We've got confused about the interaction between Caliban engineer and G:Servant remote. Here's the point. 1. If either trooper is not able to perform one of either Short Skills of the Order, then that trooper will perform only the Short Skill he is able to perform, and the other Short Skill will be an Idle. While the other trooper will perform his complete Order normally. 2. G: Servant and Doctor and Engineer Special Skills ••• However, when using this Special Skill, it will be the Doctor/Engineer who makes the corresponding Roll. 3. According to 1, if Caliban stays Camouflaged, and doesn't move but only controls the Servant to get b2b with Unconscious trooper and declares Engineer Short Skill, since he is not in b2b with the target, he cannot declare Engineer skill so his order is considered an Idle(The Servant will perform Engineer Skill instead). So we thought his Camouflaged state will not be cancelled, but according to 2, it says 'he's the one who makes the roll for Engineer Skill'. -> Declares Idle, but makes the Roll. Will the Camouflaged state be cancelled?
Camouflaged is cancelled when you Declare a skill other than a Short Movement Skill that doesn't need a roll, or Cautious Move. Regardless of the fact that the skill performed might end up being an Idle, the Caliban has Declared Engineer (as both Controller and Servant must Declare the same skills) so they will be revealed.
Yeah, the same happens with Coordinated Orders, what the trooper actually does is irrelevant, what matters is the Declaration.
