Haqqislam's Finest: Ramah Taskforce Tactica and Hub
Discussion in 'Haqqislam' started by Pride of Rodina, Feb 25, 2017.
  1. ik3rian
    ik3rian Anti-Ariadnian Specialist
    Space Artichokes can "Tohaa year" my ass, we are going to tear trough the competiton!
    Jonno likes this.
  2. The Red Duke
    The Red Duke Well-Known Member
    Can Leila duo with the Maghariba guard? And if so, is it just the Duo loadouts?
  3. HardDisk
    HardDisk Well-Known Member
    Yes and yes
    Xeurian likes this.
  4. Palomides
    Palomides Well-Known Member
    It's worth mentioning that the Rafiq is a repeater, so Leila can attack AHDs through the Rafiq if you don't want her slowing Maggie down.
    The Red Duke likes this.
  5. Deltervees
    Deltervees Crash Test Dumbass
    If Leila can replace the bot, can she replace maggie and duo with the bot?
  6. colbrook
    Does the bot or Leila have the required Fireteam: Duo skill?
  7. 8vius
    8vius Member
    To take the Maggie with the Bot do you have to take the one that has the Fireteam DUO on it? Considering the bot is a Special fireteam?
  8. ambisinister
    ambisinister Broken Zoetrope
    Yes. You can't have a fireteam of any sort unless you have a profile that allows it. In this case, only Duo Maggies can create fireteam duos.
  9. emperorsaistone
    No, for that case the a normal maghariba should suffice. For a Haris youd also only need one Haris profile.
  10. ambisinister
    Ah. Good catch, I misunderstood. Yeah, an FTO rafiq can duo with a non-duo maggie.. So @8vius here are the options as I understand them:
    maggie duo+ any rafiq fto
    maggie duo+ any wildcard
    rafiq fto + any maggie
    rafig fto + any wildcard.
  11. HardDisk
    You need at least one duo skill at your duo
  12. colbrook
    Sure, that's why I asked if they had it.
    Now I can check it looks like the Rafiq has Duo so Rafiq+Leila is legit.
  13. Section9
    Or Naffatum. (because linked HFTs are good for that!)
    Xeurian likes this.
  14. The Red Duke
    I think this is usually what you'll want to do. My only thought with bringing Leila herself in the Duo is that she can help defend against enemy repeaters and pitchers, where the Rafiq can't.
  15. Papa Bey
    Unless the hacker manages to Blackout the Rafiq when it enters their hacking area...
  16. Xeurian
    Xeurian Well-Known Member
    Yeah, that's the main problem with running any remote to use as a hacking attack vector against other hackers. Instead you can only really safely position it as anti-hacker point defense in ARO.
  17. Lext
    Lext Karakuri resculpt
    In regards to the "counts as ghulams" rule, could I use the Khawarij haris profile and make a Haris with him, ghulams, or naffatuns?
    Or in this instance could only Khawarij join the khawarij haris profile, as ghulams and naffatun don't count as Khawarij?
    Sent from my SM-J530Y using Tapatalk
  18. ldgif
    ldgif Well-Known Member
    Latter is correct as Ghulam don’t have Haris linkability.
    Lext likes this.
  19. Sojourne
    Sojourne Irregular
    How would you build RTF, assuming Limited Insertion? I'm having trouble as I find we don't have that many good "tarpit" options. No ghazis, minelayers or good AROs at the LI level.
    Have to build for scenarios where you don't get first turn, and if you're up against super strong first turners such as IA with their pain trains.
  20. Shoitaan
    Shoitaan Well-Known Member
    Play like PanO, setup a wall of Dakka. The Ghulam BS will be ok with FT bonuses but with so many troops counting as ghulams, doesn't need to be LI sticking their heads out. Plus the option is there to also provide bait the enemy will burn order to zero in on: Maggie, Namurr etc.
