Smiler
    Smiler Well-Known Member
    Posting the image in thread for the lazy[​IMG]
  14. Plebian
    Plebian Well-Known Member
    Super cool. Hope we get prysm next!
    Smiler likes this.
  15. zlavin
  16. Spellbreaker90
    Dart really likes Laxmee. Focus makes Dart a lot more Deadly thanks to her switches, and with fairy Dust you can remove the Dazzled state imposed on you by Ambush so that you have don't have to give up offensive.
    -V- likes this.
  17. Roadrunner7431
    I agree that Laxmee and Dart are ideal Sisters. However I would like a ruling from -V-. Fairy Dust happens at the beginning of the Actions Step and so does Ambush happen again at the beginning of Dart's Actions Step. Can there be two beginnings? Or does it mean that both should happen before you start spending Energy? By the way, I wonder what the Spanish word is that was translated to "Ambush" because I always thought that Ambush implies an imminent attack. Maybe "Lying in Wait" might be better English to describe what Dart is doing here.
  18. Fathi Amirmoez
    Fathi Amirmoez Active Member
    I believe there's no limitation on how long "the beginning of the actions step" can last, beyond that imposed by the need to reach the next phases of activation to complete the game.
    Given this, and the fact we know you can play multiple tactics with the same timing one after another, I'd say you're free to use them in whatever order, up until you actually start activating Dart.
    Flipswitch likes this.
  19. Flipswitch
    This would be my reading of it also.
  20. Roadrunner7431
    The Spanish title of Dart's tactic is "Emboscada" which means Ambush. I correct myself.
    Fathi Amirmoez likes this.
