Maybe if you assembly it... It's not truly difficult, I'll give you some tips according what I'm seeing. The panel you have at the bottom-right, goes inserted at the panel you have at the top-right. The panel at the center-right goes with those you have at the center-top and probably with those at the center-center The door (panel at the top-left) goes in front of the first one (bottom-right) The panel at the bottom-center and the one at the center-left are the lateral walls. So now you can assembly partially a box with the main shape, without using glue, to show a better picture of the model. Maybe that could be of help. EDIT: Ah, the small pieces that you have at the left (most of them at the left, all of them with the same shape) are the steps of a ladder, whose lateral pieces are those which resembles a candycane or a cane next to one of the lateral walls. The piece which is next to the ladder step at the bottom (the one with 5 connectors at the right side) is attached with its siblings (same shape, you have four) to the lateral walls at the T holes.
