How much cover is enough?
Discussion in '[Archived]: N3 Rules' started by Zsolt, Aug 10, 2018.
  1. tdc
    tdc ALEPH Fragment
    As I said, there is an arguement for it not, but it does work both ways.
  2. Skjarr
    Skjarr EI Mouthpiece
    Oh indeed.
    Personally even if it's the top 1/3 covered I'd say in cover.
    It's obscures part of the target (-3 MOD) and there is something there to get in the way of the bullets (+3 ARM) so mechanically it works for me.
    ChoTimberwolf likes this.
  3. tdc
    tdc ALEPH Fragment
    For me, thinking like this is where the rules break down. if you were 1mm away from cover, the same is true - the target is obscured, there is something in the way of the bullets.
    My view is that having cover is a trooper actively using the cover to hide them,
    • for a low wall the trooper crouches, popping up every now and then to fire.
    • for a corner, the troop steps back ever shot to hide themselves
    These are how the trooper gets the visual mod and bonus ARM.
    Where this falls down is a trooper using something that covers there torso and head as cover.... there's no way you are going to be able to hide your legs there... and unless the trooper is constantly dancing a trained gunman will hit a leg even at distance.
    Robock and ChoTimberwolf like this.
  4. Zsolt
    Zsolt Well-Known Member
    This rule shouldn't be this hard to clarify and decide on. Why CB, Why!. Write those rules properly!
    Hecaton and theradrussian like this.
  5. Skjarr
    That's a fair point and when you put it like that it does seem a bit silly.
    However I do enjoy image of a trooper constantly hopping around as the bullets whiz past their legs.
    I suppose it depends how far you want to go with the abstraction. To be honest there are so many bits of the rules that break down when you stop to think about the implications (same with every game system) that I've kind of stopped looking too closely.
    ChoTimberwolf and tdc like this.
  6. Tom McTrouble
    IMO it's pretty clear the base refers to the actual base of the model. If we go by the logic of "base" means silhouette like it does for "base to base" contact, there's no reason to call out a height requirement separately. If they wanted base to mean width, they would have said that. Cover has to cover your feet yo.
  7. Zsolt
    I'd rather get shot in the feet than in the head.
  8. toadchild
    Early N3 FAQs retroactively redefined "base contact" to mean "silhouette contact".
    Hecaton, Zsolt and ChoTimberwolf like this.
  9. Urobros
    Urobros Well-Known Member
    We really have a discussion here...? The rules couldn't be more clear in this point:
    Partial Cover
    Partial Cover partially blocks the attacker's vision of his target.
    Requirements
    • The target of the BS Attack must be in base contact with a piece of scenery.
    • For a piece of scenery to be considered a valid Cover, it must conceal at least a third of the target.
    And yes, base contact it is easily translated here like "siluette". No need to think more about it.
    Greetings
  10. Zsolt
    Yeah, arguments can made lot shorter, if you ignore 60% of the facts....
  11. Urobros
    :thinking_face:wich facts? You need to have a third of your miniature conceals with cover, at least... What more do you need to know if you have, or haven't, cover? Now with the siluettes are relatively easy and quickly to see this 1/3.... Are a lot of rules wich probably need a clarification but this.
  12. Zsolt
    This is what's in the rules:
    • For a piece of scenery to be considered a valid Cover, it must conceal at least a third of the target. This means that it must have a height that is equal to or higher than one third of the target's height, and must also cover at least the equivalent of one third of its base.
    See how much longer the second sentence is than the first one? Those facts.
  13. tdc
    tdc ALEPH Fragment
    Apart from the second sentence does not change the requirements of the first.
    If you only have 1/9 (1/3 hight, 1/3 width) you do not satisfy the first sentence.
    DukeofEarl and Urobros like this.
  14. Urobros
    Ok. I don't think it was necessary to copy every word of the "wiki" or "the rulebook" to make an argument. The rest of the paragraph don't denies in some way the first sentence, only clarifies it. The rule is well explained.
  15. Zsolt
    I think it does. Covering the third of a rectangle is not the same as covering one third of it's width AND one third of it's height.
    If something covers EITHER one third of it's width, then one third of the whole area is covered. But if I cover one third of it's width, then it also means, the total of the height is covered for that strip. And this contradicts with the second part, which says only the third of the height needs to be covered. If I cover both the width and height's one third, I either cover 1/9 of the whole area (if I cover one third of the one third), or 5/9 of the whole area (If I cover one third width fully and one third height full). See above for pictures.
    That's my point, the second part says "this means", but it doesn't mean the same, it means something different.
  16. tdc
    tdc ALEPH Fragment
    Yes and No.
    I can't be bothered to make a pretty picture this time, so text version!
    Here's a model
    Here's two examples of a model with 1/3 covered in terrain (red). Do either of these satisfy the second sentence?
    |||||||||_____|||||||||
    |||||||||_____|||||||||
    |||||||||_____|||||||||
    |||||||||_____|||||||||
    |||||||||_____|||||||||
    |||||||||_____|||||||||
    Likewise two more examples with 1/3 covered in terrain (red). Do either of these satisfy the second sentence?
    |||||||||_____|||||||||
    |||||||||_____|||||||||
    |||||||||_____|||||||||
    |||||||||_____|||||||||
    |||||||||_____|||||||||
    _____|||||||||
    In both cases the width of terrain on the left hand side is NOT 1/3 or more of the model, however for the right hand side it is.
    Yes, english is a dumb language. But the above example is what the second sentence is talking about.
    Urobros likes this.
  17. Zsolt
    Too bad, the previous pictures were perfect!
    I'm not sure, you cover the 1/3 of the area, just not in a continuous part. But there were no requirement for it being continuous.
    But my problem isn't about continuity, just the amount of area covered.
    OOO
    OOO
    OOX
    X is in cover, O is not. This satisfies the second part. Is it in cover? There's a line, where one third of the width is covered. Also there's a line where one third of the height is covered. It still seems odd.
    I'd say no. But the "this means" part means the first and second parts of the statement means the very same. So how can I not be in cover, if I satisfy the second part?
    If this lone X doesn't satisfy the second part, what should?
    OOO
    OOO
    XXX
    One third is covered, seems we are done here. But the height is covered the exact same way as in first, so how isn't the first not in cover?
    I'm running circles. I should stop.
    Mask likes this.
  18. tdc
    tdc ALEPH Fragment
    That's the thing, the paragraph
    is only talking about a (single) piece of scenery. It isn't describing how a model can claim cover from scenery, but stating how a (single) piece of scenery provides cover to a model.
    So whilst in both left hand cases a third of the model in all dimensions is covered by scenery, neither pieces of scenery cover 1/3 or more of the model in either left hand case.
  19. Zsolt
    Scenery item:
    XXX
    X X
    X X
    mind blown! Or if we bother about the base being covered:
    X X
    X X
    XXX
  20. Mask
    Mask Well-Known Member
    Cannot be clearer than this! This is the demonstration that the rule is poorly written. Very very very poorly written. Nothing to be ashamed anyway. Just admit that and go with a rewrite and we'll be all proud of you CB.
    Mask
    Hecaton and Zsolt like this.
